SeaNo180
Make and model:1996 180sx
Size of engine:2.0 litre
Modifications to the car:cat back exhuast + pod + BOV + boost controller
Type of turbo: stock t25G (i think)
Trim of turbo:stock
Rear Exhaust housing:??
When does vehicle begin boost:2600rpm
When does vehicle reach full boost?4000rpm
and what PSI:16 (then boost seems to drop)
Does the vehicle have Cams? if so; NO
What brand:
What lift/duration etc:
Power = 160rwkw
Make and model:s13 sr20det
Size of engine:2L
Modifications to the car:i/c, fc,nismo 555, exhaust, filter, gtr pump,gktech manifold
Type of turbo: gt2871r
Trim of turbo:52
Rear Exhaust housing:.64
When does vehicle begin boost:dont know
When does vehicle reach full boost and what PSI:3800
Does the vehicle have Cams? if so;easy cams
What brand:greddy
What lift/duration etc:256/264
Max power achieve at what boost:280rwkw 20psi
Edited by whips
Make and model: s13
Size of engine: sr20
Modifications to the car: forged,pfc,800cc inj,z32 etc
Trim of turbo: 56
Rear Exhaust housing: .86
When does vehicle begin boost: 2500rpm
When does vehicle reach full boost and what PSI:3800/4000rpm
Does the vehicle have Cams? yes
What brand: Brian Crower
What lift/duration etc: 264 deg
Max power achieve at what boost: 380hp (283kw) @ 20psi
Tuned by allstar garage
Edited by DR1FT3N
Make and model: 180sx
Size of engine: sr20 - s14 motor
Modifications to the car: pfc, 780cc injectors, z32 afm, aftermarket plenum and exhaust manifold
Type of turbo: gt2860rs
Trim of turbo:
When does vehicle reach full boost and what PSI: 3500 - 18psi
Does the vehicle have Cams? no
What brand:
Max power achieve at what boost: 208 @ 18psi
Make and model: Nissan 180SX
Size of engine: CA18DET
Modifications to the car: Stock engine as far as I know, metal head gasket, FMIC, Exhaust inc. manifold, Fuel Pump
Type of turbo: GT28R "S15 BB"
When does vehicle begin boost: 1750-2000
When does vehicle reach full boost and what PSI: 14psi@ 2500-3000rpm
Does the vehicle have Cams? No
Max power achieve at what boost: 202rwhp/155rwkw at 14psi with a stock Mines ECU Tune
Make and model: 1999 s15
Size of engine: SR20DET
Modifications: Cat back, Apexi intake, Greddy profec B EBC
Type of turbo: Factory T28
Trim of turbo:unsure
Rear Exhaust housing:unsure
When does vehicle begin boost: 2000rpm
When does vehicle reach full boost and what PSI: 4000rpm @ 13psi
Does the vehicle have Cams? if so: no
Max power achieve at what boost: 172.4rwkw @ 13psi
Make and model: Datsun 1200 ute
Size of engine: ca18det
Modifications to the car: pretty much stock apart from individual coils
Type of turbo: t25
Trim of turbo:?
When does vehicle begin boost: 1800rpm
When does vehicle reach full boost and what PSI: 2800-3000rpm and running 14psi
What brand:
Max power achieve at what boost: around 200hp on 14psi
Edited by mr1200
Make and model:s15 SR20det
Size of engine:2.0L
Modifications to the car: Everything
Type of turbo: Garrett T3 3071
Rear Exhaust housing: 0.78 Twin Scroll
When does vehicle begin boost: Who cares!
When does vehicle reach full boost and what PSI: 24 psi at 4000 rpm
Does the vehicle have Cams? if so; Procams 260 Dur/ 12mm lift
What brand:Tomei
Max power achieve at what boost: 388.9 hp (290rwkw) at 22psi
Make and model: 2001 S15 ADM spec
Modifications to the car:FMIC, profec-b, Apexi power FC, Apexi 3" turbo back exhaust, pod
Trim of turbo:
When does vehicle reach full boost and what PSI:when it does
Does the vehicle have Cams? if so; Not Yet :ph34r:
What brand:
Max power achieve at what boost: 190wrkw @ 15psi
NOTE: there is no dyno graph attached! :o the info is exactly the same as what i have stated...is a line on a page really gonna make you feel better about it? :rolleyes:
Edited by slide n boost
Make and model:180sx sr20det
Size of engine:2.0
Modifications to the car: 4' exhaust, fuel pump, apexi safc2, heavy duty clutch, GTR calipers, 19' rims. Highflow turbo.
