SeaNo180
Make and model: Nissan Silvia S13
Size of engine: CA18DET, 1.8L
Modifications to the car: 1mm oversize forged pistons, stainless manifold, full 3inch exhaust, kn pod filter, RB20 throttle body, butterflies removed from inlet manifold, 650x250x90mm bar and plate hyperflow intercooler, Remapped ECU - TUNED BY DR DRIFT, Bosch 040 Fuel pump, GTR injectors, Z32 AFM
Type of turbo: GT28RS
Trim of turbo: ??
Rear Exhaust housing: 0.64
When does vehicle begin boost: 2000rpm
When does vehicle reach full boost and what PSI: 3500rpm, 22psi
Does the vehicle have Cams? if so; CA16DE inlet cam, Stock exhaust cam, Growly Adjustable cam gears
What brand: Stock Nissan
What lift/duration etc: 248/8.5mm lift
Max power achieve at what boost: 244rwkw @ 21psi
Make and model: nissan silvia s13
Size of engine:SR20DET
Modifications to the car: 3 inch exhaust gutted cat, FMIC, hks panel filter in standard air box,turbo smart boost contoller
Type of turbo: ATP turbo
Trim of turbo:unknown
Rear Exhaust housing unknown
When does vehicle begin boost:3,00rpm (ish)
When does vehicle reach full boost and what PSI:approx 4,200rpm, 15psi
Does the vehicle have Cams? no non turbo cams very soon to bring the lag down a tiny bit
power 200rwkw maybe doin injectors and microtech than hittin the dyno
Youre dreaming mate...stock S13 ECU and Injectors? More like 160rwkw...................
Make and model: e30 320i
Size of engine: 2.0
Modifications to the car: sr20det conversion, lsd, front mount, gt28rs, microtech lt10, 550 injectors, walbro pump
Type of turbo: gt28rs
Trim of turbo: nfi
Rear Exhaust housing: .64
When does vehicle reach full boost and what PSI: 3250 16psi
Does the vehicle have Cams? if so; yes
What brand: camtech drop in camshaft
Max power achieve at what boost: 195rwkw @ 16psi
Make and model:2002 s15 spec r gt adm
Size of engine:2L
Modifications to the car:axexi pfc, avcr, bosch fuel pump, hks 740cc injects, trust exhaust , trust cooler, z32 afm
Type of turbo: 2871r
Trim of turbo:56t
Rear Exhaust housing:0.64
When does vehicle begin boost:2100rpm
When does vehicle reach full boost and what PSI:3800rpm spike to 18.5 settle at a constant 17.7/5psi
What brand:Tomei Pon Cams
What lift/duration etc:11.5 256dur
Max power achieve at what boost:244.0 @ 17.7 psi
few areas need attention just to help smooth out the graph a lil, will be goin for a 2nd run next week to see if there was a change
Make and model:S13 Silvia
Size of engine:1.8 ca18det
Modifications to the car: 3" turbo back, gtr front mount
Type of turbo: t25
Trim of turbo: .64 i think
When does vehicle begin boost: early
What brand:
Max power achieve at what boost:130.9 @ 10psi
car is stock apart from front mount + exhuast at Morpowa's new dyno
just to let you and others know.
i have two mates s13 redtop SR's making 200rwkw with just T28's standard injecs/standard AFM.
tuned by morpowa.
Just to let you know, the stock S13 injectors will not make 200rwkw.
lol. they are stock injectors. what more can i say.
one makes 196rwkw and the other makes 201rwkw.
so yeh the stock injectors do make 200. thanks
They must be the 2 missing Magic S13s ive heard about...you sure that aint rwph?...Bit more realistic.....considering no one else seems to be making that power on STOCK S13 injectors and T28s...on reptops..............my previous car included where the stock S13 injectors were maxed at 170rwkw?.....
Make and model:98 S14a
Size of engine: sr20det
Modifications to the car:full zorst, fmic, fuel pump, ECU, AVCR
Type of turbo: stock non BB T28
Trim of turbo:
When does vehicle begin boost:2500k
When does vehicle reach full boost and what PSI:3500k @ 13psi
Does the vehicle have Cams? if so; No
What brand:
Max power achieve at what boost: 186rwkw 13psi
Make and model: 99 S15 Silvia
Size of engine: SR20DET
Modifications to the car: Predator Motorsports Radiator/Intercooler Kit, Microtech LT10s, HKS 550cc Injectors, Sard Regulator, Bosch Intank Pump, Custom 3in dump and 3 inch exhaust, xforce low mount manifold.
