Interior Parts! - Hardtuned.net
Interior Parts! Brand Catalogue Post
20 replies to this topic
#1 TAARK
Posted 31 May 2011 - 05:52 PM
INTERIOR PARTS
Return to Menu
S13/180sx Steering Column Surround
Description:
Nissan S13/180sx Steering Column Cover.
Includes both upper and lower parts.
Application: All S13's & 180sx's
Price: $90.00
Posted Image Posted Image
S13/180sx Kick Board Clips
Description:
Lost one of these little guys?
These are the little clips that hold the kick panels in place.
Application: S13's & 180sx's
Price: $4.00
S13/180sx Drivers Door Handle
Description:
Have your door handles faded or broken? Grab a new one today.
Price: $45.00
S13/180sx Passenger Door Handle
Description:
Price: $40.00
S13 Gear Boot
Description:
These are BRAND NEW and GENUINE Nissan gear boots for 180sx and S13 models...
Price: $70.00
Genuine Nissan S14 Stereo Bezels
Description:
These are BRAND NEW and GENUINE Nissan plastic stereo bezels for S14 models...
Price: $110.00
Genuine Nissan S14 Gear Boot
Description:
These are BRAND NEW and GENUINE Nissan gear boots for S14 models... Includes the plastic trim too.
Price: $100.00
Nissan DIN Blanking Plate
Description:
Got a hole in your dash that you want filled, these bolt right in and block off any unwanted DIN slots.
Price: $17.00 each
Nissan DIN Pocket
Description:
Got a hole in your dash that you want turned into a pocket, these bolt right into DIN slots.
Price: $30.00 each
S13/180sx Cluster Cover
Description:
Is your cluster cover scratched and cloudy? Then freshen up your dash now! You wont believe the difference…
Price: $55.00
S14/S15 Fan Speed Resistor
Description:
Is your heater/air con only working on one speed? Then this will most likely be your problem…
Price: $30.00
180sx Parcel Shelf Hanger
Description:
Have you broken one of these, parcel shelf has nothing to hang from? Get a new clip now.
Price: $5.00 each
180sx Parcel Shelf Clip
Description:
Have you broken one of these, parcel shelf has nothing to clip into? Get a new clip now.
Price: $3.00 each
#2 99spec R
  • Car:silvia s15
Posted 02 June 2011 - 01:33 AM
You have nismo 740cc injectors for s15?
Thanks
#3 maiky-s15R
  • Car:99 s15 SPEC R
Posted 02 June 2011 - 03:04 PM
WOW thats a great price on the t28...will you have those in stock on a regualr basis??? whats postage cost to sa?
#4 wazza 200sx
  • Car:s14 200sx
Posted 02 June 2011 - 03:09 PM
Hey mate do you have a s14 rear left quarter panel?
#5 Guest_S14S2 BOY_*
Posted 02 June 2011 - 10:51 PM
Hey mate do u have 180sx abs front sensors?
#6 SRS13
Posted 03 June 2011 - 10:39 AM
Do you do a gasket kit? What does it come with, price?
For rebuilding an engine - S13 SR20 Redtop, thanks.
#7 swilly01
  • Car:CA18DET 180sx
Posted 03 June 2011 - 06:09 PM
Do you have any o2 sensors for a CA18DET? If so how much? And how much for postage to melbourne?
Thanks.
#8 MoJizzy
  • Car:Silvia S14A
Posted 03 June 2011 - 06:19 PM
Hey,
In what way is the S15 VCT an upgrade from a series 2 S14 VCT? Sorry, don't know enough about these motors, but I'm learning. Cheers.
#9 NM35
Posted 04 June 2011 - 03:46 PM
Hi
Can i get a price for a factory V35 powerduct part #16555-AM604 delivered to Adelaied 5086.
#10 GetNkD
  • Car:JDM S15 Spec R
Posted 04 June 2011 - 04:16 PM
hey mate do u have the gear boot for the s15 ??
cheers
#11 Toyrismo
  • Car:s13
Posted 07 June 2011 - 01:35 PM
Hey do you have any Thrust washer/shims for R200 VLSD..you know the ones used for shimming the VLSD.. would like to know price if stocked
#12 BenJaman
  • Car:JDM Spec R & FC Rx7
Posted 07 June 2011 - 09:09 PM
Hey mate I am looking to replace the gaskets from the turbo to the frontpipe (plus all the studs, bolts, nuts, spring washers) with genuine Nissan s15 items. What sort of price to get it all posted to Perth? Ben
#13 SrPowerS15
Posted 08 June 2011 - 01:11 AM
wondering if you have spark plug cover?
#14 xxl_05
Posted 10 June 2011 - 02:31 PM
Hey man can u pm me a price on a standard piston ring set for a rb25det r33. Cheers
#15 rezzy_S13
  • Car:SIlvia s13
Posted 14 June 2011 - 01:12 PM
Hi mate can i get 2 door pins and 4 door bushes for s13/180 delivered to NSW 2026?
Also would you have indicator plug for bulbs by any chance?
pm me your details and i'll sort it out asap!
Cheers, Rob
#16 JDs RPS13
  • Car:1993 RPS13
Posted 16 June 2011 - 03:00 PM
hey mate can i get an availability on the nismo engine mount set
#17 napoleon
  • Car:varietta s15
Posted 18 June 2011 - 04:43 PM
good stuff...does anybody know where to buy clips for the roof of a silvia s15 varietta from? or know where parts for this model can be purchased?
i just purchased one of these bad boys last night and the roof has a nasty rattle in it because only 1 clip is fully functional
#18 xris
Posted 03 August 2011 - 07:33 AM
Hi Taark
Can you send me a price delivered on the following parts
- SR Front Main Oil Seal
- SR Rear Main Oil Seal
- SR Injector Isolators
- S14 Rocker Cover Gasket Set
- S14 Water Pump
- SR Gearbox Front Oil Seal
- SR Gearbox Rear Oil Seal
Delivered to Melbourne OZ.
Thanks
Neil
#19 sheepo
Posted 03 August 2011 - 09:05 AM
pm sent
#20 sidewaysmike
  • Car:96 200sx S14
Posted 06 August 2011 - 03:04 PM
Hey taark price on s14 sr20det water pump posted to 4109 cheers
#21 lolzor
  • Car:JDM s15
Posted 28 August 2011 - 06:33 PM
Hey! Could you pls notify me when u guys get a sr20 VCT unit, I'm keen. Thanks!