Type of turbo: gt28
Trim of turbo:-
Rear Exhaust housing:0.86
When does vehicle begin boost: 2400rpm
When does vehicle reach full boost and what PSI: 3250 13psi
Does the vehicle have Cams? On there way.
What brand:
Max power achieve at what boost:220 @12.5
Edited by Fat Looser
Update here...
Same specs as before (2871R 52 trim, .64 exhaust + supporting mods) but with Greddy easy cams (256 intake, 264 exhaust, 10.5mm lift)
I made a before and after graph in case anyone was considering these cams...
I didn't notice any bottom end loss, only now that I look at the graph I can see the trade off, well worth it in terms of how the car feels now.
Modifications to the car: Walbro GSS341HP Pump, Malpassi (aka crap) Rising rate FPR, HKS HiPower Exhaust, RPS Engineering downpipe, Cooling Pro Intercooler, Microtech LT10S.
Type of turbo: S15 ball bearing T28 (stocko!!)
Trim of turbo: stockas
Rear Exhaust housing: .stockas!
When does vehicle reach full boost and what PSI: 18psi@ 4000rpm
Does the vehicle have Cams? if so; Hella no!
What brand: stockos
Max power achieve at what boost: 230rwkw@18psi road tune MOTHERPHEKKASSSS!!!!!.
W00T!!! They said it couldn't be done!!!!!!!!!!
Stock injectors BIATCHES!!!!! lol
BANG! :ph34r:
win for now... FAIL later :(
What brand: stockos
who's dyno did it make 230kw?
Make and model:96 type x 180sx
Size of engine: sr20det
Modifications to the car:full zorst, fmic, fuel pump, split fire coils, light weight pulley kit , greddy profec b spec 2 , rb25 afm
Type of turbo: power enterprise pe1420
Trim of turbo:
When does vehicle begin boost:2500k
When does vehicle reach full boost and what PSI:4500k @ 16psi
What brand:
Max power achieve at what boost:197.5rwkw @16psi
What brand: stockos
230....seat of the pants dyno? :P
Size of engine:2L
Trim of turbo:52
What brand:greddy
I have basically the same everything, hope for stats similar with nistune!
280 with 555's? Unlikely
try 850's & Bosch 023.
I said basically bud
mate
you are an idiot! most likely at the flywheel.
anyways here's mine
Make and model: S15 Sr20det
Size of engine:2L
Modifications to the car: 3" inch turbo back, Spec M FMIC, walbro, profect B and remap @ unigroup
Type of turbo: stock t28bb
Trim of turbo:stock
Rear Exhaust housing:.stock
When does vehicle reach full boost and what PSI:3300
Max power achieve at what boost:189.5 @ 15psi
(hits 18psi @ 3500rpm then slowly comes down)
Make and model: Nissan 200SX/Silvia S14A Euro Spec
Modifications to the car: tomei manifold & elbow, greddy downpipe, greddy ti-r catback, greddy spec-r ic, nismo 555cc, 60mm SR20DE N/A throttle body, crower titanium retainers, tomei type a valve springs, hks evc, koyo radiator, flex-a-lite FAL220 fans, nismo coppermix clutch & flywheel, walbro fuel pump, apexi powerfc, apexi air filter intake, Z32 maf, custom 3" air intake.
Type of turbo: GT2860RS (flowported intake/outlet/WG)
Trim of turbo: .60
Rear Exhaust housing: .64
When does vehicle begin boost: not sure
When does vehicle reach full boost and what PSI: not sure
Does the vehicle have Cams? if so; Yes
What brand: Tomei Poncams
What lift/duration etc: IN/EX 256 / 11.5mm lift
Max power achieve at what boost: 249kw/334hp at the hubs @ 16psi / 1.1 bar
Benched using Rototest:
Make and model: Nissan 200SX/Silvia S15 ADM
Modifications to the car: Nistune ECU, 740cc injectors, Z32 AFM, Nismo Pump, FMIC, Enclosed pod with CAI, Standard internals, BC valve springs with Ti Retainers
Type of turbo: Trust T518z
Trim of turbo: .48?
