grub_ze70
Feint motion AE86 build
hey guys, some of you may know this car... after all the problems last year with the 4agte we have decided to move away from 4a's all together. going with a world first in an AE86.
here are some snaps! befor...
the new engine...
yes your right... its a 2GR-FE 3.5 v6 all aloy quad cam out of an aurion. where putting individual throttle bodies on it with and after market ECU still running the VVTi. we hope to make about 200kw at the wheels...
interesting choice, be good to see how it goes!!
Very interesting, good to see something that hasn't been done. Hope it all works out for you.
they are an alloy block also yeah? awesome choice of engine should be reliable as hell... just needs a turbo on it :P
Nah keep it na, I've been in a stock aurion and they fly can't Imagine what it's gna be like in a lighter car and with mods
Much respect for going down this path, good luck with the build.
Ah awesome, I finally get to see pics!
I hope this proves to be more reliable for you guys :)
About time you let the cat out of the bag.
Can't wait to see it finished and in action
cool as! dont they have 200kws stock? should get more out of it easy :)
should be interesting to see, you can always bolt on the trd supercharger aswell if you want more power :)
Nice engine choice, still got the 5year - 100,000km warranty on it LOL?
Engine Weight? Flywheel? Bellhousing?
we're using a 3sgte flywheel and clutch. im not sure of the weight but and steve i can pick it up without too many problems! going off that, it is close to the weight of a 4AG. we have a few bell housings that are close to fitting. but one of the bigger problems we have come across is the mounting of the starter motor. cause in the camry its mounted on the gear box side so there is no hole on the engine side to put the starter motor through.
there is an off road buggy in aus with a 2GR twin turbo pumping out 600KW at the flywheel on 18psi! when the engine had stock internals they were running it at like 10psi and making around 400kw at the flywheel. im going to make a BIG call here but i think theyre the new 2JZ.
http://www.supraforums.com/forum/showthread.php?t=467852
That's a great conversion idea. Look forward to seeing it in action. Should make some great torque too :)
I wouldn't see any need to tune it, drove an Aurion for a month last year and it definitely lived up to all the ads about its power :thumbsup:
interesting .. good to see someone steering away from the norm
cant wait to see this all done
wow!!!
impressive! also quite a large call about being the new 2J, but it seems to be the go!
good luck with the rest of the conversion/build
was wondering what happened to this car
good luck with it
It's also gonna use the W58 that's already in there.
Just machined a lightened 3sgte flywheel to the aurion bolt pattern.
The plenum idea was discussed, just in case I decide to go forced induction later.... But individual throttles make me happy in the pants :) can't wait to see the trumpets sticking out the bonnet :D
wow this is f**king awesome.
goodluck with it all :D
Awesome work mate. I used to drive an aurion at work and I was really impressed with it's power in that chassis (torque steer and axle tramp galore), let alone something this nimble, best if luck with it, very keen to see your end result
Do like! How far from completion?
Need to work faster... SO many people waiting to see the finished product. Better start building at the speed "Nigel" does... :lol:
is that even possible, should be interesting to see no the less :thumbsup:
