Memz180
Fuel gauge problem
Hi guys,
Car is 180sx type x 96 model sr20det
One morning went to car gauge was showing full tank when only half tank of petrol inside.
Drove it around the level came back down to normal.
A few days later after filling up the gauge keeps going up and down. Every morning the gauge would show more than what's in the tank till I start driving then gauge would come back down.
I've searched around and others have said that the resistor in the sending unit can be the problem. So I pulled out the fuel pump assembly and the float seems fine have not tested resistance though which I will do soon.
Would this be a gauge issue or more likely the fuel gauge sending unit ?
sender unit pull the sender unit back out and put the float throught its motions and get someone to monitor the fuel gauge.
Thanks will try this.
You're not parking on a slope at night are you?
- Lance
Parked on dead flat surface.
Edited by Memz180
