SeaNo180
Make and model: 2002 JDM S15
Size of engine: SR20DET
Modifications to the car: HKS FMIC, HKS silent hi-power exhaust and downpipe, HKS mushroom filter, Apexi Power FC D-jetro (convert to MAP sensor), port and polish of head, Walbro Fuel Pump, Nismo 740cc Injectors, Sard fuel regulator, Greddy oil catch, Tomei Rocker Arm Stopper, Cometic head gasket, ARP head stud, Koyo radiator and radiator fan, Exedy Hyper Single clutch and flywheel
Type of turbo: Garrett GT2871R turbo (specs are a .6ar comp housing, 52trim, 51.2mm inducer, .64ar turbine housing. basically the Garrett version of the HKS GTRS)
When does vehicle begin boost: 1500
When does vehicle reach full boost and what PSI: 4000rpm and 19 PSI
Does the vehicle have Cams? Tomei Poncams 256
Max power achieve at what boost: 258 rwkw @ 19 PSI
Make and model: nissan 180sx type x
Size of engine: 2L
Modifications to the car: PowerFC, 3" custom turbo back, pod filter, fmic
Type of turbo: stock T25
Trim of turbo: ????
Rear Exhaust housing: ????
When does vehicle begin boost: 2500ish
When does vehicle reach full boost and what PSI: 3500 (15 psi)
Does the vehicle have Cams? if so;
What brand:
What lift/duration etc:
Max power achieve at what boost: with stock exhaust had 236HP atw on 15 psi
unsure with the turbo back
Car make/model: Nissan silvia
Engine: SR20DET
Turbo: Power Enterprise 1420
Mods: GReddy cooler, turbo back exhaust, fuel pump, 550 injectors, computer, Z32
Starts to spool: 2500RPM
Full boost: 3200RPM
Power achieved: 182rwkw on 15psi
Make and model: 82 KE70 Corolla
Size of engine: SR20DET Retop
Modifications to the car: Z32, PowerFC, 740cc's, 3" exhaust, bleed valve, big fuel setup, 600 x 300 x 76 cooler, Bee-R Limiter :D
Type of turbo: GTRS
Trim of turbo: 56T ?
Rear Exhaust housing: .84
When does vehicle begin boost: Dunno
When does vehicle reach full boost and what PSI: Unsure really~? 3800Rpm 16Psi
Does the vehicle have Cams? if so; Standard
What brand: N/A
What lift/duration etc: N/A
Max power achieve at what boost:232.7KW @ 16Psi
This is a thread for people who are buying a new turbo to be able to see what other guy's are using and what power figures they are making with what mods.
Make and model: Suzuki Vitara/SR20DET
Size of engine: 2.0
Modifications to the car: Manifold, full exhaust, microtech, 800cc injectors, 044 fuel pump, fmic
Type of turbo: Hi-Flowed T28BB
Trim of turbo:?
Rear Exhaust housing:?
When does vehicle reach full boost and what PSI: 3500 / 15psi
Does the vehicle have Cams? if so; No
What brand:
Max power achieve at what boost: 231 Rwhp @ 15psi
Make and model: 1995 180sx
Modifications to the car: Most the usual (no internals)
Type of turbo: KKR-330
Trim of turbo: 56
Rear Exhaust housing: .86
When does vehicle begin boost: 1800
When does vehicle reach full boost: 2800ish
Does the vehicle have Cams? if so; standard
What brand: ROCK
What lift/duration etc: STOCK
Max power achieve at what boost: 209.1kw / 374.6nm @ 0.9 bar
'99 JDM s15 silvia
1998cc
All bolts ons
2871r
52
.64
When does vehicle begin boost: 2500 or so
When does vehicle reach full boost and what PSI: 3700rpm, running 17psi
Does the vehicle have Cams? Stock
Max power achieve at what boost: 224.9 rwkw @ 17psi
Make and model: S15 Silvia
Modifications to the car: Predator front mount kit, K&N filter, turbo XS bov, x-force low mount manifold and 3 inch turbo back system and a turbosmart boost tee thingy.
Type of turbo: Standard BB T28
Trim of turbo: Standard
Rear Exhaust housing: Stanard
When does vehicle begin boost: Never really checked, guess 2500rpm or something
When does vehicle reach full boost and what PSI: unsure but running 17psi
Does the vehicle have Cams: Negative
Max power achieve at what boost: 275.5hp at 17psi which is 205.4kw at 17psi
Is this about right?
