SeaNo180
Make and model: 1997 180sx type X
Size of engine: 2.0L
Modifications to the car: Nistune, Metal intake, Apexi filter, z32AFM, , Blitz FMIC, Turbosmart BOV (plumbed in), 3" turbo back exhaust w/bellmouth dump, 100 cell highflow cat, Greddy profec OLED, 43mm radiator, 1150cc injectors (top feed), FPR800,
Type of turbo: Garrett GTX2863r .64
When does vehicle begin boost: around 1000rpm
When does vehicle reach full boost and what PSI: 5310RPM, 20PSI (hits 18PSI at 3800, boost control might need some work)
Does the vehicle have Cams? no
What brand:
What lift/duration etc:
Max power achieve at what boost: 221kw @ 20PSI, 6150RPM, 577nm @ 4800RPM
Tuned at MRC, 20deg ambient temp
Edited by Varvs
Hey Varvs, do those 1150cc injectors and top feed rail fit underneath a strut brace? Do you have the nismo engine mounts? Wondering if that will fit for me, looks damn close haha.
Make and model: Nissan 180SX
Size of engine: Redtop SR20DET
Modifications to the car: BC Adjustable Cam Gears, +1mm Enlarged Valves, Ported/Polished Head, Nisstune, Splitfire Coil Packs, 3" Turbo Back Exhaust, Z32 AFM, Front Mount Intercooler, Nismo 740cc Injectors, Walbro 255 Fuel Pump
Type of turbo: Precision 5130
Trim of turbo: 84
Rear Exhaust housing: .64
When does vehicle begin boost: 3800rpm
When does vehicle reach full boost and what PSI: Redline @ 23.5psi
Does the vehicle have Cams? if so;
What brand: Brian Crower
What lift/duration etc: 12.06/264
Max power achieve at what boost: 224kw @ 18psi
OEM mounts, no strut brace. sorry.
Hmm, you reckon it would fit a strut brace on your car? or unlikely?
Make and model: Nissan s15 200sx
Size of engine: 2.0l
Modifications to the car: 6Boost, 740's, Blitz dual EBC, 45mm hyper gate, blitz TBE,
Blitz cooler, haltech platinum pro plugin.
Type of turbo: GTX3076
Rear Exhaust housing: .63
When does vehicle begin boost: around 2000rpm
When does vehicle reach full boost and what PSI: 3800 17.5psi
Does the vehicle have Cams? poncams
What brand: tomei
What lift/duration etc: 256/256 11.5
Max power achieve at what boost: 256atw 17.5psi
Dynoed on a mid 30 degree day
Nice setup man. I'd be interested to see what it makes on 21psi
Yeah man cheers, got re-dynoed with fresh tune and new exhaust as the blitz rear muffler was very restricted, internal diameter wasn't even 2". Don't think just because your buying brand names they always work the best. I changed to a different tuner and made an additional 50kwatw with an additional 3psi, obviously there were other factors that resulted in the overall outcome, but I'm impressed with the results on 98 pump.
Modifications to the car: 6Boost, 740's, Blitz dual EBC, 45mm hyper gate, 3" dump custom stainless TBE, blitz cooler.
When does vehicle begin boost: around 3000rpm
When does vehicle reach full boost and what PSI: 5000 @21.5psi
What brand: tomei
Max power achieve at what boost: 301atw @21.5psi
Edited by Pro16t
Awesome result man, the magic 300kw figure.
The curve looks greatly improved. Mark and Evan yavuz do fantastic tunes there
FYP.. I've seen horrific tunes out of said shop..
Ive had mine tuned 4 times at various stages of my car being developed over the last 7 years. Has been perfect every time.
