pointblankauto
Silicone Hoses - Straight, Reducers, 45 Deg, 90 Deg, 135 Deg, T-Piece, Clamps, Vacuum Hose
We stock the full range of handmade silicone hoses and stainless steel t-bolt hose clamps designed for performance applications. Available hose types include straight joiners, straight reducers, straight humped joiners, 135 degree elbows, 90 degree elbows, 90 degree reducing elbows, 45 degree elbows, 45 degree reducing elbows and t-piece joiners.
Note: All straight joiners and straight reducers are 80mm in length. All sizes available in BLUE and BLACK. All parts ARE IN STOCK at all times. Contact us for trader order discounts.
Straight Joiners
2 Inch ID (51mm) Straight Joiner $9
2.25 Inch ID (57mm) Straight Joiner $10
2.5 Inch ID (63mm) Straight Joiner $10
2.75 Inch ID (70mm) Straight Joiner $11
3 Inch ID (76mm) Straight Joiner $15
3.25 Inch ID (83mm) Straight Joiner $16
3.5 Inch ID (89mm) Straight Joiner $17
3.75 Inch ID (95mm) Straight Joiner $18
4 Inch ID (102mm) Straight Joiner $19
4.5 Inch ID (114mm) Straight Joiner $21
5 Inch ID (127mm) Straight Joiner $23
Straight Humped Joiners
2 Inch ID (51mm) Straight Humped Joiner $13
2.5 Inch ID (63mm) Straight Humped Joiner $15
3 Inch ID (76mm) Straight Humped Joiner $22
3.5 Inch ID (89mm) Straight Humped Joiner $25
4 Inch ID (102mm) Straight Humped Joiner $2
Straight Reducers
2.25 to 2 Inch ID (57-51mm) Straight Reducer $10
2.5 to 2 Inch ID (63-51mm) Straight Reducer $11
2.5 to 2.25 Inch ID (63-57mm) Straight Reducer $11
2.75 to 2.25 Inch ID (70-57mm) Straight Reducer $11
2.75 to 2.5 Inch ID (70-63mm) Straight Reducer $12
3 to 2 Inch ID (76-51mm) Straight Reducer $14
3 to 2.25 Inch ID (76-57mm) Straight Reducer $14
3 to 2.5 Inch ID (76-63mm) Straight Reducer $16
3 to 2.75 Inch ID (76-70mm) Straight Reducer $17
3.5 to 2.75 Inch ID (89-70mm) Straight Reducer $18
3.5 to 3 Inch ID (89-76mm) Straight Reducer $18
4 to 3 Inch ID (102-76mm) Straight Reducer $20
4 to 3.5 Inch ID (102-89mm) Straight Reducer $21
5 to 4 Inch ID (127-102mm) Straight Reducer $27
45 Degree Elbows
2 Inch ID (51mm) 45 Degree Elbow $20
2.25 Inch ID (57mm) 45 Degree Elbow $21
2.5 Inch ID (63mm) 45 Degree Elbow $23
2.75 Inch ID (70mm) 45 Degree Elbow $26
3 Inch ID (76mm) 45 Degree Elbow $34
3.5 Inch ID (89mm) 45 Degree Elbow $40
4 Inch ID (102mm) 45 Degree Elbow $48
45 Degree Elbow Reducers
2.5 to 2 Inch ID (63-51mm) 45 Degree Elbow Reducer $24
2.75 to 2.5 Inch ID (70-63mm) 45 Degree Elbow Reducer $30
3 to 2 Inch ID (76-51mm) 45 Degree Elbow Reducer $35
3 to 2.5 Inch ID (76-63mm) 45 Degree Elbow Reducer $35
3 to 2.75 Inch ID (76-70mm) 45 Degree Elbow Reducer $35
3.5 to 3 Inch ID (89-76mm) 45 Degree Elbow Reducer $42
4 to 3 Inch ID (102-76mm) 45 Degree Elbow Reducer $48
4 to 3.5 Inch ID (102-89mm) 45 Degree Elbow Reducer $51
90 Degree Elbows
2 Inch ID (51mm) 90 Degree Elbow $21
2.25 Inch ID (57mm) 90 Degree Elbow $23
2.5 Inch ID (63mm) 90 Degree Elbow $25
2.75 Inch ID (70mm) 90 Degree Elbow $27
3 Inch ID (76mm) 90 Degree Elbow $38
3.5 Inch ID (89mm) 90 Degree Elbow $56
4 Inch ID (102mm) 90 Degree Elbow $68
90 Degree Elbow Reducers
2.5 to 2 Inch ID (63-51mm) 90 Degree Elbow Reducer $25
2.75 to 2.5 Inch ID (70-63mm) 90 Degree Elbow Reducer $30
3 to 2 Inch ID (76-51mm) 90 Degree Elbow Reducer $39
3 to 2.5 Inch ID (76-63mm) 90 Degree Elbow Reducer $39
3 to 2.75 Inch ID (76-70mm) 90 Degree Elbow Reducer $39
3.5 to 2.75 Inch ID (89-70mm) 90 Degree Elbow Reducer $51
3.5 to 3 Inch ID (89-76mm) 90 Degree Elbow Reducer $50
4 to 3 Inch ID (102-76mm) 90 Degree Elbow Reducer $57
4 to 3.5 Inch ID (102-89mm) 90 Degree Elbow Reducer $56
135 Degree Elbows
2 Inch ID (51mm) 135 Degree Elbow $27
2.5 Inch ID (63mm) 135 Degree Elbow $37
3 Inch ID (76mm) 135 Degree Elbow $55
T-Piece
2 x 1 Inch ID (51mm x 25mm) T-Piece $18
2.5 x 1 Inch ID (63mm x 25mm) T-Piece $21
2.75 x 1 Inch ID (70mm x 25mm) T-Piece $26
3 x 1 Inch ID (76mm x 25mm) T-Piece $30
T-Bolt Host Clamps
2" Stainless T-Bolt Hose Clamp (54-62mm) $6
2.5" Stainless T-Bolt Hose Clamp (67-75mm) $7
3" Stainless T-Bolt Hose Clamp (79-87mm) $8
3.5" Stainless T-Bolt Hose Clamp (92-100mm) $9
4" Stainless T-Bolt Hose Clamp (104-112mm) $10
Vacuum Tubing
1/8 Inch ID (3mm) Blue Silicone Vacuum Hose - 1M $8
3/16 Inch ID (5mm) Blue Silicone Vacuum Hose - 1M $9
1/8 Inch ID (3mm) Black Silicone Vacuum Hose - 1M $8
3/16 Inch ID (5mm) Black Silicone Vacuum Hose - 1M $9
What are the lengths of each silicone join? Needing at least 70mm!
Also does your BLACK silicone joins include brand marking or are they just plain? I'm after the latter...
Cheers,
Andy
Hi Andy,
All of the straight joiners and straight reducers are 80mm in length. There is no branding on any of the silicone we stock.
