SeaNo180
Make and model: Nissan Silvia S14
Size of engine: 1998cc
Modifications to the car: Greddy intake manifold, PFC D-Jetro, 740cc injectors, blitz 2-core intercooler, apexi 1.1mm HG
Type of turbo: TD06SH-25G
Trim of turbo: dunno
Rear Exhaust housing: 10cm
When does vehicle begin boost: ~4000rpm
When does vehicle reach full boost and what PSI: ~4800rpm@1.4bar on the street, ~5200rpm on the dyno
Does the vehicle have Cams? yes
What brand: Tomei
What lift/duration etc: 12mm/260
Max power achieve at what boost: 327rwkw@1.4bar
Make and model:S13 93
Size of engine:SR20 (slight bore increase)
Modifications to the car: Almost everything
Type of turbo: Garrett GT30R
Trim of turbo:52
Rear Exhaust housing:.64
When does vehicle begin boost:3000
When does vehicle reach full boost and what PSI:4100
What brand:JUN
What lift/duration etc: 264/272 11.5
Max power achieve at what boost: 350rwhp 21psi 550nm torque
Make and model: 1991 Nissan 180SX
Size of engine: SR20DET 2.0 litre
Modifications to the car: Greddy spec M front mount cooler, 3" exhaust (high flow cat), Nismo 555cc Injectors, nippo denso fuel pump, Power FC, Z32 AFM with HKS pod and custom stainless 3" intake pipe.
Type of turbo: HKS GT-SS
Rear Exhaust housing: dunno
When does vehicle begin boost: before 3000rpm
When does vehicle reach full boost and what PSI: (not sure - will update)
Does the vehicle have Cams? if so; yes (STOCK)
Max power achieve at what boost: 200rwkw @ 14psi (low boost)...can run 1.1 bar through it but haven't bothered yet
Make and model:HCR32
Size of engine:2.0ltr
Modifications to the car:manifold, gtr fmic, plenum, 90mm t/b 550cc jectors,ss zorst, pfc, z32 afm,
Type of turbo: Garrett3540
Trim of turbo:
When does vehicle reach full boost and what PSI:4400 @ 1.2
What brand:
Max power achieve at what boost: 240rwkw @ 1.2
Make and model: s14a 200sx
Size of engine: sr20det
Modifications to the car: hks 256/264 cams, power fc, exhaust, fmic, ebc, 740cc nismo's, z32afm etc
Type of turbo: gt2871r
Trim of turbo: 56
Rear Exhaust housing:0.64
When does vehicle begin boost:2000-2500rpm
When does vehicle reach full boost and what PSI: 3800 - 4000rpm
What brand: hks
What lift/duration etc: 256/264
Max power achieve at what boost: 335rwhp ~ 251rwkw @ 18psi
Make and model:S13
Size of engine:1.8ltr CA18det
Modifications to the car:manifold, fmic, 263.8.9 Cams, 700cc jectors, 3inch turbo back.
Type of turbo: HyperGears TR44
Rear Exhaust housing:.63
When does vehicle reach full boost and what PSI:5000
What brand: Stock
What lift/duration etc: 263 by 8.9
Max power achieve at what boost: 261KWs @ 22PSI
Video shotout
Make and model:S13
Type of turbo: HyperGears TR43
Rear Exhaust housing:.48
When does vehicle begin boost:2800
When does vehicle reach full boost and what PSI:4600
What brand: Stock
Max power achieve at what boost: 230KWs @ 19PSI
Make and model: S13 Silvia
Size of engine:SR 2.0
Modifications to the car:Tomei 256 Poncams, Tomei Forged pistons, stock crank and rods, Haltech E8
Type of turbo: Trust T88-34D
Trim of turbo:
Rear Exhaust housing: 22cm
When does vehicle begin boost:5000
When does vehicle reach full boost and what PSI:6000 21psi/26psi/29psi
What brand: Tomei
What lift/duration etc:256 Poncams
Max power achieve at what boost: 422hp (314.5kw) / 481hp (360kw) / 519hp (385kw)
Make and model: S13 180SX
Size of engine: CA18DET
Modifications to the car: FMIC, 3" Exhaust, BOV, Pod Filter
Type of turbo: GT2560R
Trim of turbo: 60
Rear Exhaust housing: .64
When does vehicle begin boost: 2500RPM
When does vehicle reach full boost and what PSI: 4000RPM
Does the vehicle have Cams? No
What brand: N/A
What lift/duration etc: N/A
Max power achieve at what boost: 127.9 @ 9psi, 163.7 @ 19psi
Make and model: S15
