shogun!
Shogun, from stock to extreme +700hp
Nice one tim...
At least you can hold your turbo one handed :quagmire:
The extra work you put into the turbo should be worth it :D
cheers mate :D
it spool very early and hit max at around 6000rpm
I bet yours are no lesser ;)
Bought a large box of oil.
(8 l engine oil) Motul 300V Competition 15W-50 Racing lubricant for racing cars
(5 l gearbox oil) Motul Gear 300 75W-90 Racing gearbox lubricant 100% Synthetic – Ester based
(6 l LSD oil) Fuchs Titan Race Gear 90 LS High Performance Limited Slip Diff Oil (formerly known as Silkolene BOA 90 LS)
(1.5 l brake and clutch fluid) Motul RBF 660 Factory Line race brake fluid
I LOVE IT !! such power for such little engine.. the time n effort u put in is inspiring..
but i do agree with koguchi, the wing belongs in d bin.. other than that 10 outa 10 :)
The original watercooled oilcooler, mounted on the engine block under the oilfilter, is sometimes creating a problem and has to be removed. It could be a problem with the function, available space etc. In my case the reason is a heavily tuned engine with high boost pressure. This create a very high local temperature rise. Let us call it a local thermal water explosion. This local temperature rise create a high local pressure in the cooling system and this could make the original oilcooler crack and cause a water/oil leak.
There are some ways to solve this problem, this is how I chose to do it:
Original oilcooler is hidden under the intake manifold and behind the alternator.
Original oilcooler. It is mounted on the block with 4 bolts.
Here it has been dismounted.
A close up to show how it looks behind the oilcooler. It is important to remove all trace of old gaskets and paint. The mating surface must be smooth and clean since this is the surface where the oilfilter/sandwich plate is sealing snug and tight.
In the centre you can spot the original stud. This is to be dismantled (twist it out like a screw).
Original stud dismounted.
In Nissan FAST software, part 15213P is found. This part is only used on engines without an original oilcooler mounted on the engine block.
It is named "Stud, oil filter" and Nissans part number according to Nissan is 15213-W040A. I have ordered one and will test it to be 100% sure it is the correct part.
The valve I will mount in the filter holder.
Stud, 15213-W040A, mounted in the block (the four bolts and the gasket shall be removed).
Now you can select if you would like to use only a filter, an external oilcooler, a filter relocation kit or a combination with all of them.
I use them all.
Oilcooler thermo plate.
Mounting an oilcooler and a thermo plate.
Filter relocation kit.
An awesome find and solution on the filter side of things Tim!
There is also a cooler less oil filter mount (for lack of a better term) from u12 spec CA18's I believe. Could possibly be Exa.
Will post pictures of the unit when I can.
But many kudo's on your build! And will probably follow this route when I build my CA up.
Yesterday I was informed the new R-tyres are on their way and they should be delivered to me today. The flush fit wheel air valves have also been shipped. Soon time to get it all assembled and balanced. Exciting :)
I have that kind of valve on my other wheels too and they bring a nice touch to it.
It turned out very well with the flush valves on the new wheels I use for the R-tyres. Pictures to be posted after next round in the garage. I will have to remember to always keep the air fill adatper in the car from now on.
When the tyres were mounted on to the rims, they had to pump them up to more than 4 Bar of pressure. It sounded like a big cannon in the tyre shop. My poor ears...I wasn't prepared at all... at least not when the first tyre went on.
Mounted some parts. It will be ok but as shown, there is lots to adjust regarding wheel alignment and I will also adjustthe track both front and rear. At the rear, there is plenty of Camber but still a slight gap between the tyre and the fender. At the front, there is also some space for adjustments. I will decide how much I want to slam the car when the coilovers have settled. The steering angle has improved with the spacers mounted on the inner tie rods.
or why not this one? :hypo:
You are very lucky, it seems as if you have an unlimited budget for this car. It should be perfect when you are done :)
But once its finished you are probably going to get bored and will want to build more and more ;)
Your garage is pretty sweet as well, would be perfect if you had a car hoist in there too
Some OEM-parts I picked up today:
Holder for the license plate lights.
Fasteners and washers for the camshaft brackets (total 24pcs of each).
Over pressure valve and oil filter stud to remove the OEM oilcooler.
Fasteners, washers and nuts for the outgoing drive shafts on the diff flanges (total 12pcs of each).
Fasteners, washers and nuts for the prop shaft on the ingoing flange on the diff (total 12pcs of each).
ChargeSpeed supplied by BadAssParts. Test mounted prior to paintjob.
Whats with the wide body when you dont have wheels wide enough to fill stock guards?!?!
To resolve the issue you had with the inline oil cooler problem i went a different route (first off i used the non in line cooler filter adaptor which bolts into place, then i got myself one of the Growly fittings, this way you have lines coming straight out of the block to a oil filter relocater, then to the oil cooler then back to the block. so much neater.
Take some time to read a bit more. I have wheels wide enough.
Thanks for the information about the adapter :)
A bracket to relocate the license plate and a ignition key light
A brief summary of what I'm working on regarding aerodynamics of the car:
ChargeSpeed front fenders from BadAssParts test mounted prior to the paint job.
this thing is awesome. good to see you taking your time to do it right.
going to be pretty mental when its finshed.
you going to be tracking this thing with all the aero you have planned?
Wow... All I can say is wow!!!.... Just read this whole thread, totally worth my time. Great build thread mate and good on you for posting pics and descriptions to help out others while your building your beast. This car will be an absolute monster when you are finished. I cannot wait to see the pics and videos when its done! Are you going to get the whole car resprayed ? or just have the guards/skirts painted the same colour as the rest of the car ? Keep up the good work man.
Steve.
ps... I wish I had your income :P
Thanks bro :D
Yes I will track it with small woll ribbons attached to the body and a video to spot the airflow.
Differential pressure gauge to measure the pressure changes.
A digital scale with remote reading to measure travel up and down.
Steve.
Thanks Steve. Very nice post :D
I will respray it in its original colour.
Truley amazing Shogun, i have seen your build from all around the world..
Keep it up, i cant wait to see it finished... Altho i doubt you will ever be finished haha :D
Damn this thing is cool! Good to see you're really putting alot of thought into everything you do! So jealous of it all!
God Jul & Gott Nytt År
Merry Christmas and a Happy New Year
Joyeux Noël et bonne année
Fröhliche Weihnachten und einen guten Rutsch ins neue Jahr
Gleðileg jól og farsælt komandi ár
Buon Natale e felice anno nuovo
旧年中大変お世話になりました
¡Feliz Navidad y próspero año nuevo!
Some tiny bits in place