Awesome result man, the magic 300kw figure. The curve looks greatly improved. Mark and Evan yavuz do fantastic tunes there
+1
Make and model: Nissan S15 ADM
Size of engine: Blacktop sr20det vct
Modifications to the car: Nistune with flex, xforce 3in tbe, fmic, nismo 740cc, walbro 255lph pump, splitfire coils, r35 afm, 3in intake
Type of turbo: IHI VN14 on e75
Trim of turbo:
When does vehicle begin boost: 5psi @ 2000rpm
When does vehicle reach full boost and what PSI: 18psi @ 3400rpm
Does the vehicle have Cams? No
What brand: Stock
Max power achieve at what boost: 233rwkw @ 20psi
Size of engine: 2.0L, non-VCT
Modifications to the car: Usual shit, 7 year old Forced Motorworx motor, Adaptronic with full flex, HKS EVC6
Type of turbo: Garrett GTX3071
Rear Exhaust housing: .83 divided
When does vehicle begin boost: 0.5bar @ 3000rpm
When does vehicle reach full boost and what PSI: 1.85bar @ ~4200rpm
Does the vehicle have Cams? Yes
What brand: Tomei Poncam, Drop-in Cams (did have BC 272 cams, car was a nugget)
What lift/duration etc: 256 / 11.5mm
Max power achieve at what boost: 351kW @ 1.85bar
I have full logs if anyone wants, turbo setup was capable of making more power.. but I stopped dialing in boost because the owner of the car said that's more than enough power.
Make and model: Nissan 180sx
Size of engine: Redtop sr20det non vct
Modifications to the car: Nistune with flex, egay dump and front pipe/decat/custom 3"catback, nismo 740cc, walbro 255 pump, Z32 afm, 3'' intake, blitz fmic, Greddy oled EBC, cams and springs, RAS
Type of turbo: Hypergear ss1.5
Trim of turbo:
Does the vehicle have Cams? yes
What brand: procams
What lift/duration etc: 12/260
Max power achieve at what boost: 226rwkw @ 19psi (98) / 261rwkw @ 21psi (E85)
Tuned by MRC - Turbo had a bit more left in it on E85 but was running out of fuel. Graph below
"]http://s1024.photobu...reh1m.png.html]Screenshot_2016-07-20-18-07-26_zpsahxreh1m.png
Edited by Als
There are other very reputable shops especially one that's speciality are GTR's that absolutely butchered my tune.
I've only heard good things about unigroup, but at the end of the day everyone has an opinion.
My opinion is all workshops are the same they always dick you around
true, then again that's why I do all my own tuning and for all my mates :)
One of those tuna months, once again all SR20s LOL.. must be race wars soon... where's Toretto?
Awesome result on the blue s15. Care to share what mods it has?
Blue S15 has:
  • stock motor
  • stock exhaust manifold, stock ADM turbo
  • stock head, stock cams
  • stock coil packs with plugs at 0.7mm
  • HKS EVC EBC
  • Haltech Platinum Pro & Auxiliary Loom + Intake temp sensor, Flex Fuel sensor, AEM UEGO wideband (hooked up for engine protection)
  • Deatschwerks DW300 (version 1), OEM fuel relief valve deleted and FPCM bypass
  • 740cc Nismo injectors
  • Turbosmart FPR1200 at 3.5bar base
  • Garrett 12psi actuator
  • GReddy off the shelf FMIC
  • XForce turbo back with a shitty XForce cat
Would have been able to make a few more kWs if it didn't have that shitty cat in the car.. I hate XForce cats.
18psi but it bleeds down to about 12psi up top.
Turbo is completely out of puff.
Low gap so no misfires as it's on stock coils. More of a precaution :)
Once the 180 is retuned, that is definitely the setup the s15 will get
Make and model: Nissan S14A
Size of engine: 2.0
Modifications to the car: Nistune, Five 0 1200cc injectors, walbro 460 E85 pump, Sard FPR, Z32 afm, 3'' intake, Greddy FMIC, Greddy profec B spec II EBC, ss manifold, tomei dump, tomei poncams, RAS, 3 inch exhaust with HKS hipower cannon
Type of turbo: VN14
Trim of turbo:
Rear Exhaust housing: not sure of spec
When does vehicle begin boost: low 2K
When does vehicle reach full boost and what PSI: around 3.5K
What brand: poncams
What lift/duration etc: 11.5/256
Max power achieve at what boost: 225rwkw @ 20psi on E85
Make and model: 98' S14 series 2 200sx
Size of engine: SR20DET 2045cc (ish... 87mm bore, stock stroke)
Haltech Elite 1500 ecu with Wideband control, Wiring Specialties Loom, Forged bottom end; pistons and h beam rods with ACL bearings, stock balanced crank, ARP main and headstuds, mildly ported head with titanium retainers, thick springs etc, 455lph auxiliary pump with surge tank, Bosch 2kcc injectors in Mazworx rail. Flex fuel setup. Sinco Customs custom split pulse, twin gate high mount manifold. 2 Turbosmart Hypergate 40mm gates. All the supporting mods like exhaust, front mount, radiator, custom PWR oil cooler setup, genuine Greddy Oil Pan, etc etc...