Size of engine:2.0
Modifications to the car: Everything But ..... Internals
Type of turbo: Trust T518Z
Trim of turbo: 8cm
When does vehicle begin boost:2500
When does vehicle reach full boost and what PSI:4000 21psi
What brand: Tomei Poncams
What lift/duration etc: 256 In&Ex
270Kws@21psi 650Nm@4000rpm
325Kws@21psi 850Nm@4000rpm With NOS
Edited by BPROOF
Make and model: R32 Skyline
Size of engine: RB26/30
Modifications to the car: GTR IC, 580cc Inj, 44mm w/g, 044,microtech, split pulse stainless top mount manifold, 3.5" exh
Type of turbo: T70
Trim of turbo:
Rear Exhaust housing: .86
When does vehicle begin boost: 2000rpm
When does vehicle reach full boost and what PSI: 3000rpm @ 15psi
Does the vehicle have Cams? GTR
What brand: nissan
What lift/duration etc: 8.5mm 255
Max power achieve at what boost: 400rwhp @ 7000rpm 15psi
This has a very broad power range, it is running minimum boost allowed by external wastegate(14.7psi spring)
This is a very reliable combo especially for drift and could easily make 450-470rwhp @ 20psi with boost controller/re-tune.
I guess its not bad for bush bearing! dont believe the hype, they are alot cheaper, do a great job most Trust turbos are bush,
just make sure you get a good tune. I think thats where alot of bad stories come from!
Make and model: 94 S13 180SX
Size of engine: SR20DET 2.0L
Modifications to the car: FMIC, custom plenum,custom steam pipe hi-mount manifold turbo back exhaust, Garret GT3076R ext gate,tial 44mm gate,tomei PROcams,HKS cam gears, sard 850cc,044,rising fpr, avcr, d jetro,
Type of turbo: garret gt3076R
Trim of turbo: 56trim a/r .60
Rear Exhaust housing: .63
When does vehicle begin boost: 1500rpm
When does vehicle reach full boost and what PSI: 4200rpm 26psi
What brand: Tomei procams
What lift/duration etc: 12.5mm 270/270
Max power achieve at what boost: 305rwkw@26psi,
Make and model: 98 S14a 200sx
Modifications to the car: Power FC, Walbro, 550cc Inj, Full 3" Zorst, Cooler piping 2.5", FMIC, pod, catch can, turbotech mbc
Type of turbo: Garrett GT2871R
Trim of turbo: 52Trim A/R 60
When does vehicle begin boost: 1500~rpm
When does vehicle reach full boost and what PSI: 3700~rpm 1.3bar
Does the vehicle have Cams? Yes - HKS Step 1 256º / 264º duration 10.5mm / 10mm lift
240.3rwkw @ 18psi
This thread is for references only, so can people please post up their mods and what power they are making with their aftermarket turbo's. we dont' need any posts with standard turbo's.
There is to be no discussion, this is a reference thread only. if you want to ask any questions please pm the member. any discussion will be deleted.
*THREAD CLEANED*
please read the 1st post made by SeaNo180 it clearly states:
1. we dont' need any posts with standard turbo's
2.There is to be no discussion
Make and model: 1990 onevia
Size of engine: ca18det
GT28rs, 38m External Gate, 720cc injectors, 600x300 fmic, 044 fuel pump, dr drift remap, z32 afm, 3" turbo back zorst, ss manifold, pod filter, forged pistons, O ringed block, balanced & blue printed, race prepped rods & crank, 1.5mm metal head gasket, ported head, bov, turbotech boost controller, malpassi fuel reg, lightened flywheel, exedy clutch,
Type of turbo: gt28rs
Trim of turbo: ? a/r 0.7
Rear Exhaust housing: 0.86
When does vehicle begin boost: 2250
When does vehicle reach full boost and what PSI: 3900 @ 14psi
Does the vehicle have Cams? if so; No
What brand:
Max power achieve at what boost: 171rwkw @ 14psi @ 156 km/ph
Max Torque: = 481N.M @ 124 km/ph
(were not able to tune past 14 psi due to faulty coolant temp and knock sensors)
Have since purchased a custom plenum, xf throttle body, 600x300x100 fmic, valve springs, cams & cams gears, 48mm turbosmart progate, high mount manifold and a t70 turbo.
