Garrett GT2871R Vs Tomei M7960
125 replies to this topic
Poll: Garrett GT2871R Vs Tomei M7960 (157 member(s) have cast votes)
Which Turbo?
You cannot see the results of the poll until you have voted. Please login and cast your vote to see the results of this poll.
Vote Guests cannot vote
#1 AMACHA
  • Car:S15 Silvia JDM
Posted 19 January 2011 - 04:16 PM
Ok So i have narrowed it down to two turbos, which both have good response and produce some great figures in excess of 200rwkw.... Which would you choose?
Garrett GT2871R
Compressor inner diamater: 51.2mm Outer Diamater: 71.00mm 52 Trim A/R 0.60
Turbine wheel diamater 53.9mm Trim 76 and A/R 0.64
Turbo is Dual Ball Bearing water and Oil Cooled boost starts at roughly 2700rpm and is all in by 4000rpm
Turbo + Braided Lines + Gaskets + actuator = 1670.00
Tomei M7960
Compressor inner diamater: 52.6mm Outer Diamater: 68.00mm 60 Trim
Turbine wheel inner diamater 61.00mm Outer Diamater: 54.00mm 78 Trim
Turbo has Journal bearings is water and oil cooled, with maximum boost achieved by 4000rpm
TURBO complete kit = $1660.00
Im in a stalemate guys which do i choose!
#2 JETGTR
Posted 19 January 2011 - 04:40 PM
dude went for a ride in a Spec R with one of these TOMEI M7960 kits, was making 240rwkw on a very, very rich conservative tune and OMFG!!!
Turbo was all ready to go by what looked like 3800-4000 and pulled like a god damn train until redline!!!
Injectors were close to maxing out aswell, hence the lower power level considering what the turbo can flow. A set of 260-264 cams and you'll really start making some serious grunt.
Spun tyres through most of 2rd gear and struggled to keep the car in a straight line in 3rd sometimes.
Everyone has a GT2871 or GTRS...go the tomei. It's ben tried and tested and made by Tomei, you cant go wrong. As for journal bearing, they are just as reliable as a ball bearing turbo, just keep up with the oil changes.
Im putting one of these kits on my S15. In the end both units will perform....im only choosing tomei because i want to break the GT2871 fellowship lol, eventhough the 2871r is a great bit of gear.
#3 AMACHA
Posted 19 January 2011 - 04:45 PM
View PostJETGTR, on 19 January 2011 - 04:40 PM, said:
dude went for a ride in a Spec R with one of these kits, was making 240rwkw on a very, very rich conservative tune and OMFG!!!
Wow thats good news mate...sweet to know sorry you didnt specify you went for a ride in a spec R with the tomei or garrett turbo? i take it the tomei?
cheers for the reply
#4 z0mbieJesus
  • Car:JDM S15
Posted 19 January 2011 - 04:51 PM
Have you gone in a ride with a 2871r? Curious for a hands on comparison cause I just ordered an M7960 over the 2871r from the US, pumped to get it in matched with a set of easy cams.
#5 JETGTR
Posted 19 January 2011 - 04:58 PM
Ahhhh sorry dude, yea, Tomei Arms M7960. he got the kit from hioctanedirect.com.au
#6 JETGTR
Posted 19 January 2011 - 05:02 PM
I have a friend with a GT2871R on his Spec S. Making 230rwkw though. Even though it went pretty damn hard...it was running higher boost than Ricks tomei turbo'd S15....he was running 19-20psi if i remember right and the GT2871R S15 was running 22psi i think..around there anyway. The tomei powered car felt a lot more than 10rwkw quicker...if that makes sense lol?
I reckon the guy said that the 2871R S15's tune was quite aggressive aswell....really should be making more then 230rwkw though!
#7 z0mbieJesus
  • Car:JDM S15
Posted 19 January 2011 - 05:03 PM
Garrett GT2871R
Tomei M7960
If you want a bit more info check out http://www.nissansil...1
East coast customs has fitted a few of them and rates them above 2871r, altho I have read a couple of negative things on other forums, but theres always going to be a dud in the bunch
#8 z0mbieJesus
  • Car:JDM S15
Posted 19 January 2011 - 05:04 PM
Nice thats what i was hoping to hear!!! Makes that $1500 feel better spent! Im pumped
#9 JETGTR
Posted 19 January 2011 - 05:10 PM
^^^ Kinda jealous now dude lol. You'll love it im sure!
