SeaNo180
Make and model:1999 s15
Size of engine:2L
Modifications to the car:,740cc inj,bosch 044,800 fpr,FMIC,stock manny,boost controller, power fc, cam sprokets set at 0,pistons, conrods,acl bearings,stock crank, rocker arm stoppers,mainstuds, headstuds,1.2mm MHG,
Type of turbo: gt3071
Trim of turbo: have to look up
Rear Exhaust housing: have to look up
When does vehicle begin boost: 2500ish
When does vehicle reach full boost and what PSI:4000ish 17psi
Does the vehicle have Cams? if so;yes
What brand:hks 264 step 2
What lift/duration etc: 11 in/out
Max power achieve at what boost:229kw @ 17psi,1.5bar, 648nm torque, going in for power tune thursday, will edit when i get figures back
Make and model:93' 180sx
Size of engine:2L SR20
Modifications to the car: SRNRG engine
Type of turbo: GT2860RS
Trim of turbo:
Rear Exhaust housing: .86
When does vehicle reach full boost and what PSI: around 4000 and 19psi
Does the vehicle have Cams? if so; Greddy EZ
Max power achieve at what boost: 263rwkw @ 19psi
Trim of turbo:
Am I reading this right....your making 263rwks from a disco potato....what fuel?
Trim of turbo:
BP Ultimate :D lol
Nah this is bullshit.... i wanna see the torque curve!
1/4 mile numbers??
  • Downvote 1
Dunno. Yeah the boost spike i need to manage somehow. I'll let you know how much 550s can take when I put my cams and whay not in.
Martin Donnon says 550's max out at 270rwkw (SR20). So if you're not getting near that, then something is wrong with your setup.
(if u dont know who Martin Donnon is, then you're an absolute Bafoon)
There's no way U could make 270rwkw with a safe AFR with 550's! They'd need HUGE fuel pressure which is dodgy as.
It depends on the turbo and intercooler being used. With a certain combo im guessing its possible to get 270rwkw with 550's.
*For STREET application of course.
Top of the line injectors can take 70psi fuel pressure.
Make and model: S15 Silvia
Size of engine: 2L
Modifications to the car: All bolt ons
Type of turbo: T2871R
Trim of turbo: 52 trim
Rear Exhaust housing: .64 exh
When does vehicle begin boost:2800rpm
When does vehicle reach full boost and what PSI: 4000rpm - 20psi
What brand: Greddy Easy Cams
What lift/duration etc: 256 In, 264 Exh, 10.5mm lift
Max power achieve at what boost: 237.6rwkw
Make and model: 1988 S13 SILVIA
Size of engine: SR20det
Modifications to the car: GT28RS 740s front mount full exhaust remap ss manifold blah blah
Type of turbo: GT2860RS more info here: http://www.nissansilvia.com/forums/index.php?showtopic=393574&st=0&p=5255873&fromsearch=1entry5255873
Trim of turbo: ?
Rear Exhaust housing: 0.86
When does vehicle begin boost: view graph
When does vehicle reach full boost and what PSI: view graph
Does the vehicle have Cams? if so; no, but adjustable gears
What brand: -
What lift/duration etc: -
Max power achieve at what boost: 201rwkw @ 17psi
Make and model: S13 Silvia
Size of engine: 1.8L
Modifications to the car: stock internals, FMIC, Haltech E8...
Type of turbo: ATR28G3
Trim of turbo: ?
