JayDevil5000 0 Posted August 31, 2018 (edited) 1999 BMW E36 M3 with 97,928km on the clock - Originally a 3.2L Car, now S13 SR20DET Powered! Engine: Nissan S13 SR20DET 2.2L (Rebuild 20k ago) Head – Mild port job and reco Cometic MLS Head Gasket Tomei Rocker Arm Stoppers Other Gaskets – Genuine Nissan and ACL Race Series Gaskets CP Forged Pistons and Chrome Moly Rings Manley Forged Rods with ARP Rod Bolts Darton Sleeves ARP Head Studs ARP Main Studs ACL Race Bearings – Conrod and Mains Gates Racing Adjustable Vernier Cam Gears Custom Alloy Sump – needed to clear the engine x-member Custom Engine Brackets, using standard BMW rubber mounts Gearbox to Diff: Nissan S13 SR20DET 5-Speed Manual Gearbox (Rebuild 25k ago) Nissan S13 SR20DET Flywheel Xtreme Heavy Duty Clutch Original Tailshaft Shortened and modified with SR20DET Yoke Original M3 3.2L 210mm LSD Differential Custom Gearbox Mount Fuel System: Siemens Deka Compact 630cc Top Feed Fuel Injectors Custom Big Alloy Fuel Rail High Flow Fuel Pump Turbosmart Fuel Pressure Regulator ECU / Ignition / Wiring: Haltech Platinum Sport PS2000 ECU Wiring was done professionally, spliced into factory body connector so car could be actually returned back to a stock BMW engine by simply unplugging the custom engine loom and refitting original BMW M3 engine, wiring etc, etc. All electronics work as factory including dash instrumentation. Genuine Nissan S15 Silvia Ignition Coils with built in ignition modules. Adapters were machined up and wired up during the installation. Wideband O2 Sensor and Controller fitted for easy tuning. Haltech Electronic Boost Control with In-Cabin Adjustment Intake / Turbo: Garrett GT2860RS Disco Potato Turbocharger Custom Stainless Header Style Turbo Manifold with Ceramic Coating PWR Alloy Intercooler Custom Carbon Fibre / Alloy Air Box Custom Stainless Steel Mandrel bend and TIG welded Pipework and Silicone Hoses Turbosmart Blow off Valve Cooling: PWR Custom 55mm Alloy Radiator Spal Thermofan Original BMW M3 Oil Cooler Greddy Alloy Adapter Block for Oil Cooler + Fittings & Lines for BMW M3 oil cooler Interior: Standard M3 Black Leather Nissan Gear stick was modified to allow the factory BMW M3 shifter knob to slot on Other Mods/Upgrades: Full Stainless Steel 3” Exhaust, All Metal Stainless Cat, Varex Adjustable Stainless Muffler K-Sport Coil Overs – Adjustable dampers, camber plates and height adjustment Nissan S15 Silvia Alternator, Power Steering Pump, A/C Compressor, Crank Pulley and Belts 18” Staggered BBS Style Wheels Air conditioning has all been plumbed up just needs to be gassed. Around 180kg lighter than the original car due to Aluminum SR20DET and box replacing the hefty Cast iron 6cylinder, heavy exhaust and gearbox. Being originally a genuine 3.2L M3 the car came with the big near bulletproof 210mm LSD Diff which has been retained. Standard M3 brakes have also proven more than adequate. Engine is consuming coolant slowly, not mixing oil and water, not reving over 5,000 RPM. Power Steering leak, looks like coming out of a fitting on the side of the P/S pump. Unregistered, not engineered. History: I bought the car stock and complete, minus the 3.2L M3 engine and gearbox. The previous owner had removed the engine, built it, spending a ton of money on it and fitted it in his race car and lost interest in the road car (this car). A setup like this is ideal for street and/or track days and once properly sorted is expected to make 220Kw+ at the rear wheels. If I could afford to keep the car till I had the time and funds to get it back on the road I would as it’s a wicked car. It starts, runs and drives. Please feel free to ask any questions you have. Price: $27,000 ono Price: $18,500 negotiable Contact: Jay Mobile: 0491 064 484 Location: Bargo, NSW (25 mins South of Campbelltown or 1hr 10mins from Sydney City) Edited September 30, 2018 by JayDevil5000 Share this post Link to post Share on other sites
