SeaNo180
Make and model: 92' 180sx
Size of engine: ca18det
Modifications to the car: FMIC, Pod filter, BoV
Type of turbo: T25
Trim of turbo: -
Rear Exhaust housing: -
When does vehicle begin boost: 3,000RPM
When does vehicle reach full boost and what PSI: 9PSI at 4,500
Does the vehicle have Cams? if so;
What brand:
What lift/duration etc:
Max power achieve at what boost: 148rwkw stock boost ( 9PSI )
on stock boost???
:lol::lol::lol:
why 2 different correction factors? what rpm is peak hp? and positive boost at 2000rpm with 270deg cams... are you serious?
right.. so no answers
lol 22 dyno runs over 2 hours and your new designed manifold back in 2005 didnt even glow...
Make and model: 1996 180sx Type X
Size of engine: 2.0L
Modifications to the car: Power FC, Forged Internals, 740cc Injectors, Port and Polished Head, z32 AFM, Predator Radiator and Intercooler Kit
Type of turbo: GT2871R
Trim of turbo: 56
Rear Exhaust housing: .64
When does vehicle begin boost: 2100rpm ish??
When does vehicle reach full boost and what PSI: 4000rpm ish?? ( 17psi )
Does the vehicle have Cams? if so; Tomei 270/270
Max power achieve at what boost: 309.8rwhp ( 240rwkw ish?? ) - 17psi
Make and model: 200sx s14
Size of engine:2l sr20det
Modifications to the car:pod,intake,gt2871r,hybrid cooler,microtech lt10s,bosch023,sard fpr,denzo600cc injectors,splitfire coils, eBoost 2,3inch stainless exhaust and stainless manifold
Type of turbo: GT2871r
Trim of turbo:76
Rear Exhaust housing:.86
When does vehicle begin boost:2500rpm
When does vehicle reach full boost and what PSI:4200rpm at 20psi
Max power achieve at what boost:308.5hp/230kw at the wheels
All tuning done by Justin at Blacktrack Performance (rx Engineering )
BY some mirical im making this power with a 100% standard clutch :o
Edited by elza s14
Make and model: 1994 S14 sr20det in 1989 cefiro
Size of engine: 2.0l
Modifications to the car: Link Computer, trust cams, trust 740cc injectors, evo 5 turbo, intercooler, custom intake piping, 80mm throttle body, standard plenum modified dramatically to suit throttle body, custom steampipe exhaust manifold. Custom dump pipe, custom 3'' exhaust
Type of turbo: Mitsi Evo 5 Turbo. TD05HR 16G6 10.5T
When does vehicle begin boost: 3000RPM, 14PSI@3900, 18psi@4100RPM
Does the vehicle have Cams: Yes
What brand: Trust 256 & 264 @ 11mm lift
Max power achieve at what RPM: 272rwkws on 14psi @7500RPM, 305rwkws on 18psi @7500RPM
Dyno is a Dynapack Chassis Dynomometer hub dyno. It is known to read a little higher than roller dynos bout 10%.
Edited by H-TownDrifter
Make and model:180sx
Size of engine:SR20
Modifications to the car:powerFC, 740cc, Z32afm, bleed valve, all other supporting mods
Type of turbo:gt2871r
Trim of turbo:52trim
Rear Exhaust housing:64ex
When does vehicle begin boost:not sure
When does vehicle reach full boost and what PSI:3800ish 16psi
Does the vehicle have Cams? if so;stock
What brand:
Max power achieve at what boost:217.8rwkw@16psi
I want cams!
