Feint motion AE86 build - Hardtuned.net - Page 2
115 replies to this topic
#31 URAS1
  • Car:s14 s1
Posted 17 February 2010 - 05:42 PM
is that even possible, should be interesting to see no the less :thumbsup:
#32 ToySprinta86
  • Car:Toyota Sprinter
Posted 18 February 2010 - 09:25 PM
Cars going into Carco on Monday.
Looks like i'm gonna have a crossover style individual throttle body setup :D
Dropping the crossmember down a fair bit, good thing is that this will correct me steering geometry due to the RCAs being slightly too big.
Aurion motor has a few factory goodies, like a cartridge type filter in the sump, (easy oil changes :) ) an engine oil heat exchanger, which i'm just gonna re plumb into the oil cooler instead.
#33 cush³
Posted 19 February 2010 - 08:32 AM
Paint it orange and black!!
#34 Guest_Umai Naa!!_*
Posted 19 February 2010 - 09:11 PM
And never come back! :P
Just kidding. Keep us posted about this thing. Looks like it's got some huge potential!
#35 DRF13
  • Car:NSU Ro80
Posted 28 February 2010 - 07:24 AM
I'd have never thought of fitting an Orion motor, but are these the same as they put in Rav4's and pretty much everything else these days? If so they may be designed to fit a wide variety like the VQ series.
#36 ToySprinta86
Posted 28 February 2010 - 08:12 AM
yep, used in:
to name a few :P
#37 DRF13
  • Car:NSU Ro80
Posted 28 February 2010 - 08:16 AM
wholey fark! :lol: thats awesome
#38 ToySprinta86
Posted 28 February 2010 - 08:25 AM
The 2S bellhousing is gonna have to be modified, the dowels line up, but will put the engine or gbox on a 35deg angle :S
New clutch and flywheel :)
Had to slightly elongate the bolt holes to suit the Aurion Crank, but putting in dowels to be safe
#39 DRF13
  • Car:NSU Ro80
Posted 01 March 2010 - 10:01 PM
doesn't look like much meat to elongate bolt holes in, but I'm sure you know what you are doing
I'd love to see a good 3RZ in an 86, but I do think that alloy V6's are the way of the future
#40 ToySprinta86
Posted 03 March 2010 - 02:33 AM
yeah, elongating's a bit iffy, but the dowels should add some extra support...
#41 meat axe
Posted 03 March 2010 - 05:14 AM
looks wicked mate. what gear box are you using? keep us all updated
#42 ToySprinta86
Posted 03 March 2010 - 05:59 AM
I'm using the same W58 that was behind the 4A. should last :P
#43 ToySprinta86
Posted 16 April 2010 - 06:32 AM
Quick update, motor and gearbox are in!
took a bit of fiddling and a few bellhousings but its there.
Ended up using a 2s bellhousing.
may have to have the engine sitting on a slight lean so gear lever isn't coming out the side of the trans tunnel.
#44 !sil80 fan!
  • Car:R32 GTR & toyota cressida
Posted 16 April 2010 - 07:22 AM
awesome dude loving this build.
#45 --Redwork--
  • Car:AE86
Posted 16 April 2010 - 07:32 PM
Bend the gear lever..
#46 ToySprinta86
Posted 08 August 2011 - 04:22 PM
About time I updated this:
Trying to smash this thing together for ADGP, should be a fun couple of weeks :)
Old arms
Attached Image: 228868_10150254983611498_651051497_8120608_2630212_n.jpg
ETS arms :)
Attached Image: 229772_10150254982726498_651051497_8120583_2684061_n.jpg
new brakes! :)
Attached Image: IMG_4094.jpg
Attached Image: IMG_4149.jpg
The "bolt-in" cage
Attached Image: IMG_4068.jpg
modded sump
Gonna smash out the headers this weekend, then off for wiring and tune :)
#47 Biggie
  • Car:96' Type X
Posted 08 August 2011 - 04:35 PM
needs more ITB
#48 ToySprinta86
Posted 08 August 2011 - 04:39 PM
Already have the throttles ready :)
Don't want to push my luck getting it ready for ADGP, but I'll have them on for next year
#49 Biggie
  • Car:96' Type X
Posted 08 August 2011 - 05:00 PM
emo....
ill even lend you a angle grinder to cut a hole in the bonnet.
#50 MeZ
Posted 08 August 2011 - 09:32 PM
Good meeting you Steve, cant wait to see this beast in action!
#51 Strewth01
Posted 08 August 2011 - 09:46 PM
Subscribes* Pumped to see how this all turns out! Good luck.
#52 whiteseries4
  • Car:S4Rx7 s13 r32
Posted 08 August 2011 - 09:47 PM
how does the clutch feel?
have been looking at those brands clutches, any good?
#53 sheepo
Posted 09 August 2011 - 12:33 AM
Omg thats one crazy engine conversion. Hope it all goes well with this build :)
#54 Stinkypoo
Posted 09 August 2011 - 01:02 AM
Hurry up and finish it Steve, especially after bailing from Japan to do this.
Car still needs a bit of work, he'll be pushing it hard to get it ready for ADGP in September.
BTW, is it just me, or do the old arms look better than the new ones????
#55 ToySprinta86
Posted 09 August 2011 - 08:24 AM
lol, thanks for pointing that out Eiji. Can always count on you to find the mistakes :P
Haven't had the car running to see how the clutch feels, but I have out a heavy duty organic in my girlfriend Z32 TT and it's feels fine. Even has a Daikin pressure plate.
Was cool to meet ya Mez, hopefully see ya at ADGP :)
#56 Stilvia
  • Car:S13
Posted 09 August 2011 - 08:32 AM
Looking great... Love new ideas!
#57 country drift
  • Car:SR20 Onevia
Posted 09 August 2011 - 06:45 PM
View Postgrub_ze70, on 14 February 2010 - 05:27 PM, said:
View PostMatt-AE86, on 14 February 2010 - 08:51 AM, said:
Engine Weight? Flywheel? Bellhousing?
we're using a 3sgte flywheel and clutch. im not sure of the weight but and steve i can pick it up without too many problems! going off that, it is close to the weight of a 4AG. we have a few bell housings that are close to fitting. but one of the bigger problems we have come across is the mounting of the starter motor. cause in the camry its mounted on the gear box side so there is no hole on the engine side to put the starter motor through.
there is an off road buggy in aus with a 2GR twin turbo pumping out 600KW at the flywheel on 18psi! when the engine had stock internals they were running it at like 10psi and making around 400kw at the flywheel. im going to make a BIG call here but i think theyre the new 2JZ.
http://www.supraforu...ad.php?t=467852
Peter Kittle's buggy
that thing is intense... he pumps ALOT of cash ino it
#58 ToySprinta86
Posted 10 August 2011 - 08:06 AM
Well, I do have 2 spare GT28RS turbos from the 4A if I get bored with ITBs....
#59 RPS-250
  • Car:89 Silvia
Posted 10 August 2011 - 08:13 AM
Wow! Twin discos on a V6!
#60 ToySprinta86
Posted 23 August 2011 - 08:05 AM
Starting to feel the crunch now!
Its getting there though.
After trying out a few pipe designs, we figured that this layout wouldn't work:
This one would work a little better I think...
Putting theory into practice:
One side done!
Rinse and repeat for the other side! :)
Not too shabby at out first crack at headers in my mates tin shed :)