Make and model: 1990 180SX
Modifications to the car: Everything possible, bottom and top end
Type of turbo: TD06H-20G
Trim of turbo: 20g
Rear Exhaust housing: 8cm
When does vehicle begin boost: 3500
What brand: Tomei
What lift/duration etc: 270x9.25mm
Max power achieve at what boost: 228.3kw@19psi
Max Torque: = 600nm
Turbo has been rebuilt and is now performing well.
Make and model: Nissan 180SX
Size of engine: SR20DET (2 Litre)
Modifications to the car: GT2876R, Tial 44m External Gate, 850cc injectors, front mount, 040 fuel pump, EMS Stinger ECU, tomei rocker stoppers, HKS Cams
Type of turbo: GT25/40R (GT25R, GT2876R)
Trim of turbo: 53mm with 62 trim
When does vehicle begin boost: 3500RPM
When does vehicle reach full boost and what PSI: 4000RPM and at 18PSI.
Does the vehicle have Cams? HKS step 1 264in (10.5mm) 264ex (10mm)
Car made 327RWHP (243kw) @ 18PSI
Make and model: CA18DE+T S13 Silvia
Size of engine: 1.8 lt
Std 1.8 Lt CA18DE
2 mm Tomei Metal Head Gasket
3" 3A Racing Pod Filter
New Z32 AFM
Metal Intake Pipe
Trust TD05-16C
450x300x100 FMIC
80mm Billett Throttle Body
CPC Custom Intake Plenum
Removed Intake Butterfiles with Heavily ported intake manifold
Mild Port on Head Intake
264 degree Unknown Lift In/Ex Cams (big lift)
Tomei Cam Gears
Tomei Valve Springs
Mild Port on Head Exhuast
Trust Low Mount Un-Equal Lenth Header Exhaust Manifold
Hypergear 38mm External gate with 4" Screamer pipe.
2.25 into 3" Custom Dump
3" Decat Pipe
3" Cat Back
50mm GKtech GTR Alloy Radiator
550cc Denso Injectors
Sard FPR
Dr Drift Custom Fuel Rail
Type of turbo: Trust TD05-16C
Trim of turbo:
When does vehicle begin boost: 4psi @ 2200rpm
When does vehicle reach full boost and what PSI: 15 psi @ 3300 rpm
Does the vehicle have Cams? if so; Yes
What brand: ???
What lift/duration etc: ???/264In 264EX
Max power achieve at what boost: 215rwkw @ 16psi
Sam
Make and model: Nissan 180sx 1994
Modifications to the car: aplex boost controller, haltech E8, aplexi exhaust with 3inch cat, fmic, forged piston, hks metal head gasket, custom mainfold and dump pipe , 650cc Sard injectors, bosh 040 fuel pump, z32afm
Type of turbo: GT2871R
Trim of turbo: 56
When does vehicle begin boost:3000-3500rpm
When does vehicle reach full boost and what PSI: about 4500 - 5500rpm not to sure
Does the vehicle have Cams? if so What brand: no cams
What lift/duration etc: dont know
Make and model: R33 GTS-T
Size of engine:RB25
Modifications to the car: FMIC, APexi pod, boost controler, bosh fuel pump, 3in turbo back exhaust
Type of turbo: T3
Trim of turbo:-
Rear Exhaust housing:-
When does vehicle begin boost:1500
When does vehicle reach full boost and what PSI:5900rpm at 11.5psi 0.7bar
Does the vehicle have Cams? if so; no cams
What brand:-
What lift/duration etc:-
Max power achieve at what boost:198rwkw at 11.5psi 0.7bar
Edited by s13_Boostin
Make and model:
Size of engine: 1.8ltr ca18det
Modifications to the car: fmic ,coil pack, fuel pump,breather tank,custome intake pipe
Type of turbo: hks 25/10
Trim of turbo:
When does vehicle begin boost:2500-2800rpm
When does vehicle reach full boost and what PSI:1 bar
What brand:
Max power achieve at what boost: 150kwatw at 13psi
Make and model:180sx rps13
Size of engine:2.0
Modifications to the car: cooler, fuel pump, fpr, 750cc inj, forgied internals, power fc, z32 brakes,
hks AFM, POD, cool air Induction,
Type of turbo: trust (td0?)