Edited by Jay-
Make and model:s14 200sx series one 1996model
Size of engine:1998cc
Modifications to the car:apexi power fc turbo back exausght fmic sr20de throtle body nismo fuel pump nismo injector 740cc oil cooler nismo thermostat hiflow cat pod filter
Type of turbo: garret gt2560r
Trim of turbo:?
When does vehicle begin boost:1900
When does vehicle reach full boost and what PSI:3000ish i guess
Does the vehicle have Cams? if so;yes
What brand:greddy easy cams
What lift/duration etc:256/264
Max power achieve at what boost:218.4kw atw on 13psi unigroup dyno
i dont mean to sound like a cockhead but are you guessing or has the car been dynoed???
Dyno'd on shootout mode
Edited by Jay-
sweet not bad i was reffering to you comment "is this right" you sounded unsure but im guessing you ment the hp-kw conversion ;) gotya
Make and model: 1990 s13
Size of engine: 1998CC (2.0)
Modifications to the car: FMIC, 3-inch exhaust, Forged pistons, rods, bored 20 thou, cometic metal head gasket, acl bearings, haltec E8, fuel system, CAI with pod
Type of turbo: GT2860RS
Trim of turbo: 76
Rear Exhaust housing: 0.86
When does vehicle begin boost: 6psi @ 3500
When does vehicle reach full boost and what PSI: 16 psi @ 4200
Does the vehicle have Cams? tomei poncams & cam gears
What lift/duration etc: 256/256
Max power achieve at what boost: 247rwkw @ 16 psi
http://i119.photobucket.com/albums/o126/de.../keiradyno3.jpg
http://i119.photobucket.com/albums/o126/de.../keiradyno4.jpg
Make and model: S13 SR20DET
Size of engine: 2L
Modifications to the car: fmic, 3in turbo back exhaust, hi flow cat, gt2871r turbo, haltech e8, boost solenoid, pod filter, stainless intake, 550cc injectors, walbro fuel pump.
Type of turbo: gt2871r
Trim of turbo: 52
Rear Exhaust housing: .64
When does vehicle begin boost: bout 2000rpm
When does vehicle reach full boost and what PSI: 4300 rpm 18psi
Does the vehicle have Cams? if so; just stocko's
What brand:
Max power achieve at what boost: 214rwkW at 18psi
Edited by Ash85
Size of engine: 2L
Modifications to the car: Pod filter, Plazmaman FMIC, EMS Stinger, Greddy Profec BII, Sard 700cc injectors, Bosch 070 fuel pump(external), Tomei Adjustable cam gears, Tomei Valve springs, s15 exhaust manifold, 3' turbo back exhaust, de-cat
Type of turbo: Garrett GT2871r
Trim of turbo: 52
When does vehicle reach full boost and what PSI: 3700 rpm 17psi
Does the vehicle have Cams? if so; YES
What brand: Tomei
What lift/duration etc: 12mm lift 260 duration
Max power achieve at what boost: 255rwkW at 17psi
Edited by Duffage
Well done. Poncams?
Make and model: 1994 Nissan 180sx
Size of engine: 2L
Modifications to the car: Blitz IDIII EBC, S15 Injectors, Full exaust (3.5" into twin 2.5" from cat back), FMIC, Walbro fuel pump, Power FC + Z32 airflow meter, Tomei Pro cams, apexi hard intake pipe + Blitz pod
Type of turbo: Jap spec S15 BB garrett
Trim of turbo:?
When does vehicle reach full boost and what PSI: 3400rpm / 18psi
Does the vehicle have Cams?Yes
What brand: Tomei
What lift/duration etc: 260/260 12mm Lift
Max power achieve at what boost: 221.4rwkw @ 18psi
Make and model: 2000 S15
Size of engine: sr20det
Modifications to the car:Tial 38m External Gate with screamer pipe, 850cc injectors, fmic, 040 fuel pump, Power FC, z32 afm, 3" turbo back zorst, pod, bov, Blitz boost controller, Sard Fuel Reg, Exedy 5 puk Brass button, oil catch can,
Type of turbo: GT3071R
Trim of turbo: ?
Rear Exhaust housing: 0.64
When does vehicle begin boost: 2000
When does vehicle reach full boost and what PSI: 4000 @ 20psi
What brand:
Max power achieve at what boost: 263.1rwkw @ 20psi
Max Torque: = 476nm.