Rear Exhaust housing: 8cm
When does vehicle begin boost: 3000rpm
When does vehicle reach full boost and what PSI: 3700rpm 20psi
What brand: Brian Crower stage 2 cams with VCT
What lift/duration etc: IN/EX 264/ 12.06mm lift
Max power achieve at what boost: 267.4kw/at the hubs @ 17psi (E85) 260rwkw@17psi (98 PULP)
Modifications to the car: GKTECH 3 inch turbo back exhaust, GKTECH FMIC, Pod filter, Turbo tech boost controller
Type of turbo: Garrett T25g
When does vehicle reach full boost and what PSI: 3500rpm 14psi
Max power achieve at what boost: 153rwkw BP PULP. Boost drops down to 10psi, also, running too rich to make more power.
Sorry bout pic quality, off phone.
Make and model: 1996 s14
Modifications to the car: z32, full exhaust, nippon denso pump, pod, hybrid cooler, power fc, 740cc nismo injectors
Type of turbo: hks gtss
Trim of turbo:
When does vehicle begin boost: around 2800
When does vehicle reach full boost and what PSI: 3500-4000
Does the vehicle have Cams? if so; yes
What brand:hks
Max power achieve at what boost: 240rwkw @18psi
reached 256kw on nearly 20psi
Make and model: 1994 S13
Modifications to the car: Overhauled engine, 800cc injectors, FMIC, 3" exhaust, E85
Type of turbo: GT2560R
Trim of turbo:?
Rear Exhaust housing: 0,64
When does vehicle begin boost:2300
When does vehicle reach full boost and what PSI:4000
Does the vehicle have Cams? if so;no
What brand:
Max power achieve at what boost:Peak boost 1,5Bar at 4000Rpm, 1,3 Bar from 4500Rpm, 1,15Bar from 6000Rpm,
352hp at the hubs, 447nm at the hubs
Edited by chovden
Make and model: Datsun 1600
Size of engine:S13 SR20DET
CP 20 thou over pistons. CR approx 9:1
1mm Multi layer stainless headgaskit
Eagle Rods.
ARP bolts everywhere.
Trust RAS.
Splitfire Coil packs.
Windage tray.
Balanced and crack tested Crank.
ACL Race series bearings.
Greedy ( original ) intake with N15 70mm throttle body.
Stainless steel himount Turbo manifold ( made in Thailand )
Nissan S15 Multilayer Exhaust gasket
External Tial 44mm V-band wastegate.
5 bolt to V-band flange then 3 inch dump pipe ( all ceramic coated )
Ceramic Coated Turbine housing.
Sard 550cc injectors.
Durilium clear annodised pully's
GFB modified Crank pully ( front wheel machined off )
300ZX MAF sensor.
HKS bellmouthed Airfilter.
Deceptor Pro BOV.
Carbon Fiber oil Catch Can
Walbro 500 HP Mustang fuel pump modified to mate with Nissan intank fuel filter, cage and cup.
The Intercooler uses S13 endtanks and a 600mm tube and fin core.
Standard S13 5 speed with a Nismo Coppermix singleplate clutch and Nismo flywheel.
3 inch exhaust Jun BL muffler
A PLMS Developments modified ECU and loom utilizing the NIStune software.
Type of turbo: Garrett 2871R
Trim of turbo: 52 Trim
Rear Exhaust housing: 71
Does the vehicle have Cams? if so; Toda racing 264's
What lift/duration etc 10.5 from memory
Max power achieve at what boost: 225 @ 14PSI
^^^ C'mon Paul boost it up already will you :)
Engine : SR20det
Type of turbo: HPI manifold / T28bb
Injectors: nismo 555's
fuel pump: 32 GTR
When does vehicle reach full boost and what PSI: 3000
Does the vehicle have Cams? if so; Tomei poncams
What lift/duration: 256/256 11.5mm lift
Max power achieve at what boost: 199.7rwkw @ 14psi
Make and model: 2001 ADM S15
Modifications to the car: Full 3" Exhaust with Factory Cat, Power FC, 600x300x76 FMIC, Walbro fuel pump, K and N Filter, DE Throttle Body.
Type of turbo: Stock T28
Trim of turbo:
Rear Exhaust housing: Stock 0.64
When does vehicle begin boost: Early
When does vehicle reach full boost and what PSI: Unsure
Does the vehicle have Cams? Stock
What brand:
Max power achieve at what boost:189.8rwkw @ just under 14psi.
1st run was on stock ECU and 11psi approx 150rwkw.
