hYu
Can front R32/33 hubs fit onto S13/180sx spindle?
Hey guys,
I've been searching around many forums and haven't really found a very definitive answer on this specific topic especially since it seems everyone has a different name for each part and it's hard to understand. So I've attached a photo to be more specific. Sorry but I'm still a noob with this kinda stuff, but just want to do the job right first time.
Currently looking at parts to buy to do 5 lug conversion on my S13 (just the front for now), there's a few people selling some R32/33 front axle assemblies including the lines, rotors, callipers, hubs and knuckles... I know from the guide that most of the R32/R33 brakes (rotors and callipers) will fit after putting on S14/15 5 stud hubs, but I'm wondering if the R32/33 wheel hubs themselves would fit onto the S13 knuckle spindles after removing them by taking out the wheel bearing lock nuts.
That way I can just buy the one part without screwing around with S14/15 hubs and LCAs, or getting aftermarket ichiba hubs and the like.
Has anyone ever specifically tried this before?
Edited by hYu
Skyline front hubs are noone's friends.
S13 knuckles only fit S13 hubs. You can buy S13 5 stud conversion hubs, which use the OEM bearings, so easier to replace.
It's pretty easy to just pick up complete S14/S15 front end - LCA, knuckles, hubs, brakes.
Yeah the skyline front hubs have the wheel bearing nut go on from behind to start with and the hub itself is for a wishbone setup not mcferson strut so isn't even close to fitting. Your options are aftermarket spindle from justjap or wherever, or a s15/14 hub,with shims put in the strut mounting holes. Or drilling out your struts a bit. Then swapping the ball joint on the lca with an r32/33 one.
I see, thats a bummer.
Not even S14/15 hubs would fit onto the S13 spindles?
Problem is my car has ABS, it's there so I figured I might as well keep it. I could get those ichiba 5 stud conversion hubs but they don't have the abs rings on them...
I might have to go with the S14/15 front end route after all then. They're not too hard to find if you got the money of course, which I'm lacking a bit.
Cheers, thanks for your input.
