Cootha
S15 Aircon fan control issues
So, my ac fan will only switch on then I set the fan speed to 4 (max speed). The compressor works and you can hear it engage when you click the ac on to fan speed one but there is no air blown out on setting 1-3 only on setting 4 do you get the fan working. The air is cold like it should be but will only blow on the maximum setting? Should i just get another ac control unit and hope this fixes the problem or is it likely thats it more complicated then that?
Fan speed resistor is f**ked, get a new one.
Is that part of the control unit assembly?
Edit, I found it on taarks. I'l buy a new one in and hopefully it works, thanks Protius.
Edited by Cootha
So I though this might be a common issue and that this might help people if there unsure how to replace their own. I couldn't find any photos of its location except this one on taarks ytxubqF.jpg
The fuse is located under the blower motor in the passengers footwell, its held in place by two screws.
This was mine, its in poor condition with obvious corrosion. I checked each pin in the connector with a multimeter to make sure each setting (1-3) works. It seems that the resistor is broken, il ordering a new one and will report if this fixes the problem.
Edited by Cootha
I used to worked on car A/C daily and this sort of problem is VERY common on just about any car :) Hence my original short but sweet post haha
I got my new fan speed resistor and it all works perfectly now :) unfortunately I also had a pretty big frontal collision when someone did an illegal right turn in front of me. So i ended up with a car with great Aircon but no front end haha.
