WICD
RB20 CAM ANGLE SENSOR PROBLEM
Hey guys,
I have just bought a VL with an rb20 in it, and it needs some work.
started it today and let it get up to opperating temp and the CAS started to smoke... atleast i think it was the CAS smoking, the car doesn't have a timing cover on it and the smoke was coming from the sensors side.
I dont know anything about rb20's, does the sensor have a bearing that can go or anything? i have no idea...
thanks for your help,
Darren
hey mate check that the timming belts not rubbing on anything ....... dont think they have a bearing
try replacing the sensor, mine smoked up then i blew my rb20,
it doesn't have a timing cover on it? Has it been spaced out the thickness of the timing cover when it was removed? If it wasn't then there is your problem, put some washers between the CAS and the CAS bracket and it won't do it anymore. (but it might already be stuffed)
