Before I start, I'd just like to state I've never been on the track and encountered the tires. I know a lot of people couldn't care less and even use them as a marker to aim for, which is good and provides some interesting viewing (we all love watching the wall at Ebisu being scraped don't we?). But Mallala doesn't have a wall, instead, multiple stacks of 4 bundles of 3 tires.
The tires are apparently placed there in order to save drivers from plowing into the concrete wall, which is roughly a little less then the racetracks width from the edge of the track. However at recent events, accidents involving the tires have cost drivers as they hit the stacks just after a decent scando.
Lets have a look at the most common accident:
The car travels wide after the scando and usually the rear 1/4 collides with a tire stack. Motion of car is represented by the red arrows.
The car has now experienced a force where the impact was made. Due to the fact that the impact was behind the centre of the car, the car is turned in an anti-clockwise direction, as shown by the various arrows below (had it hit directly in the centre, it would continue its path of motion, slower).
The direction of travel is now altered in favor of the tires that caused the change of direction. The car is now 'hooked' in towards the wall/more tires.
If the car has not stopped now, escaping with only damage caused by one or two stacks (hit at 120km/h+), the wall is looking promising.
Recent video footage proves this theory:
Kalby pulls one hell of a scando and goes a little wide, making contact in the rear 1/4. You can imagine the motion of the rear of the car as it swings around.
That motion of the rear is suddenly stopped and the front has to account for this. The front is hooked around.
Despite opposite lock, the car is sent in its anti-clockwise spin out of control, towards the wall.
Contact with the wall is made still at a very high speed. Check out how much the tires absorbed the impact. This is a classic example of Newtons laws (I forgot which one). By the formula F=P/t, the force exherted on an object is directly proportional to the momentum it has (meaning, more momentum, more force), and inversely proportional to the time for the collision to occur (meaning, more time, less force. Less time, more force). The tires slow the collision down, rather then suddenly coming to rest courtesy of the concrete wall. This reduces the force on the car, thus reducing the damage.
Here's the video, thanks to Luke Terbeeke for the footage.
http://www.vimeo.com/7497734
Had the tires not been there, the path of motion would be similar to this:
Rear wheels go into dirt and have less traction. At this point, the drift is either held or the car spins into the huge open area Mallala has at the end of the straight.
The blue arrow represents the resultant movement of the car.
Simon goes wide on the first run in this video and continues to drift seemingly un effected.
http://www.youtube.c...h?v=5MCncGjs5AI
If the tires must be there, a safer arrangement could be adopted.
The first improvement is the chance of hitting the tires. As there is only the width of one tire (as opposed to four above) directly next to the track per bundle, there is less chance of the car colliding if the same number of bundles are used. ie, the distance between trackside tires on average is increased.
The same anti-clockwise rotation will still occur, but now the car is facing a tire stack perpendicular to its direct of travel. Previously, the car may not encounter any tires this close to the wall. There is move change of hitting the tire then hitting the wall.
The car is now face with multiple rows of tire stacks directly in its path of motion.
The car has either slowed down by now due to more collisions with better arranged tires or has sandwiched a tire stack between the car and the wall.
Multiple tire stacks can move freely and easily go under a car, potentially flipping it, as below:
once again Luke Terbeeke with the good.
*I would show stewy going over them but the photos have been removed form photobucket*
A more secure tire wall may be a better option, however it will still hook the car in and if its solid enough, potentially do more damage. To retain the absorbing qualities of a tire wall but reduce the 'hooking' effect it has, lining the wall with a flat sheet of rubber, as they do on other corners of the track, will give a flat surface upon contact, reducing the angle of the collision (as opposed to hitting the edge of a tire flat on).
Here's a bit of a diagram of what'll happen.
From this diagram and Newstons laws, I had a bit of an idea. Its absurd and it probably won't happen, but this system would act almost as a rubber band. The orange line represents a fance made of some material that is held through a small system of pullies that will absorb an impact and gently release the car back onto the track. This system is similar to that used by the catch cable on an aircraft carrier.
This sytem will stop head on collisions but will potentially cause other collision by interfering with what would normally just be a wide drift. This system would be very expensive and will rip up the grass (which is rumored to be the real motive of the tires). So, is extremely unlikely to happen.
Another alternative is to simply move the concrete wall right to the edge. This will be similar to Ebisu but more similar to Oran park.
Doing so will be extremely expensive and ruin the view from Deli Hill.
Another alternative (which will not ruin any grass) is to simply extend the ripple strip. Drifters will be discouraged to go wide by the extremely rough ripple strip and a loss of points given by the judges. This ripple strip would be similar to that at Meihan, seen in the following video.
We could also simply extend the bitumen right to the wall and allow it to be judged. This would provide for some truly epic entries and also give drifters the opportunity not to take the wider line. Put a photography/marshal bunker on the inside of turn one and you'll get some intense photos (help promote Mallala).
In conclusion, the cheapest, safest, and simplest option is to arrange the stacks differently. Apart from that, the track should be extended to the wall (allowing enough length for big entries) or a ripple strip placed. This wouldn't obstruct any view and possibly enhance the drifitng at mallala.
Of course there is always the option of removing the tires all together and going back to the good old days, maybe an instant lawn company would sponsor Mallala.
In the end, its a privilege for us to be allowed to drift and the track owners will do what they please, be it to save grass or save cars. We can voice our opinion and if need be, get sponsors on board and chip in, be it money or time, to do something ourselves.
Thanks a lot for reading the whole lot if you did, please keep discussion and possible solutions in here. I just hope we won't see a car go over and have a serious accident on these.
Tom.
Sign In
Register
Help
MultiQuote
