cuttz
cuttz mx83 cressida yes 3 year build almost done. With 1uz r154 goodness
hey all been meaning to do a thread on hear for a while now so my 1992 cressida grande im building
bought it about a year ago bog stock grampa style from Melbs and bought it back to Bendigo and pretty much started the mods strait away
plain was that i wanted to build something tuff from the ground up and do a full conversion all myself witch would include an engine transplant and manual conversion
seen as I haven't done ether i was keen to do the cressy
i have owned copious amounts of high powered Nissan's but now wanted the Toyota reliably and cool factor
i was planing to go 2jz but there a few around and in process atm and even though ive sen a few with the 1 uz haven't seen f all with boost running through it so that's the path im taking
so i just bought a 1 uz and its getting removed from the half cut as we speak
so far I have imported some work euroline 18 rims for her but now want to go 16 or 17 so there up for sale as i want the hella flush look as well
i also cut the std struts and welded in some br bc coilovers all-round witch included upgraded sway bar links
to keep my roll center in check and to piss of bump steer i installed some techno toy tuning rca's
to help me stop i had some alloy hub rings made to fit dba slotted ba falcon 298mm rotors and Nissan r33 gtst skyline 4 pot calipers (made a huge differance)
also bought a brand new Nardi sports type a 360 to get rid of my old torn item
sorry for the soon to be pic loading all at once but ill post up how i welded the coilovers in seen as im a boilermaker this wasn't hard for me but i suggest getting a qualified welder to do this and saying that please use my pics and any info i have given as a guide only
righto is how i first got it it really was in mint condition i looked for aged making sure one had all the door gaps right and over condition was spot on
it had a few km but it was to clean to pass up it even still hd all the std stickers and they where like new so it was always garaged
Edited by cuttz
then i started buying heaps of shit these are my new br bc coilovers
the new sway bar links that come in the coilover kit
these are the rca im using, there good solid 1 peace design and come with all high tensile bolts
this is the bottom of the front coilover
you will need to weld this to the bottom of the std strut so for a back up im doing a roset weld hear! basically drill a 12mm hole both sides of the bottom coilover tube so you can fill full of weld
these are my r 33 gtst calipers, i used a 5" flap disk to remove the nissan logo from the face
these are my new dba ba falcon rotors
these are sooooo much bigger and thicker than std and i can see how the make the differences they do
this pics has the hub rings i had made in the center
righto its business time
use this as a guide only and make sure you pre heat the cast steel on the strut to around the 180deg mark and make sure you cleen the living f@#k out of it on a wire wheel ok
remove the caliper and the rotor (crc or 5.56 is your friend)
remove the dust cover to expose the hub nut use a flat head strew driver to lift the locking tab up and undo the nut (make sure you do this back with torque wrench! mine felt good at 96 nm)
then the hub and wheel bearing should just slide off i suggest you inspect the wheel bearing at this stage as well
this is the abs sencor this has to remain so look after it when your removing it
undo the brake and abs lines from the side of the strut
this is the old long sway bar link throw this in the bin as this mounts from sway bar to strut tube and the new one replace this shit setup
this is the new sway bar link and the rubber mount fit snug into the holes that are already pressed into the a arm (also torque this up to spec)
while the stone guards are off im cutting them down to fit the brake upgrade later on
this is the bottom of the std strut notice ive left 50mm of the std strut tube on as this will locate the coilovers
best way to do this is to get some 50mm masking tape and rap around the tube and cut along the edge of the tape with a cutting disk
this is how clean the knuckle must be before any pre heat and welding
drill the roset holes i spoke about earlier
time to pre heat and weld don't pre heat the tube just the cast steel. i used a 3 phase 350 mig with .9 wire
note after you finish welding keep heating lightly with the oxy torch to slow the cooling process or place in a bucket of sand
then cleen up and paint black to stop rust
now its time to place the rca in place
install the coilover in the car and torque the rca up spec
now put it all back together and repeat for the other side
to do the rears you have to remove the rear seat and parcel shelve but apart from that 4 bolts and there in
i then put some stock r33 rims i have on
and this is the base high so can go much lower
then removed the gay mud flaps
time to do the brakes and install new wheels
this is the size diferance between rotors
easy as 123 just unbolt the caliper and pull the rotor off and put the new ones on
i first painted the calipers with high temp caliper paint to make em look sexy
then fitted my work euroline rims i imported with new falken and now looks like this untill i buy smaller ones and roll the gaurds im not going lower but it will happen
these are for sale if anybody is intereted
ok now to replace my foo barr s/wheel i bought this!! brand new nardi sports type a 360 from italy
please dont ask how much as it almost mad me cry but wanted this type and diameter(360) so bad as i like having a bigger wheel as you get better feel and control
mmmm succulent
now the horn button reqiures a hurn retainer witch was a king pain in the arse to find one but got one from the states for like 40 posted
as the horn need the genuine nardi or works bell boss kit to locate it $$$ stuff that i said and bought a ebay special boss kit and said horn retainer to make suit
now its all fitted and looks prime in its new cockpit
Looking good mate, Keen to see the progress on this. And good to see another person from Bendigo!
