Simon-S14
problems with BC's and Driftworks knuckles
wondering if anyone has had the same issues as me? Put some rear driftwork knuckles into the s14 and my BC ER's dont go long enough... as it was before i was only 20mm from max full length on the coilover... i could have gone 140mm lower but not higher.. seems odd. So with the knuckles and BC's raised to the max 20mm i can get its still way too low.
anyone?
Had the same problem with a customers 180sx. Maxed the coilovers to the top and was still really low. Using G4/D2 coilovers or something from memory.
*sigh* thought this might be the case... gonna have to make a spacer plate that sits on top of the coilover to add length
mine fit fine, although i did have to grind the front coilover a few mm to clear the clevis on the knuckle. rears bolted straight in, just wound the base of the coilover down the appropriate amount.
on what car?
and yeah i have the front fitting issue also haha
cant just run it lower simon?
mine is a s14, its only as low as the front tyre top is level with the guard at 4.5 camber, and the rear is tucking some tyre, perfect height
They're not S13 coilovers are they?