When does vehicle reach full boost and what PSI: 4200rpm - 20psi
Does the vehicle have Cams? Yes
What brand: Tomei poncams + camgear
What lift/duration etc: 256 In, 256 Exh, 8.5mm lift
Max power achieve at what boost: 240rwkw
Size of engine: 2L
Modifications to the car: Here and there
Type of turbo: Twinscroll GT3076r
Trim of turbo:
Rear Exhaust housing: .82 AR
When does vehicle reach full boost and what PSI: 4000rpm - 16psi dyno, 3800rpm - 16psi street
What brand: Tomei Pro 260
What lift/duration etc: 260 In, 260 Exh, 12mm lift
Max power achieve at what boost: 234.9rwkw, 388Nm
Picture-1.jpg?t=1256446128
Make and model: S13 SR20DET
Size of engine: 2188cc
Crower Billet Conrods
Darton Sleeves
90mm CP pistons
Cometics Headgasket
Cryo-treated factory crank and rocker arms
Naprec heavy duty timing chain
Powerbond Race SFi Harmonic Balancer
Gti-R Oil pump – modified
New Hydraulic Lifters
ARC sump
JUN 272 11.5 Step 2 cams
JUN Valve springs
1mm inlet & .5mm exhaust Pep-pro oversize valves
Tomei Rocker arm stoppers
Trust Cam gears
ARP Head studs
ARP main studs
9.1:1 compression ratio
Relocated power steering pump
HKS Twin Spark ignition amplifier
Remapped ECU
HKS Manifold modified
HKS external wastegate
Z32 AFM
80mm throttle body
Custom CPC single piece plenum
Hybrid Intercooler
HKS dump pipe
Custom front pipe
Decat pipe
Kakimoto 3 inch Cat Back exhaust
Unknown in tank fuel pump
Bosch 044 external fuel pump
Autobahn888 Surge tank
Sard Fuel Pressure Regulator AN#6 fittings
Custom CPC Fuel Rail
Sard 800cc Injectors
Type of turbo: HKS T300
Turbo Trim: .6a/r, 3" inlet, 0.63a/r exhaust housing
When does vehicle begin boost: Low 3's
When does vehicle reach full boost and what PSI: 1.4bar @ low 4's
Does the vehicle have Cams? if so; JUN 272/11.5mm in and ex
Max power achieve at what boost: 285rwkw @ 1.4 bar on 98. Has a boost leak at the injectors, hence the rich AFR's. Will re-tune once it's sorted to gain some more response
The old hks nuggets can still do a good job. I'd probably have kept mine if it weren't for the cast manifold constantly warping on me and pulling the rear stud out of the head each track day.
Cheers guys, and yeah it looks like the old T300 has some life left in her yet! I was just hoping to test it on the track and see if I was happy with it but as you guys know, no luck with that!
wow wat a parts list on the engine. nice results too
Make and model: ADM S15 200sx
Size of engine: 2L
Modifications to the car: Nistune ECU, Standard internals, Nismo Pump, Nismo 740cc Injectors, Z32 AFM, FMIC
Type of turbo: Trust/Greddy T518z 8cm
Trim of turbo: 48? trim
Rear Exhaust housing: 8cm
When does vehicle begin boost:3000rpm
When does vehicle reach full boost and what PSI: 4500rpm
What brand: Brian Crower step 2 cams, with BC springs and retainers WITH VCT
What lift/duration etc: 264 In, 264 Exh, 12.06mm lift
Max power achieve at what boost: 281rwkw on E85 fuel and 25psi, ~ 260rwkw at 19psi on 98 octane fuel
Aren't BC cams 264's not 260's ?
Eye like a hawk! lol
all fixed up ;)
all fixed up ;)
I don't miss a trick...Lol.
Make and model: s14
Size of engine: Sr20
35,000km s15 motor
3 inch turbo back exhaust with xforce cat
front mount
gt2871 .86 rear 3 inch inlet
Custom intake pipe
z32 afm
810cc injectors
walbro fuel pump
greddy profec b boost controller
cushion button exedy clutch (struggling with the power lol)
Type of turbo: GT2871r 3 inch front
Trim of turbo: will get back to you
Rear Exhaust housing:.86
When does vehicle begin boost: Update soon
When does vehicle reach full boost and what PSI: Update soon.
Does the vehicle have Cams? if so; No
What brand:
Max power achieve at what boost 250.8kw at 20 psi
Will update post soon with more details. Just got home from Dr Drift (5 hours away) and am stoked with the power.
Didnt expect to make 250kw without cams.
Shane
Size of engine: 2L
Trim of turbo:
...WTF??? is that piss weak for that setup or is it just me??
yea i agree^^ :o
i reckon boost is too low, crank 22psi in it and see what it does :thumb:
Make and model: s15 ADM spec s
75,000km
NISTUNE
front mount ARC turnflow
stock turbo
stock injectors
Nismo fuel pump
HKS EVC-s EBC
Nismo single coppermix clutch
pod filter
Max power achieve 179.9kw at 12.5 psi (set at 14psi but settles at 12.5psi)
Make and model: '99 S15 JDM
Size of engine: SR20DETT
Modifications to the car: intercooler, full exhaust, airbox, boost controller, nistune
Type of turbo: Factory T28
Trim of turbo: Factory
Rear Exhaust housing: Factory
When does vehicle begin boost: 1800
When does vehicle reach full boost and what PSI: 4000 @ 15psi
Does the vehicle have Cams? if so: None yet...
What brand: n/a
What lift/duration etc: n/a
Max power achieve at what boost:202.2kw @ 15 psi. (Boost hits 16psi but settles to 15psi)
sr20dett? how small are those turbos?
typo
ST4AINS: is that holding 15psi to redline ?
dont know how it is doing that if its a stock t28
