Nissan_Boy
Specifications for R32, R33, R34
Specs for R32GTST
Dimentions
Length 4580 mm
Width 1695 mm
Height 1340 mm
Wheelbase 2615 mm
Turning Circle 5.2 m
Chassis & Body
Curb Weight 1320 KG
Body Type 4 door sedan or 2 door coupe
Layout Front engine / Rear wheel drive
Wheels 16 x 6.5
Tyres 205/55 R16
Brakes Ventilated: 4 pot front, 2 pot rear, ABS optional
Steering Rack & Pinion speed sensitive (front) HICAS (rear)
Suspention F/R Independent multilink
Engine
Type RB20DET- Inline 6, Twincam, turbo intercoolered
Displacement 1998cc
Compression Ratio 8.5.1
Power 158 KW @ 6400 RPM (115 to 125rwkw)
Torque 263NM @ 3200 RPM
Bore x Stroke 78 x 69.7
Redline 7,500 RPM
Fuel Injection Nissan EGI (ECCS)
Fuel Tank Capacity 60 litres
Gearbox 5 Speed Manual
Performance
0-100 6.5
0-400m 14.8
Specs for R33GTST
Dimentions
Length 4640 mm
Width 1720 mm
Height 1340 mm
Wheelbase 2720 mm
Turning Circle 10.4 m
Chassis & Body
Curb Weight 1360 KG
Wheels 16 x 6.5
Tyres 205/55 R16 or 225/50 R16
Engine
Type RB25DET- Inline 6, Twincam, turbo intercoolered
Displacement 2498
Compression Ratio 9.0.1
Power 187 KW @ 6400 RPM (130 to 140rwkw)
Torque 295NM @ 4800 RPM
Bore x Stroke 86.0 x 71.7
Redline 7,000 RPM
Fuel Tank Capacity 65 litres
Performance
0-100 6.18
0-400m 14.4
Specs for R34GTT
Dimentions
Length 4580 mm
Width 1725 mm
Height 1340 mm
Wheelbase 2665 mm
Turning Circle 10.2 m
Chassis & Body
Curb Weight 1410 Kg
Wheels 17 x 7.5
Tyres 225/45
Engine
Type RB25DET- Inline 6, Twincam, turbo intercoolered NEO
Displacement 2498
Power 206 KW @ 6400 RPM (140 to 150rwkw)
Torque 343NM @ 3200RPM
Redline 7,000 RPM
Performance
0-100 6.2
0-400m 14.3
Cant believe this hasnt been addressed yet!
The Dimensions posted for R32 are only for the Sedan Models, as the Coupe is of different dimensions and the Curb weight is actually the weight of a later model 5 speed manual Coupe.
I have posted the Varying Dimensions and Curb weights with regards to years made and transmissions fitted as well as the information for the GTS-4.
Will post Corrections for R33 and R34 Tomorrow.
Cheers :)
Years:8/89 - 8/91
GTS-T
Coupe Dimensions
4530 - 1695 - 1325
1280kg AT
1260Kg 5MT
GTS-4
Coupe Dimensions
4530 - 1695 - 1345
1400KG AT
1390KG 5MT
Sedan Dimensions
4580 - 1695 - 1360
1430KG AT
1420KG 5MT
Years: 8/91 - 8/93
GTST
Coupe
1340KG AT
1320KG 5MT
Sedan
1360KG AT
1340KG 5MT
GTS-4
Coupe
1460KG AT
1450KG 5MT
Sedan
1480KG AT
1470KG 5MT
For the Factory Turbocharged R33, the correct Model name is GTS25-T and not GTS-T as any GTS Skyline (except for the Australian SVD R31 GTS1 and GTS2) Is a 2.0L Model.
Will post R34 soon
Cheers :)
8/93 1/95
GTS25-T
Coupe Dimensions
4640 - 1720 - 1340
1380Kg 4AT
1360Kg 5MT
1390Kg 5MT (ABS Model)
Sedan Dimensions
4720 - 1720 - 1360
1400Kg 4AT
1390Kg 5AT (Type G Limited)
1380Kg 5MT
1/95 1/96
GTS25-T
Coupe
1390Kg 4AT
1370Kg 5MT
1400Kg 5MT (ABS Model)
Sedan
1410Kg 4AT
1390Kg 5MT
1400Kg 4AT (Type G)
1/96 5/98
GTS25-T
Coupe
1390Kg 4AT
1370Kg 5MT
Sedan
1410Kg 4AT
1390Kg 5MT