Type of turbo: Garret GTX2971r 90 trim with the trimmed down "T2" 56.5mm turbine wheel. (Yes, 29-71r, that's not a typo...)
Trim of turbo: 90 trim
Rear Exhaust housing: ATP Turbo T3 twin scroll in .82 AR
When does vehicle begin boost: 2500 ish upwards
When does vehicle reach full boost and what PSI: 14psi @ 4200
Does the vehicle have Cams?: Yup!
What brand: Tomei
What lift/duration etc: 260/260 12mm lift
Max power achieve at what boost: 288rwkw @ 17PSI on 98 octane.
It's been turned down to 14 for the first few oil changes...
It's yet to have its flex tune, but I'm expecting good things on full E85 and 24psi.
How do I share a pic of the dyno sheet? Posting with my IPhone.
Another S15 I tuned over the weekend :)
Make and model: S15 Silvia
Size of engine: 2.0L, SR20DET VCT
Modifications to the car: Stock Motor, ARP Studs
Type of turbo: GTX2867 0.64
When does vehicle reach full boost and what PSI: 4500rpm @ 1.6bar (VCT is fucked)
Does the vehicle have Cams? Tomei 256 Poncams
What lift/duration etc: Supertech Springs
Max power achieve At what boost: 272kW @ 1.6bar, tapering down to 1.5bar (weak actuator)
Tuner: Johnny from trak-life.com
what fuel?
nvm e85
Edited by CraZeeE
Modifications to the car: Stock (Cams/Valves/HG/Studs) + Nistune Feature Pack, Zeitronix ECA 2, FPR1200, Nismo 740cc, Wallah Bro 255, R35 AFM, 3" TBE
Type of turbo: Stock
When does vehicle reach full boost and what PSI: 3300rpm 1.3bar
Does the vehicle have Cams? Stock
What lift/duration etc: Stock
Max power achieve At what boost: 215kW @ 1.3bar, bleeds down to 1bar up top thus won't make anymore power.
Notes: Full Flex tune, runs any fuel. Car fries tyres hard due to the massive surge in torque!
Another one!
Make and model: 180SX Type-X
Size of engine: 2.0L, SR20DET Blacktop
Modifications to the car: Stock (Cams/Valves/HG/Studs) + Nistune Feature Pack, Nismo 555cc, Wallah Bro 255, Z32 AFM
Type of turbo: GT2860R 0.64 on Linglong stainless manifold which I believe is attributing to lag
When does vehicle reach full boost and what PSI: 4100rpm for 1bar a bit more for 1.3bar (lazy 7psi gate)
Max power achieve At what boost: 209kW @ 1.3bar, bleeds down to 1bar up top thus won't make anymore power.
Notes: Good fun, made it super rich and low with timing because it's a drift pig
20258451_1773231039372684_301612435515429653_n.jpg?oh=c8d2475783550e3d855ff5aaff42a288&oe=59FB36FA
Make and model: 180SX TYPE X.
Size of engine: SR20DET Blacktop.
Modifications to the car: ARC FMIC, Nismo 740cc Injectors, Apexi Power FC, Nismo Fuel pump, Splitfire coilpacks, Apexi super suction kit, Tomei dump pipe, Sard FPR.
Type of turbo: Garret GTX 2867R Gen II Internally gated with GCG 19PSI actuator.
Rear Exhaust housing: 0.64
When does vehicle begin boost: 2800rpm
When does vehicle reach full boost and what PSI: 4400rpm @ 19PSI
Max power achieve at what boost: 230kw atw/310.1bhp @ 6165rpm
Tuner: Micks Motorsports
Notes: Makes 293ftlb of torque @ 4829rpm.
Finally someone who has installed a gen 2 gtx.
What's the response like mate? How does it drive? Could you post up the dyno? I would be keen to see.
I might consider this turbo on e85 because you could probably crack 260rwkw without even having to install cams or springs saving a hell of a lot of time and money.
Edited by s15rocket