Make and model:S15 200sx adm
Size of engine:SR20DET
Modifications to the car:Fmic,pwrfc,fuel pump,exhaust manifold,avcr,740cc`s,3" exhaust...few other bits and pieces
Type of turbo: T60-1
Trim of turbo:
Rear Exhaust housing:.63
When does vehicle begin boost:3600
When does vehicle reach full boost and what PSI:4800 @ 15psi
Does the vehicle have Cams? if so;NO
What brand:NO
What lift/duration etc:NO
Max power achieve at what boost:231.7rwkw @ 15psi
Make and model: S13 silvia
Size of engine:2 ltr
Modifications to the car:ss maniflod, 3inch exhaust turbo back, no mufflers, boost cotroller, cooler, pod, fuel pump, extreme racing flywheel and clutch,
Type of turbo: KKR 380
Trim of turbo:don't no
Rear Exhaust housing:don't no
When does vehicle reach full boost and what PSI:5500
Does the vehicle have Cams? if so; nope
What brand:stock
What lift/duration etc:don't no
Max power achieve at what boost: 260 Kw at 14pis
Make and model: SR20DET 180sx
Size of engine:2 LTR
Modifications to the car: Exhaust, FMIC, Pod, EBC, Z32 AFM, PFC, 700cc Injectors, Built Engine
Type of turbo: Trust TD06H-20G
Trim of turbo: Dunno
Rear Exhaust housing: 10cm
When does vehicle begin boost: 3000rpm
When does vehicle reach full boost and what PSI: roughly 4800rpm at 19psi
Does the vehicle have Cams? Yes
What brand: Toda
What lift/duration etc: 272/272(10.5mm)
Max power achieve at what boost: 357hp(265rwkw) at 19psi
Size of engine:2 ltr sr20
Modifications to the car: gcg mainfold, external, 600inj, fuel pump, reg, rail, microtech, plenum, fmic, s14 gearbox, lsd,lightened flywheel, too much to list
Type of turbo: gt3076
Trim of turbo:0.60
Rear Exhaust housing:0.63
When does vehicle begin boost:2000rpm therebouts
When does vehicle reach full boost and what PSI:4500-5000 hard to tell 21psi
What brand:----
What lift/duration etc:-----
Max power achieve at what boost: 262kw's/351.1hp at 21psi
Size of engine:1.8L CA18det
Modifications to the car: ACL Pistons, 700cc injectors, Tomei cam gears, ported engine head. Fuel pump, Nistune ECU
Type of turbo: HyperGear TR43i with HPVA 38mm External gate
When does vehicle reach full boost and what PSI:4500 18PSI
Does the vehicle have Cams? Regrinded stock cams 256/8.9
Max power achieve at what boost: 292rwKW @ 18PSI / 392.3rwHP / 173KPH / 680NM Torque
Make and model: 95 180sx
Size of engine: SR20DET 2.0L
Modifications to the car: Front Mount,lightened flywheel
Type of turbo: T28
Max power achieve at what boost: 177.17KW @ 14psi
Make and model: S13
Size of engine:SR20DET redtop
Modifications to the car: exhaust, FMIC, pod, microtech, gktech SS manifold, 50mm synapse synchronic external wastegate
Type of turbo: Garrett GT2860RS (disco potato)
Rear Exhaust housing: 0.6
When does vehicle begin boost:2,500rpm (ish)
When does vehicle reach full boost and what PSI:approx 3,000ish 17psi then tapers down to 14psi after 5,000rpm due to wastegate controlling
Does the vehicle have Cams? yes Poncams
Made 226kw on 14psi yesterday with a reeeallly strong midrange compared too
car making 213kw on 16psi with internal gate last month,
will post up dyno sheet after i pick car up today
Edited by DVS JEZ
Make and model: S15
Size of engine: 2.x ltr
Modifications to the car: 3" zorst, pod, trust fmic, bov, bored block with oversized JUN pistons rest stock, vct removed, bikirom, gfb mbc
Type of turbo: T28 bush bearing
Trim of turbo: n/a
Rear Exhaust housing: n/a
When does vehicle begin boost: 2.6
When does vehicle reach full boost and what PSI: 3k 10psi then steady spike at 5k for 12psi till 6800 (weird tune) limiter 9k
What brand:
Max power achieve at what boost: 196kw @ wheels on 12psi
Make and model: 200sx S14a
Modifications to the car: Full exhaust, Trust FMIC, EBC, Cold air intake, S15 injectors, E-manage Blue, pump
Type of turbo: stock S14a ADM turbs
Trim of turbo: n/a
When does vehicle begin boost: 2200rpm
When does vehicle reach full boost and what: 15psi at 3000rpm
Does the vehicle have Cams?: no
Max power achieve at what boost:191rwkw@14.5psi
Make and model: Nissan 180sx
Size of engine: SR20DET 1998cc
Modifications to the car: fmic, straight through 3 inch zorst, cast manifold, 38mm ext gate with screamer, z32 afm, nismo 740cc injectors, power FC, walbro gss341 fuel pump, dual core radiator.
Type of turbo: Hypergear TR43
Trim of turbo: T3
Rear Exhaust housing: 0.64
When does vehicle begin boost: 2500 rpm
When does vehicle reach full boost and what PSI: 3800 rpm
Max power achieve at what boost: 220rwkw@18psi
should reach more with less boost as the tune is shithouse, and ill be relocating the afm to the throttle body side of the cooler piping as there is a bit of turbulence. these turbos are awesome but they are really underestimated.
Make and model: Nissan Skyline
Size of engine: RB25DET
Modifications to the car: Fully built engine with everything you can think of.
