SeaNo180
Waiting for build engine, but I might crank her over 20psi and see what she'll do.
i thought the twin scroll came in .78 vband option i havent been able to find a .83 option for the twin scroll housing..
You can get T3 .78 .82 or 1.06 in twin scroll
ahk must be just the .78 in the v band option then
No u douche!.... twin scroll is for bigger A/R Turbine housings.
You can get all 3 with vband for the dump
That correct, I got mine from GCG turbo.
^^ if i wanted to read advertising i'd watch tv or look in the sponsor section. not the turbo selection thread.
douche.
Make and model:92' 180sx
Size of engine:SR20DET (Redtop)
Modifications to the car:Power FC, 3inch Turbo Back Exhaust, FMIC, HD Clutch
Type of turbo: GT2860R
Trim of turbo:
Rear Exhaust housing:.64
When does vehicle begin boost:2000
When does vehicle reach full boost and what PSI:3500
Does the vehicle have Cams? if so;NO
What brand:
What lift/duration etc:
Max power achieve at what boost:200kw @ 16psi
haha a guy that drives a falcon is calling me a douche :lol: even if you knew very little about twin scroll.. you'd know its not just for bigger a/r housings.. so clearly your post speaks for itself :doh:
Make and model: 180sx
Size of engine: SR20DET
Modifications to the car: FMIC, 3", ebc, 740cc's, z32, cams, camgears, gktech manifold, power fc etc..
Type of turbo: Garrett GT2871R
Trim of turbo: 52
Rear Exhaust housing: 0.64
When does vehicle begin boost: not sure rpm but the big kick is at 3750.
When does vehicle reach full boost and what PSI: 19-20psi@ 4200rpm roughly
Does the vehicle have Cams? Tomei poncam 256 deg
Made 247kw@19-20psi tuned at unigroup.
Make and model: S14a
Modifications to the car: FMIC, 3", AVCr, 740cc's, z32, Unichip, Pump
Type of turbo: Hypergear ATR28G2
Trim of turbo: 52
When does vehicle begin boost: Dont know exactly..about 3200rpm ....it hits bloody hard by 3500.
When does vehicle reach full boost and what PSI: 16psi at 4200rpm
Does the vehicle have Cams? no.
Made 197rwkw on 16psi.
Have wound the boost up to 18psi but dont know what power it is making? Any guesses?
GOt some idle issues ..i thought it was the injectors but i think i need to upgrade to a better ECU.
Make and model - s13
Size of engine - SR20DET
Modifications to Car - Wolf3d V4, 555 injectors, forged internals - eagle rods, wiseco pistons, balanced, etc. All arp bolts, ported and polished head, no exhaust system (literally), Water/methanol injection - (not connected-biggest waste of money ever-lost 20kw), large FMIC 3" with thermo fans, HKS SSQV BOV, pod filter,etc
Type of turbo - GT2860RS (potato)
Ehaust Housing - 64
When does vehicle start boost - approx 2500rpm
When does reach full boost - approx 4000rpm
Does the vehicle have Cams - yes Brian Crower Stage 3 cams 272/272 12.55 lift with spring kit
230rwkw at 18.5psi
Have read elswhere in thread someone pulling almost 270rwkw with same turbo and injectors, is mine not tuned properly or is the other guy playing with himself??
Edited by macca w18
He is pulling himself.....
270rwkw with 555's.....dont think so
270rwkw with a disco...dont think so.....not even with the larger rear.
You're wrong pal. 270rwkw IS possible with a 'disco and 555's. If it was a cold enough day and he has a good Intercooler..... (and a rising-rate FPR).... its totally possible.
Bullshit
Sorry.... i was wrong about the 'disco.
Make and model: Nissan S13 92 k
Size of engine: sr20det redtop
Modifications to the car: fmic,fuel pump,3inch turbo back zorst,hks740cc's, Z32, Dr drift re-map, solid button clutch
Type of turbo: garret 2871r
Trim of turbo: 52trim
Rear Exhaust housing: .64
When does vehicle begin boost: under heavy load 1800-2000ish...
When does vehicle reach full boost and what PSI: heavy load (eg. 5th gear)3500-36005th 15psi. more like 3600-3800 on flat road for 2nd-3rdth gear 15psi.
Does the vehicle have Cams? if so; stock
What brand:
Max power achieve at what boost: 219kw 15-16psi
pretty happy with it still needs more work and boost! but the 2871 is a great turbo if your not after mass power!!
Bullshit
Thank you.
Sorry NOHERO.....but dont comment if ya dont know.
Make and model:1993 180sx
Size of engine:2.0
Modifications to the car:fmic, turbo back exhaust, pod, bleed valve boost controler. Stock ecu, injectors and pump.
Type of turbo: KKR 380
Trim of turbo:48
Rear Exhaust housing:.86
Does the vehicle have Cams? if so;no
What brand:
Max power achieve at what boost:192rwkw 0.9 bar.
192rwkw with stock injectors and fuel pump? that can't be right.
i got the same setup except for a walbro intank pump and make 191kw at same boost. bit laggy tho doesnt hit full boost till 4700.