Trim of turbo:
When does vehicle begin boost:3900
When does vehicle reach full boost and what PSI:4500
Does the vehicle have Cams? if so;no
What brand:
What lift/duration etc:?
Max power achieve at what boost:290rwhp @ 18psi
[AD95NT] - 180sx
SR20
GT2871R .64ex housing
both std manifolds
begin boost: 3000rpm
full 20psi @4000rpm
NO cams, just turbo, cooler and management
231rwkw @ around 6000rpm
550Nm torque @ 5000rpm (good substitute for cubic inches)
Make and model:Silvia S13
Modifications to the car: q45AFM, front mount, bl/tz 550cc injectors, walbro pump, e-manage tune, turbo back 3''.
Type of turbo: Hi-mount TR43 with Turbonetics ext'wastegate
The vehicle has stock Cams.
Max power achieve at what boost: 200RWKWs @ 1 bar
Make and model:2001 ADM s15
Modifications to the car: Manifold, FMIC, Exahust, Intake etc.
Type of turbo: Stock ADM T28
Trim of turbo: Stock
Rear Exhaust housing: Stock
When does vehicle begin boost: Early
What brand: NA
What lift/duration etc: NA
Max power achieve at what boost: 240 RWHP at 12psi
Make and model: Ford Laser KE Tx3
Size of engine: BPT 1.8 litre (almost 1.9)
Modifications to the car: Forgies, Flowed Head, PLenum, Manifold, Gate, FMIC, Exahust etc.
Type of turbo: GT2876R
Trim of turbo:
When does vehicle begin boost: 2000rpm or less
When does vehicle reach full boost and what PSI: 4000rpm+
What brand:NA
Max power achieve at what boost: 320 FWHP at 24psi
Make and model: 1990 Nissan Pulsar
Modifications to the car: FMIC...Microtech...EBC...550cc injectors...Walbro FP...alot more
Type of turbo: GT2560R/GT28R
Trim of turbo: 60
Rear Exhaust housing: 64
When does vehicle reach full boost and what PSI: 4000....10-16psi
What brand:
Max power achieve at what boost: 124kw @ 10psi.... 153kw @16psi
Modifications to the car: PFC, Injectors, Manifold, FMIC, Exhaust, Intake
Trim of turbo: 52T
Rear Exhaust housing: 0.64
When does vehicle begin boost:2000rpm
When does vehicle reach full boost and what PSI: 3700rpm 16.5psi
Does the vehicle have Cams? if so; HKS step 1 256/264
Max power achieve at what boost: 237rwkw @ 16.5psi
Make and model:95 180sx blacktop non-vct
Size of engine:SR20DET stock bottom end, stock head gasket
Modifications to the car:Hybrid front mount, pfc, fujitsubo legalis exhaust, Nismo 740cc, Z32, GKtech exh mani, HKS cams, blitz spec-r ebc, Apexi hard intake pipe+super funnel kit, Trust 13 row oil cooler, Koyo 53mm alloy radiator.
Type of turbo: Jap S14 T28BB
Trim of turbo: stock
Rear Exhaust housing: stock
When does vehicle reach full boost and what PSI:3400 (15psi)
Does the vehicle have Cams? if so; yep
What brand: Hks step 1
What lift/duration etc: 256IN 10.5mm/264EX 10mm
Max power achieve at what boost: 215rwkw / 288rwhp
Edited by Chunda
haha... finally.
Model: '01 S15 ADM.
Engine: SR20DET, stock internals, stock gaskets.
Mods: fmic, exhaust, injectors, pump, others.
Turbo: Garret GT2871R aka. GTRS.
Trim: 52 trim.
Rear housing: 0.64.
Boost begins: 2000ish.
Full boost and what psi: 3600ish, 1.35bar(19psi).
Cams: no.
Brand: stock.
Type: stock.
Power and what boost: 222.8rwkw on 19psi. maybe about 200now i thinks lol...
bae51c.jpg?t=1189328117\\"\"
Edited by bae51c
Make and model: 1999 nissan silvia
Type of turbo: Blitz k3-450R 6.11
When does vehicle begin boost: 1400
When does vehicle reach full boost and what PSI: 4?00rpm
Edited by silvia_alex