Type of turbo: GT3076
Trim of turbo: 56
Rear Exhaust housing: .82
When does vehicle begin boost: 2000rpm
When does vehicle reach full boost and what PSI: 17psi@ 3800rpm
Does the vehicle have Cams? if so; Yes
What brand: Tomei Poncams
What lift/duration etc: 256 8.8mm
Max power achieve at what boost: 293rwkw@17psi 10min safe tune.
Make and model:Nissan ADM Spec S S15
Modifications to the car: 3" Turbo Back / Apexi Power Intake / Apexi Power FC / Greddy Fuel Regulator / Greddy Profspec II EBC / Z32 afm ( with custom SS piping) /Apexi 760cc Injectors (@ 65% capacity) / Apexi BOV / Excedy Clutch (brass)
Type of turbo: Standard T28
Trim of turbo:
Does the vehicle have Cams? if so;no
What brand:
Max power achieve at what boost: 196kw @ 16psi
First run was without the z32 afm (blue) red run was after the AFM & piping install.
(side note : Mick (forgot last name) down the goldcoast did the tune previously and my current mechanic thought he did a good job and the engine has been looked after)
Im sure you guys know who he is down south.
Edited by Demoniak
Make and model: Nissan 180SX
Modifications to the car: Full built engine
Trim of turbo: 52
When does vehicle reach full boost and what PSI: 19-20psi@ 3800rpm
What brand: Brian Crower Stage 2's
What lift/duration etc: 264 12.06mm intake and exhaust
Max power achieve at what boost: 268rwkw@19-20psi 40min quick tune...
Make and model: 1990 180SX, SR20DET Blacktop
Modifications to the car: HKS Type S FMIC, Motec M800, Kazama castor, tierods + ends, traction, camber and toe rods. tomei 86mm pistons and headgasket, ORC 709, blitz 80mm front pipe + Nur Spec RX and 80mm straight pipe..and a bit more :)
Type of turbo: Apexi 53B60
Trim of turbo: not sure :P
Rear Exhaust housing: not sure :P
When does vehicle begin boost: ~1000rpm
When does vehicle reach full boost and what PSI: 5000rpm (1.2Bar)
Does the vehicle have Cams? yes, 256 in/ext
What brand: Tomei
What lift/duration etc: 256, 11.5
^^^Posts without dyno pics are useless.
and post that dont even state how much power
the dyno sheet of my car has been posted many of times , but for the sooks out there ill post it once again
oops...sorry abt it. didnt think it was required. besides its nothing to shout about
well heres my dyno sheet
Edited by C4a0s
Well sorry for not reading your mind.
Make and model: 94 180sx
Size of engine: 2000cc (sr20det)
Modifications to the car: Cat back exhaust, greddy pod filter
Trim of turbo: stock
Rear Exhaust housing: stock
When does vehicle begin boost: dunno
When does vehicle reach full boost and what PSI: 3rd & 4th gear 10psi around 4500
Does the vehicle have Cams? if so; Stock
What brand:
Max power achieve at what boost: stock
So what was this for again??
after having a T60-1 in the car for just over 2yrs i decided to change to a garret gt3076R
this turbo spools in much better and harder,and much better for everyday street.
Make and model:02 ADM S15
Size of engine:1998cc SR20DET
Modifications to the car:FMIC,ZAUST,EBC,ECU
Type of turbo: GT3076R
Trim of turbo:
Rear Exhaust housing:.64
When does vehicle begin boost:3600rpm-ish
When does vehicle reach full boost and what PSI:5000rpm-ish
Does the vehicle have Cams? if so;YES,
What brand:Greddy easy cams
What lift/duration etc:256 in/264 ex 10.5mm
Max power achieve at what boost:348.3rwhp at just under 18psi
please excuse the picture,photo was taken by phone
Make and model: 90 GTiR
Modifications to the car: everything
Type of turbo: HKS 3037s Pro
Trim of turbo:
When does vehicle begin boost:4000
When does vehicle reach full boost and what PSI: 7500 24psi
What brand:Tomei
What lift/duration etc:260 in/260 ex
Max power achieve at what boost: 311 @ all fours - 24 psi
Make and model: MY98 WRX
Modifications to the car: bigger turbo, Hyperflow TMIC, sti injectors, walbro FP, AVO intake, TBE, APS CAI, Power FC.
Type of turbo: TD05big16g
Trim of turbo:
When does vehicle begin boost: 2500rpm
When does vehicle reach full boost and what PSI: 3700rpm ~18psi
Does the vehicle have Cams? if so; stock
What brand:
Max power achieve at what boost: 190kw at all 4's