got bored at work one day and had some 3" zorst laying around so i started to make a set of dift pipes for when the new engine goes in
im going to paint the whole zorst black when i make the rest of it whethe 1 uz goes in
now im just waiting on my engine to be ready for the next stage and now the gear box hunt begins
so that about all for now sorry for the epic flurry of pics all at once
as for the boosted part im still undecided as to go the m90 Eaton supercharger with twin throttle body's ( witch is in favor ATM)
or ill make some steam pipe manifolds and go twin 2871 r but leaning towards the supercharger ATM as i like the whole 800plus NM of torque side of things at the ready
but now i can post updates when im ready so yeah let me know what ya think cheers
Mate iv never liked these things but this is changing my mind :) some good quality mods mate i look forward to seeing how this turns out
thanks for the coments guys cant wait for the engine to be hear then i can strip it down for ome work yo
Nice bud, all most identical to my mx83 but got a GLX without abs and I'm going 1jz
nice one mate can't wait to go down to 17 so I can fit some tires and mould my gaurs around em for more lowness
Those wheels I'm running are
Front 18x8.5 +45 with a 225/45
Rear 18x9.5 +45 with a 245/40
There is about 3mm between the strut and rim on the front with no guard modification. You will need a lower offset to clear the Coilovers if you want to run similar size but I wouldn't go any wider. Rear only needed the guards lipped as there is plenty of space. It could easily run a 10" wide rim but the crap offset doesn't give you much choice in rims. These things arnt like silvias, you can't even get anywhere near a low offset without major guard work (or run a 6" or 7" rim lol)
Nice, will be watching this. 17x9 +30 is pretty much perfect on a cressida...
yep im trying to sell mine to buy some r33 gtr rims or buddy clubs with even bigger offset
update on the 1uz is ready for me to pick it up on the weekend he he
already got a quote on head porting ruffly $1000 to port and polish the 2 head if i strip em down not to bad imo
also thinking about stripping the whole motor down and balancing the crank and changing bearings and maybe set of rods and piston
ill see as i just got another quote for the cams and there worth 1600 to 1800 king almost feel over when i got that one
Guy on toyotacressida was talking about doing regrinds, think it was a bit cheaper than that too...
Hey bud, where did you get the Nardi from? I'm after a 350mm Deep Dish one (dam my long legs!) and what model boss kit did you use? (MX83, AE86, Ect...)
hey man I bought my nardi brand new from a web site called thetunnergroup.com.au
it cost about about $430 for memory
they buy direct from nardi Italy so they get a good price
deep corns are cheeper as they sell more of them but I perfer the sports type a witch is mine
as for the boss kit eBay brother 50 it's a mx83 one but fits a few Toyotas
if you buy a genuine nardi you will need the horn retainer I'll try and find the place in USA where I got it and post it for ya there about 45 posted I think
expencive exercise to fit a nardi to these but stuff it
On a more exciting note my new 1uz is in the shed hurray
soon as the camra charges I'll load some pics up
anyone know where to find a wiring diagram cause dam there some wires and sencors on these things
is anyone else having trouble with the pic loader cause its anal at me for some reson
Yeah, thanks alot mate! Cant go past the Nardi quality and look. I been sussing out places selling legit Nardis and came across www.tunersgroup.com before. Its good to know there legit
and pic uploader is always gay... reload the page a few times and try again.
Nice choice on the 1uz, You seen the missile motorsport Cressida?
and hear is wher to find the nardi retainer ring www.crowderscustomizing.com
