drift_dingo
180sx won't crank
Any auto elec's out there want a 'interesting' problem?
Got a 180sx, not starting. Not even trying. Checked all the fuses, and rechecked...new battery, checked that too. 12.56v at the terminal on the starter solenoid. (pulled the motor out and bench tested it 20 mins ago, works fine...) it's doing the whole "turn the key, dash lights die" like it was a dead solenoid.
Still doing it. won't even turn over. I'm at my wits end >>; I've cleaned the battery terminals, checked the earth to the chassis... Could a faulty relay cause this? I'm open to any suggestions...
sounds like dead starter motor
It's got no torque to turn over, drop a winding on the armature
I had the same probs on my pulsar
Change starter over worked good now
Hmmm interesting, so it would still wind over on the bench, as it had no load...makes sense...now to locate a ca18 starter motor...
Pull all the box fuses in the main fuse box too, and check for cracks in the metal fuse loops. They can cause very unusual problems.
