Stock R33 Boost Questions - Hardtuned.net
2 replies to this topic
#1 FURBY
  • Car:Lada
Posted 11 April 2009 - 01:54 PM
Ok here is the situation
Have a Series 2 R33 only power mod is 3 inch dump and straight through to JunBL box.
What is the factory boost on a stock setup? Should be a bit more because of the dump.
Second question is what is the actuator pressure on a Rb25 turbo?
Now is it possible to remove the boost restrictor safely and run a constant say 12ish pounds?
I have done this before on a 32 GTR and run it off the actuator pressure and it runs a constant 1 bar of boost all the time but wondering if it will work on a RB25?
Cheers Furbinator
#2 Damit
  • Car:R33 & RB25 180SX
Posted 13 April 2009 - 11:19 PM
Cheers Furbinator
factory boost is 5 Psi to 4.5k than 7
hmm i know when my EBC wasnt working it ran at about 7-8 PSI so i assume that's what it will run at and i have Front mount and 3 inch exhaust as well
#3 Basti
Posted 06 May 2009 - 03:17 AM
rb25 actuator is 5psi - your "low boost". it is then solenoid controlled to 7psi - "high boost". if you want more, try the rb20 actuator which is a 10psi thang use it without the solenoid. with your dump and zorst and stuff you should be running approx 9psi anyway
