Welcome to Hardtuned.net!
why not sign up as a member? It's free, and you get a tonne more features:
| Guest Message © 2010 DevFuse | |
want some noisee - can it be done screamer pipe on stock turbo/manifold
#1
Posted 16 June 2009 - 03:48 PM
can a internally wastegated turbo be run so it has a screamer pipe
basically stock turbo but want a screamer pipe for the sound lol
i know its not legal blah, blah
can this be done without much hassel
cheers
#3
Posted 16 June 2009 - 04:04 PM
#5
Posted 16 June 2009 - 04:16 PM
cheers
Stock turbo + Screamer =
They spool to easily, it would just get annoying for daily driving?
#6
Posted 16 June 2009 - 04:17 PM
#7
Posted 16 June 2009 - 04:21 PM
#8
Posted 16 June 2009 - 04:22 PM
its a hiflow ct26 off a MR2 so its got to be a custom job i think
so you guys dont recommend it ehhh
#9
Posted 16 June 2009 - 04:25 PM
need to be able to seal the two sections off completely or you will have a mass exhaust leak = loss of power = not really worth the hassles.
#11
Posted 16 June 2009 - 04:39 PM
http://hardtuned.net...amp;hl=external
basically wat we do is weld ur internal gate shut then modify ur exhaust manifold to suit an external gate
OR
we can modify ur exhaust housing to suit an external gate by welding the external gate flange str8 onto the exhaust housing <-- most people do with this option because its more eazy to hide the gate
#12
Posted 16 June 2009 - 04:40 PM
#13
Posted 16 June 2009 - 04:43 PM
REXUR-8, on Jun 16 2009, 03:21 PM, said:
sorry about my shitty drawing but i hope u get the picture. the green bit means your have to get the hole tht is there welded upand obviously cut on the red lines
that has got to be the most crappy way to go about it
the internal gate neva seals 100% like an external gate does so ur going to be driving around with an exhaust leak and we all know how annoying an exhaust leak sound is
#14
Posted 16 June 2009 - 05:43 PM
my 2c
#16
Posted 16 June 2009 - 09:31 PM
TRB-S2K, on Jun 16 2009, 04:43 PM, said:
my 2c
did i not make myself clear enuff???
#17
Posted 16 June 2009 - 09:48 PM
#18
Posted 17 June 2009 - 10:09 AM
but what about the second option which i cant understand
im not really keen on the first one for the reasons of if i get reamed the task of pullign turbo and manifold on a mid engined car is a pita and somethign i dont want to do or pay someone an arm to do either
i dont mind the divorced dump pipe as its the easiest of the lot to fix if get reamed but exhaust leak and power loss is putting me off it lol
would a divored dump with the internal wategate removed but an external gate added to the end of the divorced dump work
hope that makes sense
cheers
#19
Posted 17 June 2009 - 11:32 AM
#20
Posted 17 June 2009 - 12:06 PM
then how does the dump pipe attach to the exhaust housing
got any pics of this setup as i can picture this in my head lol
ps- i cant see any pics posted so if its already in there apologies
#21
Posted 17 June 2009 - 12:13 PM
ill try and explain it as simple as i can
the dump pipe still bolts onto the exhaust housing like standard
the external gate flange is welded onto the exhaust housing as well (it has nothing to do with the dump pipe)
#22
Posted 17 June 2009 - 12:53 PM
maybe some pics will help me
will this be easy to unbolt if i get reamed or is it a non reversible process
sorry mate im just not really sure how this method works lol
#23
Posted 17 June 2009 - 01:04 PM
#24
Posted 17 June 2009 - 01:19 PM
#25
Posted 17 June 2009 - 02:14 PM
if u want noise install a gay BOV or drill a hole in ur exhaust.
#26
Posted 17 June 2009 - 02:42 PM
#27
Posted 17 June 2009 - 03:30 PM
turbo has been hiflowed by someone else have the specs somewhere, something about a 80trim i remember
#28
Posted 17 June 2009 - 03:40 PM
i dont want big power which is why i chose to get a hiflowed turbo and not somethign aftermarket
just thought id see if the screamer can be incorporated into this system without much hassel
obviouslt this is just for the noise and to have some fun here and there so im not going to waste money on a new turbo for that
cheers
#29
Posted 17 June 2009 - 03:44 PM
#30
Posted 17 June 2009 - 05:17 PM
cheers
then go with what Emz said!
Sign In
Register
Help
MultiQuote