Type of turbo: GT2876R
Trim of turbo: No idea
Rear Exhaust housing: 0.86
When does vehicle begin boost: Unsure, maybe 3000?
When does vehicle reach full boost and what PSI: Again unsure, maybe like 5000? 21psi.
Does the vehicle have Cams?; No.
What brand: N/A
What lift/duration etc: N/A
Max power achieve at what boost: 352.4HP/262.7KW at 21psi.
^^^ whats your injector duty cycle at man, thats big power for the size of Inj, and big boost spike as well!
110%+!....Haha...considering 550s will flow around 100hp each.....
Dunno. Yeah the boost spike i need to manage somehow. I'll let you know how much 550s can take when I put my cams and whay not in.
Make and model: S14a 200sx
Size of engine: 2L
Modifications to the car: 3" full exhaust, FMIC, GT2871R, 040 pump, gizzmo IBC, Gktech manifold
Type of turbo: GT2871R
Trim of turbo:
When does vehicle reach full boost and what PSI: 4000rpm
Does the vehicle have Cams? if so; stock
What brand:
Max power achieve at what boost: 188.7rwkw @ 10psi
Make and model: 91 SIL80
Size of engine: 2L
Modifications to the car: 3" full exhaust, FMIC, hypergear atr28g1, 040 pump, turbo tech boost controler, 480cc jdm s15 injectors
Type of turbo: Hypergear atr28g1
Trim of turbo:
When does vehicle begin boost: 60kph??? not sure on rpm
When does vehicle reach full boost and what PSI: 100kph.... spikes to 17 then sits at 15 psi
What brand:
Max power achieve at what boost: 178kw atw at 15psi........ on a dr.drift base tune. fine tuning to come. was running mega richcammo_dyno_run_001.JPG
Thats a really good result mate, same as my setup once its done...didnt wanna wind anymore boost into it? Did you use the stock valve springs with those cams?
Make and model: Nissan S15 200sx
Size of engine: 2.0L
Modifications to the car: Lots, all the pieces to make it run right :)
Trim of turbo: .64
When does vehicle begin boost: 2200
When does vehicle reach full boost and what PSI: 4700
Does the vehicle have Cams? if so: Yes 2x 256's, Both cam gears.
What brand: Tomei
What lift/duration etc: 256, 11.5
232.1atw at 12 PSI, 272.4atw at 18psi
Edited by JPZ200
yeh VCT snapped on me, got the both adjustables there. But its like a creepy climb gets to about 9-10pounds and then the the rest comes in at around 4300-4700
Plus car is starting to ping, when I use 18 pound and then drop down to 15 pounds, so taking it to Belgarage, since CRD do not road tune/test cars after a dyno tune. I think its the airtemp thats wrong and timing going near 42 degrees.
Make and model: S15 2000 Spec R
Size of engine: 2L
Modifications to the car: FPC D-jetro, Greddy Plenum, Hypertune Throttle Body, Sard 800cc injectors, big fuel lines, Splitfire Ignition, Walbro intake pump and two external 044 bosch pumps, 6 boost manifold, CP pistons, Eagle H rods...think thats about it...
Type of turbo: garrett GT3076R
Trim of turbo: ?
Rear Exhaust housing: ?
When does vehicle reach full boost and what PSI: 4200 @ 25psi on ROO16
What brand: HKS Step 2 + HKS Valve Springs
What lift/duration etc: ?
Max power achieve at what boost: 421.7HP @ 25 psi on ROO16
Paul
Edited by zombie_s15
Make and model: nissan silvia ca18det
Size of engine: 1.8 L
Modifications to the car: 3" zorst turbo back, speedlab remap, fmic, 535cc sard injectors, rb25 afm
Type of turbo: 2871 BB
Trim of turbo: 52 trim
When does vehicle reach full boost and what PSI: 3800-4200 17psi
Does the vehicle have Cams? if so; exhaust cam on inlet side, stock exhaust cam.
