Sign In Register Help
hardtuned network
   silvia | skyline | gt-r | 350z | toyota | subaru | evo | honda | mazda | euro | raceline | clubs
Skyline Hoodies
Featuring an R32, R33, R34 & THE NEW R35 GTR front and rear, they are one of our best selling items!
AU $69.00
Drift & Auto DVD's
Motive DVD, Drifters Unleashed, Outrun tour of Japan. More drift & motorsport action than you can imagine!
From AU $14.95
Silvia Hoodies
Our #1 Selling item, we only have limited stock of these hoodies, so get in ASAP!
AU $65.00
Lanyards
Do you ever lose your keys? Find them easy by grabbing a lanyard, available in red, blue and black.
AU $6.00
Skyline Hoodies
AU $69.00
Silvia Keys
Custom made keys to fit your sil! Available in multiple colors and styles!
AU $29.00
Hardtuned.net: shimming ca diff - Hardtuned.net
Welcome to Hardtuned.net!
Are you new to the site?
why not sign up as a member?
It's free, and you get a tonne more features:
  • Removes this nag screen
  • Start new topics and reply to others
  • Subscribe to topics and forums to get automatic updates
  • Get your own PM box to message other members
  • Get your own profile and make new friends
  • Customize your experience !
Guest Message © 2010 DevFuse
Page 1 of 1
  • You cannot start a new topic
shimming ca diff
#1 User is offline   SIL-013  Icon
  • Standard Member
  • PipPip
  • Group: Standard Member
  • Gender:Male
  • Car Type:Nissan Silvia
  • Car Model:Nissan Slivia Q-series ca18de
Posted 27 September 2009 - 07:47 PM
hey
i have this stock turbo ca diff that i want to have shimmed up and put into my car but i have no idea what im doing. i have a guy that is doing the job and putting the diff in for me but he needs to know all the details but once again i have no idea.
so, i was just wondering if anyone could tell me all the details about shimming diffs and what you recommend me to do so it will lock up and slide but still reasonable to drive as a streeter
cheers
#2 User is offline   Brun Icon
  • Silver Member
  • PipPipPip
  • Group: Silver Member
  • Car Model:S13
Posted 27 September 2009 - 09:30 PM
View PostSIL-013 , on 27 September 2009 - 08:47 PM, said:
hey
cheers
Hey,
I am going through the process of getting my diff shimmed at moment.
get shims from nissan approx $10+ each
also you may want to make sure you have LSD or open diff as i think that most CA have open from what i have read, or they will have the smaller R180 diff.
The pics attached are a
R180 6 Bolt Open Diff
R200 5 Bolt LSD ( larger one ) note this is a r32 one which just has a different rear back plate.
If you have open diff then read the below link on how to weld it...
http://zilvia.net/f/...l-approved.html
if you have an lsd then read the below on how to shim...
http://forums.d1nz.c...e23f8822dc239a2
http://www.skylinesa...d=4817589&st=80
Shim Sizes & Prices (@tradeprice):
0.80mm = 3842440f60 price = $10.12
0.85mm = 3842440f62 price = $14.67
0.90mm = 3842440f63 price = $9.97
1.01mm = 3842440f67 price = $9.79
1.05mm = 3842440f68 price = $14.40
1.10mm = 3842440f70 price = $6.37
1.20mm = 3842440f73 price = $6.37
1.30mm = 3842440f76 price = $10.89
1.40mm = 3842440f80 price = $6.37
1.49mm = 3842440f83 price = $6.37
Attached thumbnail(s)
  • Attached Image
  • Attached Image
#3 User is offline   SIL-013  Icon
  • Standard Member
  • PipPip
  • Gender:Male
Posted 27 September 2009 - 11:43 PM
this is what mine is
and i just spoke with the dude that i bought it from and he said it was turbo lsd diff
#4 User is offline   D_Stirls Icon
  • Frustrated Member
  • PipPipPipPipPip
  • Group: Platinum Member
  • Gender:Male
  • Car Model:180sx
Posted 28 September 2009 - 05:17 PM
yep that's an R200. There used to be a good thread on a NZ site but that has disappeared now. Where are you located?
#5 User is offline   IDL05E Icon
  • Standard Member
  • PipPip
  • Car Model:S13
Posted 28 September 2009 - 06:50 PM
from memory what i picked up when i was looking at doing mine like 12 months ago was that from factory theres close to 1.8mm of shims? (someone else may be able to back this up) so if you wanted what i guess they would call a rebuilt diff it would have close to that 1.8mm and react as a "stock" diff would.
i was after something that was tight but not locked and aimed for 2.2mm hoping that it would be locked for a bit but soon wear out, but ended up with 2.8mm of shims LOL its locked and hasnt worn out what so ever after 12 month of driving :D
#6 User is offline   D_Stirls Icon
  • Frustrated Member
  • PipPipPipPipPip
  • Gender:Male
  • Car Model:180sx
Posted 29 September 2009 - 09:54 AM
Every diff will ahve a different size shim from factory as the viscus centres were all slightly different and they idea behind shimming them was to achieve a set torque between the two output shafts. in the ones i've done i've seen everything from a 0.8mm to 1.5mm shim. Also you only do one side. I know that people on here swear that you do both sides but even the factory manual states that only one side is an adjustment shim.
#7 User is offline   sr-ceffy Icon
  • Standard Member
  • PipPip
  • Car Model:nissan cefiro
yeh that is correct with the 1.8mm there is a 1.0 somthing on one side and a .8mm on the other side we normally just use two new 1mm shims from nissan and if you want extra tight add the old .8mm shim as well when you take the diff apart make sure you note which direction and side the bearing caps come off use a paint pen to mark them and also take photos of it all as you pull it apart the half shafts flanges you just smack them out with a hammer also remember to mark which side each came out of than the centre will come out sometimes with a couple of pry bars then you unbolt the ring gear of the centre and there are 2 star head screws undo them and pull that apart you will see the shims replace them and start putting it back together remeber take heaps of photos dont rely on your memory :)
Page 1 of 1
