terrykoun
S13 SR20DET Coil Pack Loom Pin Out
Hi friends,
On a S13 redtop sr20det does anyone know what the pin out is for the engine side loom? I.e from the ecu to the coil packs plug? There should be five pins, 1 for each coil and 1 power, just need to know which one is which on a stock loom.
Reason being is I’ve got a micro tech ecu and it’s got a custom loom connected to the stock coil pack which has also been cut up to a custom plug. Now I got a plug and play spitfire coil packs for a redtop SR, so I don’t know which coil should line up to each pin from the spitfire igniter... if I can find out what the stock engine side loom is then I can just make up a loom and plug it in (I’ve got a blank loom ready to go)
For the reason above I’m looking for the pin out (ie looking at it front on left to right, top row then bottom row) rather than colour ID
Cheers guys!
Hey guys, sorry probably my fault for being a bit confusing.
It would be an immense help if someone can post a picture of the engine side loom of an s13 SR showing the wires going into the loom.
thanks