#10 z0mbieJesus
  • Car:JDM S15
Posted 19 January 2011 - 05:15 PM
this wait for all my parts from the US is killing me, Ill post up how it goes once its all in and dyno'd so some people can get some details on the tomei gear considering there is next to nill reviews on it
#11 z0mbieJesus
  • Car:JDM S15
Posted 19 January 2011 - 05:17 PM
out of curiosity what if any cams did your mate have with the M7960?
#12 JETGTR
Garrett GT2871R
Tomei M7960
If your serious about the M7960..PM me and i'll put you in contact with a guy called CaBs from nissansportscarclub.org who can get these kits for $1575 delivered +-$25!
He'll be getting mine for me.
#13 AMACHA
Posted 19 January 2011 - 05:28 PM
Garrett GT2871R
Tomei M7960
looks like im going the tomei unit :D what size injectors do you need with this bad boy....and is cams/FPR nessasary?
#14 JETGTR
Posted 19 January 2011 - 05:31 PM
Didn't have any...just standard im pretty sure, didn't ask. Idle was smooth, like no cam lope at all, so im guessing stock.
His tuner mentioned though that cams would really wake the engine up!
#15 JETGTR
Posted 19 January 2011 - 05:34 PM
Garrett GT2871R
Tomei M7960
Good man lol. Standard FPR and rail will be fine as long as your fuel pump is decent. As for injectors and cams, i don't imagine 550's would get you to that power level and if they did i reckon they would be close to maxxed out, not too sure though.
A set of 260-264 cams would be perfect, prob more towards 260's for a streeter and 264's for a track/weekender
#16 z0mbieJesus
  • Car:JDM S15
Posted 19 January 2011 - 05:59 PM
Just buy some 740's, almost same price and safer to go lower duty cycle on larger injectors
#17 z0mbieJesus
  • Car:JDM S15
Posted 19 January 2011 - 06:01 PM
oh and apparently bell mouth dump really helps with these as well
#18 JETGTR
Posted 19 January 2011 - 06:07 PM
Sard 850's are dirt cheap aswell, may be a little overkill though, 740's would be great.
If you have the cash, a Tomei expreme dump pipe would be killer!!!
#19 AMACHA
Posted 19 January 2011 - 06:32 PM
already got a turboback exhaust including that dump pipe mx front pipe and greddy exhaust!
Just chasing around 230rwkw as i dont want to change my clutch from the exeddy heavy duty again!!!!
Dont think im goign to go cams dont have the cash atm....
Just goign to get turbo, injectors and Z32..... so go the 740cc no the 555cc for the 220-230rwkw figure im chasing?
#20 z0mbieJesus
  • Car:JDM S15
Posted 19 January 2011 - 06:35 PM
go the 740's, safer to down tune the larger injectors then lean out smaller ones, and theyre the same price
#21 JETGTR
Posted 19 January 2011 - 06:50 PM
+1
#22 AMACHA
Posted 19 January 2011 - 07:27 PM
sweet boys...thanks for all the help.... any place to get cheap 740cc injectors :D
#23 z0mbieJesus
  • Car:JDM S15
Posted 19 January 2011 - 08:07 PM
look in the US atm, everything is cheap there, 240sx mobs and ebay US is where i find most of my gear, just hafta wait that extra bit for postage (still cheaper with extra postage though)
#24 AMACHA
Posted 19 January 2011 - 08:37 PM
Hey JETGTR what injectors was your mate running?
#25 Shawnhalu
Posted 20 January 2011 - 12:50 AM
yeah i love my tomei m7960, tomei 740inj, 256/256cams and the tomei exhaust dump pipe =D
#26 -Les
Posted 20 January 2011 - 04:42 AM
Sure does!
These are epic turbos, jap vs US? I'll take Jap thanks :P
I'm running the larger model of this, the M8270, cannot complain.
#27 z0mbieJesus
  • Car:JDM S15
Posted 20 January 2011 - 06:47 AM
what power you getting on what cams?
#28 JETGTR
Posted 20 January 2011 - 09:10 AM
Not too sure mate, sorry. Said the tune was quite rich and safe, so in that case obviously the injectors were big enough lol....bigger than 550's i'd say.
I'll find out for you.
#29 z0mbieJesus
  • Car:JDM S15
Posted 20 January 2011 - 09:29 AM
at a guess I reckon 550's would max out at roughly 220-230 rwkw, may be wrong tho
#30 AMACHA
Posted 20 January 2011 - 11:23 AM
I only want to go maximum of 230rwkw as my clutch is rated at 250rwkw that's why I'm thinking of going 555cc hmmm does anyone make 600cc?
