Sign In Register Help
hardtuned network
   silvia | skyline | gt-r | 350z | toyota | subaru | evo | honda | mazda | euro | raceline | clubs
Skyline Hoodies
Featuring an R32, R33, R34 & THE NEW R35 GTR front and rear, they are one of our best selling items!
AU $69.00
Drift & Auto DVD's
Motive DVD, Drifters Unleashed, Outrun tour of Japan. More drift & motorsport action than you can imagine!
From AU $14.95
Silvia Hoodies
Our #1 Selling item, we only have limited stock of these hoodies, so get in ASAP!
AU $65.00
Lanyards
Do you ever lose your keys? Find them easy by grabbing a lanyard, available in red, blue and black.
AU $6.00
Skyline Hoodies
AU $69.00
Silvia Keys
Custom made keys to fit your sil! Available in multiple colors and styles!
AU $29.00
Hardtuned.net: 89 S13 Silvia - Building to perfection - Hardtuned.net
Welcome to Hardtuned.net!
Are you new to the site?
why not sign up as a member?
It's free, and you get a tonne more features:
  • Removes this nag screen
  • Start new topics and reply to others
  • Subscribe to topics and forums to get automatic updates
  • Get your own PM box to message other members
  • Get your own profile and make new friends
  • Customize your experience !
Guest Message © 2010 DevFuse
  • (44 Pages)
  • 1
  • 2
  • 3
  • Last »
  • You cannot start a new topic
89 S13 Silvia - Building to perfection 2011 Circuit car
#1 User is offline   Nigel Icon
  • Platinum Member
  • PipPipPipPipPip
  • Group: Platinum Member
  • Gender:Male
  • Car Type:Nissan Silvia
Posted 11 March 2008 - 01:41 PM
Hi guys, i have a build up in drift chat but i thought i would start one in the correct section.
Heres a partlist but the parts are just the start of the car, everything is modified to how i think it should be. Its far from finished but will be on the track soon.
1989 Nissan Silvia
Owner: Nigel Petrie
Occupation: Fitter and Turner
Length of ownership: 2 years
Mods:
Engine:
Fully rebuilt SR20det
TOMEI Rocker arm Stoppers
TRUST Inl 264, EX 272 11.5mm Cams
GREDDY Valve springs
HKS 1.2mm Head gasket
ARP head stud kit
Nismo low temp thermostat
CP 86.5mm Forged pistons (9.0 Comp ratio) Ceramic and teflon coated
EAGLE Forged H beam Rods
Rebuilt Head
Trust sump
Billet underdrive pulley set
Racespec engine mounts
Splitfire coilpacks
GFB lightweight crank pulley
Microtech LTX8 computer with custom loom
Induction and exhaust:
Trust TD06L2 full turbo kit with 45mm ext wastegate
Custom lobsterback inlet pipe with filter
Custom intercooler pipeing
Hybrid GT cooler
Samco joiner hoses
80mm Billet alloy throttle body
Custom Inlet plenum with bellmouthed 75x45mm ram tubes
Full 3 inch stainless exhaust
Vaccum distributer can with earls fittings
Cooling:
Earls 16 Row oil cooler with GREX sandwich plate and Earls dash 10 lines
Custom 3 Core 60mm radiator
Custom alloy radiator plumbing
Greddy header/ Bleeder tank
Modified engine coolant lines with billet allow flow block and earls fittings
Twin 12inch thermos with proper shroud
Nismo thermostat
Custom coolant overflow bottle
Fuel:
R33 GTR fuel pump
Sard regulator
Defi fuel pressure gauge
Custom fuel rail with earls Dash 6 hose fittings
870cc VDO Siemens injectors
Driveline:
Z32 Gearbox with self made SR20 adapter kit
Short shifter mounted 150mm further back with a custom linkages
OS Giken Fly Wheel
OS Giken TS2B Twin plate Clutch
Nismo rubber Gearbox Mount
Custom 1 piece 4 inch Tailshaft with Safety hoop
ATS Carbon clutch pack 2 way diff with 4.08 gears
Suspension:
Greddy Type S Coilovers with in cabin EDFC adjustment
160mm long 8k front springs, 200mm long 6k rear springs
S13 lower control arms, cut and shut to be 30mm longer each side
16mm Tie rods
Ikeya formula tie rod ends
Offset rack spacers
New rack bushes
Kazama Adjustable caster rods
S15 Knuckles cut and shut
22mm front swaybar with rose jointed mounts
20mm rear swaybar with rose jointed mounts
Adjustable Tubular rear camber arms
Adjustable Tubular rear toe arms
Adjustable Tubular rear traction arms
Rear lower control arm cut and shut to be 10mm longer
R33 rear knuckles, cut and shut to lower the shock and toe point 25mm
Custom rear cradle bushes made from solid urathane
Urathane mounts replace every existing rubber bush
Footwork:
Front: Rays Volk Racing TE37 17x9.5+12 with 215/40/17 rubber.
