Downtown
which light bulb for s15 GT wing brake light?
howdy, tried searching, i need to replace the brake light bulb in the GT wing, i assume the wing will just unbolt off and bulb can be easily removed and replaced??, thanks..
nope, its a bulb, an 18w E2, that pushes in by 2 pins, there is a small screw on the back of the spoiler opposite the light, and then the light pushes out, although i took the dam spoiler off, which made it easier anyway, there you go.. later...
sorry to bump an old thread.
is there a trick to doing it without removing the spoiler? I got the screw out from the back and pushed the light out, but the wiring stops it from coming out far enough to change the globe.
cheers.
ok i managed to get it out for anyone else interested. just need to feed the wire through the spoiler to let it come out a little more, then twist and remove.