Update :)
Make and model: 1990 Nissan 180SX
Size of engine: CA18DET - 1853cc
Modifications to the car: Forged bottom end. Tomei cams. Trust Turbo kit. big injectors etc etc
Type of turbo: TD06H-20G
Trim of turbo: 8cm
Rear Exhaust housing: 8cm
When does vehicle begin boost: 3600
When does vehicle reach full boost and what 4000rpm @ 16psi
Does the vehicle have Cams? Yes
What brand: Tomei Pro Cams
What lift/duration etc: 260x10.25mm
Max power achieve at what boost: 282.6kw@16.9psi
Max Torque: =
Trim of turbo: ?
What brand:
Have you got a dyno sheet of the boost running along the RPM - not that i dont belive you but amazing to see a 3071r reaching full boost by 4000rpm
Its a very hard decision 2871r or the 3071r
Well done. Poncams?
Pretty sure if they are Tomei 260 12mm lift like mine they are pro cams. I think poncams are only 256/256 11.5mm of lift.
Modifications to the car: cam gears, ems stinger 4,bosch 040, nismo 740 injectors, 6boost manifold,greddy profec b spec2, etc etc
Type of turbo: t518z
Trim of turbo: 8cm
When does vehicle reach full boost and what 4000rpm @ 20psi
What brand: hks step 1
What lift/duration etc: 264 10.5mm in & 264 10mm ex
Max power achieve at what boost: 235kw@20psi
Trim of turbo: ?
What brand:
I have the stock manifold, thats why i got full boost by 4k, hahahah
Make and model: 180SX Type X '96
Size of engine: 2L
Modifications to the car: Apexi pod filter, Hybrid FMIC, Blitz SBC-ID3, Stock injectors, Stock fuel pump, Stock ECU, X-Force exhaust manifold, 3" turbo back exhaust, X-Force high-flow cat
Type of turbo: Garrett GT2860RS "Disco"
Trim of turbo: 76
When does vehicle begin boost: 3000-3300 rpm
When does vehicle reach full boost and what PSI: 3700-4000 rpm 14 psi
Does the vehicle have Cams? NO
What brand:
Max power achieve at what boost: 172 rwkW at 13.4 psi
Make and model: 200sx S13 EDM
Size of engine: 1.8L
Modifications to the car: Apexi pod filter, SSA FMIC, Greddy RS bov, 534cc injectors, walbro fuel pump, Nistune, hypergear exhaust manifold, 3" homemade turbo back exhaust
Type of turbo: TR28kai
Trim of turbo: 55
When does vehicle begin boost: 2000-2500 rpm
When does vehicle reach full boost and what PSI: 3500 rpm 17 psi
What brand:
Max power achieve at what boost: +300 crank HP at 17 psi
Make and model:1993 180sx
Size of engine:2.0
Modifications to the car:fmic, turbo back exhaust, pod, bleed valve boost controler. Stock ecu, injectors and pump.
Type of turbo: KKR 380
Trim of turbo:48
Rear Exhaust housing:.86
Does the vehicle have Cams? if so;no
What brand:
Max power achieve at what boost:192rwkw 0.9 bar.
Size of engine:2.0
Trim of turbo:48
What brand:
192rwkw with stock injectors and fuel pump? that can't be right.
I was suprised. Was expecting only 170 or so. Car made 156 with standard turbo @ 1 bar. (Different dyno) Guys at the workshop were suprised too. Happy days though! Other graph on the sheet was car with standard turbo and leaking gasket boosting to only 0.7 bar.
Make and model: S15
Size of engine: 2.0LTR
Modifications to the car: ECU, EBC, FMIC, 3inch full exhaust, fuel pump.
Type of turbo: Stock
When does vehicle begin boost: 2000 rpm
When does vehicle reach full boost and what PSI: 3500 rpm 16 psi
Max power achieve at what boost: 180rwk @ 16psi
MAKE AND MODEL: S13 SIL
SIZE OF ENGINE: 2.0 ltr sr20
MODIFICATIONS TO CAR: built engine, haltech, 850cc, greddy plenum, cam gears
TURBO: GT3082R
REAR HOUSING:0.82
WHEN DOES TURBO BEGIN TO BOOST? 3000rpm
WHEN DOES TURBO HIT FULL BOOST AND WHAT PSI? 4200rpm at 18psi
CAMS? hks step 2, 264 in 272 ex
MAX POWER AT WHAT BOOST? 308kw at 18psi