Make and model: 2002 Nissan S15
Size of engine: 2.0L
Modifications to the car: 3 inch exhaust, FMIC, Bosch 040, Nismo 740cc, Z32 AFM, PowerFC
Type of turbo: HKS GT-RS
Trim of turbo: 52
When does vehicle begin boost: 3000rpm
When does vehicle reach full boost and what PSI: 4000rpm
Does the vehicle have Cams? if so; Yes
What brand: Greddy Easy Cams
What lift/duration etc: 256/264 10.5mm
Max power achieve at what boost:so far 247rwkws @ 15.9 psi
Make and model: 1993 S13 Silvia
Size of engine: SR20DET (Redtop)
Modifications to the car: FMIC, z32 AFM, Walbro, Nismo 555cc Injectors, SS Gkteck Manifold, 3 inch dump to cat, 2 ½ inch catback, Greddy Profec B Spec II, Nistune
Type of turbo: GT2871R
Trim of turbo: 52
When does vehicle begin boost: 2000
When does vehicle reach full boost and what PSI: 3800
Does the vehicle have Cams? Stock
Max power achieve at what boost: 241.1 Kw @18psi tuned at Autotech in Canberra
Edited by the_moose
Make and model: 1992 180SX
Size of engine: SR20DET Redtop standard internals
Modifications to the car: Hybrid B&P 450x300x76 FMIC, KELWAY FMIC custom piping, Z32 AFM, Walbro, Nismo 740cc Injectors, KELWAY steam pipe exh manifold, 3 inch dump to cat, Trust PE2 cat back, Greddy Profec B Spec II, Nistune, HKS springs, HKS cam gears, Tomei RAS
Type of turbo: GT2871R optioned with T28 style comp cover
Trim of turbo: 56
When does vehicle reach full boost and what PSI: 3800 @ 18psi
Does the vehicle have Cams? HKS step 2 264/264 12mm/11.5mm, .
Max power achieve at what boost: 267.5rwkw @ 18psi tuned on E10 100 oct from United servo's
: 275rwkw @ 17psi tuned on E85 when it was available in Adelaide at ENFFUE
Make and model: 97' S14a
Modifications to the car: Nistune, FMIC, Turbo back 3" Zorst, AVCr EBC, Fuel Pump, Injectors, Highflow Cat
Type of turbo: Hypergear ATR28 G2
Trim of turbo:
When does vehicle begin boost: See dyno sheet
What brand:
Max power achieve at what boost:204rwkw @ 14psi
Tuned by Paul at Chasers.
Std AFM maxed out. Will be putting in my Z32 afm shortly and retune with more boost.
How much difference will the Z32 make?
Trim of turbo: 52
Pretty good result. Any idea what the duty cycle of your 555cc injectors were at at max power?
Make and model: 1994 S14 SR20DET
Modifications to the car: 3 inch exhaust, FMIC, walbro, power enterprise 550cc, Z32 AFM, Nisstune, HPI lowmount manifold
Trim of turbo: 52
Does the vehicle have Cams? if so; No
What brand:
210RWKW @ 12psi all make dyno
thats a good result Danzo. Post up ya dyno sheet.
Any internal work?
Trim of turbo: 52
stock cams? wow
Make and model: 180SX
Size of engine: 2L
Modifications to the car: FMIC, Pod, 040 pump, EBC, Turbo back zorst and a sick driver
Type of turbo: T28 Bush bearing
Trim of turbo: stock
Rear Exhaust housing: stock
When does vehicle begin boost: 2000-
When does vehicle reach full boost and what PSI:3,100 13.5
Does the vehicle have Cams? if so; nope
Max power achieve at what boost: 168.5 on 13.5 PSI
Make and model: S13 SR20DET
Size of engine: 2188cc
Crower Billet Conrods
Darton Sleeves
90mm CP pistons
Cometics Headgasket
Cryo-treated factory crank and rocker arms
Naprec heavy duty timing chain
Powerbond Race SFi Harmonic Balancer
Gti-R Oil pump – modified
New Hydraulic Lifters
ARC sump
JUN 272 11.5 Step 2 cams
JUN Valve springs
1mm inlet & .5mm exhaust Pep-pro oversize valves
Tomei Rocker arm stoppers
Trust Cam gears
ARP Head studs
ARP main studs
9.1:1 compression ratio
Relocated power steering pump
HKS Twin Spark ignition amplifier
Remapped ECU
HKS Manifold modified
HKS external wastegate
Z32 AFM
80mm throttle body
Custom CPC single piece plenum
Hybrid Intercooler
HKS dump pipe
Custom front pipe
Decat pipe
Kakimoto 3 inch Cat Back exhaust
Unknown in tank fuel pump
Bosch 044 external fuel pump
Autobahn888 Surge tank
Sard Fuel Pressure Regulator AN#6 fittings
Custom CPC Fuel Rail
Sard 800cc Injectors
Type of turbo: HKS T300
Turbo Trim: .6a/r, 3" inlet, 0.63a/r exhaust housing
When does vehicle begin boost: Low 3's
When does vehicle reach full boost and what PSI: 1.4bar @ low 4's
Does the vehicle have Cams? if so; JUN 272/11.5mm in and ex
Max power achieve at what boost: 285rwkw @ 1.4 bar on 98. Has a boost leak at the injectors, hence the rich AFR's. Will re-tune once it's sorted to gain some more response
All I can say is "fully sick" nice to see someone go to town on a car.