What brand: n/a
What lift/duration etc: n/a
Max power achieve at what boost: 235 rwkw 17psi
With cam gears i hope to hit full boost a bit earlier and bring the mid range up fair bit
Edited by useless
Thought I already put my results in here, but apparently it was a different thread.
So here they are:
Make and model: Nissan 180SX
Modifications to the car: Nismo 740CC, Nistune ECU, CAMS, Cam Gears, 3.5" Turboback Exhaust, 6 Boost manifold, 38mm Turbosmart gate, profec b ebc, fmic.
When does vehicle reach full boost and what PSI: 4500 at 22 PSI
Does the vehicle have Cams? if so; 264 11.5 Intake, 272 11.5 Exhaust Cams
What brand: Greddy
What lift/duration etc: 264 11.5 Intake, 272 11.5 Exhaust Cams
Max power achieve at what boost: 358.2RWHP at 22 PSI
http://hardtuned.net/forums/index.php?showtopic=382765'>http://hardtuned.net/forums/index.php?showtopic=382765
Make and model: Nissan S14 SR20DET
POWERTUNE GT3071 T2 .64 internal gated turbo kit
POWERTUNE low mount tune length 4 into 1 merge collector manifold
POWERTUNE Intake Pipe
POWERTUNE Intercooler kit
Braided Earls Turbo oil and water lines
Aeromotive Fuel Pressure Regulator
POWERTUNE 3inch turbo back exhaust system
POWERTUNE Topfeed 1000cc fuel rail kit
Bosch 023 fuel pump
Haltech E8
Type of turbo: GT3071 T2 internal gate
Trim of turbo: 56 trim
Does the vehicle have Cams? if so; STANDARD CAMS
Max power achieve at what boost: 257.6rwkw with 98 OCTANE 277.4rwkw on 24psi with E85
98 octane
E85
Make and model: Nissan Cefiro 1988
Modifications to the car: GTR injectors, BLITZ front mount, Walbro fuel pump, STATUS remap, Z32 AFM, BLITZ exhaust
Type of turbo: HKS 25/35
Trim of turbo: duno
Rear Exhaust housing: duno
Does the vehicle have Cams? STANDARD CAMS
Max power achieve at what boost: 216.8 kw on 17psi, full boost by 3600rpm
Make and model: s15 sr20det unopened engine in s13
Modifications to the car: supporting mods nismo 740's, z32 afm, greddy valve springs, copy sump, jjr exhaust manifold modded to suit 44mm tial, 3 inch exhaust, trust 400x300x100 tube and fin intercooler, 40mm china radiator, trust oil cooler, splitfires, old blitz dsbc, bosch 044 and surge tank, s15 pfc.
Type of turbo: 3071
Trim of turbo: 56T 71mm compressor .5ar housing, 84T 60mm GT30 turbine .63 housing
Rear Exhaust housing: .63 non gated
When does vehicle begin boost: dunno
When does vehicle reach full boost and what PSI: 20psi@3600
Does the vehicle have Cams? if so; yep
What brand: Unigroup spec camtechs,
What lift/duration etc: 255 11.5 in 260 12.0 ex
Max power achieve at what boost: 285rwkw@21psi on ultimate
dyno done on r888 semi's, spark breaking down so bit of a rough curve
Thanks mate,
I was a bit surprised with it myself.
Now i just want to drive the thing! Damn unregistered track nugget...
Awesome stuff Dave! Should be fantastic on the track with a curve like that. I dare say your only issues will be traction with that sort of midrange.
Thought I'd post my former setup for anyone interested:
Make and model: S13 SR20DET
Modifications to the car: Nismo 740's, Z32 afm, Tomei RAS, alloy radiator, oil cooler, Hybrid FMIC, HKS SS Manifold, HKS 40mm External 'gate, 3 inch exhaust with ceramic cat
Type of turbo: HKS T300
Turbo Trim: .6a/r, 3" inlet, 0.63a/r exhaust housing
When does vehicle begin boost: ??
When does vehicle reach full boost and what PSI: 1.4bar @ low 4's
Max power achieve at what boost: 241rwkw @ 1.4 bar on 98. Ignition was breaking down hence the shape of the curve at high rpm
