Reccomended fuel pressure for SR20DET? - Hardtuned.net
12 replies to this topic
#1 Chappy
  • Car:2009 V36 370GT Sedan
Posted 11 May 2005 - 04:11 PM
i just baught a new Sard fuel pressure reg, and i was wondering if anybody here would know what pressure i would need to set it to? or how i can find out?
SR20DET 180sx 1992 model
#2 DumHed
  • Car:Silvia
Posted 11 May 2005 - 04:38 PM
with the vacuum line disconnected, 43psi
With it connected and the engine idling, 36psi
Or you could put the stock reg back on, which will give you the right pressure all by itself :)
#3 Chappy
Posted 11 May 2005 - 04:41 PM
stock reg is buggered, hence the changing of the reg
and isnt the vaccum line needed to make sure it adjusts the pressure according to boost?
#4 TasBoost
Posted 11 May 2005 - 05:33 PM
What sort of gague are you guys using to measue the fuel pressure?
The reason I ask is I am currently after a fuel pressure gague that I can put inline with my fuel line and leave it under the bonnet. I dont want some wanky chromed up thing that you mount on your bonnet, just something small and simple.
Any ideas?
Cheers,
Nick
#5 ghost180
Posted 11 May 2005 - 07:29 PM
You can get the small underbonnet fuel press guages from almost any performance workshop that sell malpassi's and efi pumps.
#6 benjf43
  • Car:s13 silvia sr20det
Posted 11 May 2005 - 07:58 PM
34.3 or 2.45 bar psi is stock fuel pressure
http://sr20det.nismo...etreference.pdf
#7 Busky2k
  • Car:S14.5 200SX
Posted 11 May 2005 - 08:55 PM
I'd run it at stock fuel pressures, like DumHed has suggested. benjf43, that information is incorrect when referrencing to the S14/15 workshop manuals.
#8 Chappy
Posted 12 May 2005 - 09:42 AM
is the fuel pressure the same for s14/15 and s13?
#9 Slow33
  • Car:R32
Posted 12 May 2005 - 10:10 AM
Just goes to show, it depends on where you get your info from as to what answer you will get. Just because a web page looks good, doenst mean its telling the truth.
Nissan workshop manual says 2.991kg or 43.4psi and 2.55kg or 36.3psi, it appears DumHed aint so dumb ;)
#10 DumHed
  • Car:Silvia
Posted 12 May 2005 - 02:01 PM
don't worry, I won't post values unless I've checked them in the Nissan manual, or in this case, remember them due to setting them on so many peoples' cars!
#11 Chappy
Posted 12 May 2005 - 05:35 PM
aargh! the instructions are in japanese!
i mean, the reg looks pretty straight forward, but i dont want to miss a vital detail :angry:
#12 datzlr
  • Car:Type X
Posted 16 May 2005 - 02:31 PM
ive setted my fuel reg at 38 psi can someone pm me for more info on this
#13 Lindo
Posted 16 May 2005 - 04:32 PM
Depends what power you makin and how much fuel you require...
for mild mods 150-180kw or even a bit more, stock pressure should be fine, once you get near 200 and are pushing the standard injectors to their limits it's a good idea to up the pressure a bit to help them out.