Rear: Rays Volk Racing TE37 17x10+18 with 235/40/17 rubber.
Rays wheel nuts
Spare set of 17x10+15 Lensos for the rear
Brakes:
R33 GTR Brembo Brakes all round
EBC red stuff pads
DBA Slotted rotors
Maltech Braided lines replace all factory solid and flexible lines
Tilton Pedal box with short 75 series Tilton master cylinders
Custom hydraulic handbrake with Tilton master cylinder in the console
Willwood F-R Brake bias adjuster
Inside:
Bride Vios III bucket seats with custom super low mounts
Shaved dash with alloy guage panel
Defi Boost gauge
Defi Oil Temp gauge
Defi Oil Pressure gauge
Defi Exh Temp
Defi Water Temp
Defi Fuel Pressure gauge
Defi controller
Motec overheat light, alternator excite and Oil press warning light
Custom loom made from scratch (not 1 original wire in the entire car)
Start button and toggle switches for power windows, parkers, lights and ignition on the roof
Removeable steering wheel hub
Custom 100mm steering spacer
Nardi deep corn sued steering wheel dished 80mm
Guttered dash
Oddysey dry cell battery mounted on top of gearbox tunnel
GPS speedo
Chassis:
Original paint
Interior stripped to bear metal and rattle canned machinery grey
Stich welded chassis
Strengthened strut towersRaised rear strut towers 50mm
Strengthened chassis rail
Modified Safety 21 roll cage with welded on mounts
Custom front tubs
Custom tin work for the pedal box, seat mounts and floor
Custom radiator/intercooler removable support (to make removing gearbox and motor easier)
Outside:
Nissan Aero option front bar
Nissan Aero option side skirts
Hammer umped guards
Raised bonnet
Shaved bootlid
East Bear non electric mirrors
Origin carbon roof lip, boot lip and sun shades
Heres a little picture diary of where the car came from.
Picked the car up fairly complete but lots of work to be done
How it started off
Did a few track days
25mm spacers
Then SR time
Z32 conversion
More track days
New wheels
Destroyed motor
Fitted full cage
Toyed with LS1 idea
Tubbed front
Tilton pedal box
New Bride Vios III
Pulled down gearbox to check it
New motor
Foot rest
Extended gear lever
Roof lip, boot lip and sun visors
More pics when i finish it off
Attached thumbnail(s)
  • Attached Image
#2 User is offline   -ichigo- Icon
  • Ballerific Zenki
  • PipPipPipPipPip
  • Car Model:ichigo
Posted 11 March 2008 - 02:25 PM
nigel id officially like to welcome you to awsometown :)
#3 User is offline   JDM-32 Icon
  • Standard Member
  • PipPip
  • Group: Standard Member
  • Gender:Male
  • Car Type:Other
  • Car Model:180sx Type X.
Posted 11 March 2008 - 02:56 PM
Wow hot much?
Jase
#4 User is offline   GFUNK Icon
  • Get Dirty.
  • PipPipPipPipPip
  • Gender:Male
  • Car Model:S13 Silvia
Posted 11 March 2008 - 03:07 PM
your garage is so small yet you have done so much in it
love watching the build up man, keep us updated
#5 User is offline   Softy Icon
  • Boozehound
  • PipPipPipPipPipPipPip
  • Gender:Male
  • Car Type:Other
Posted 11 March 2008 - 03:12 PM
As i have said b4....
The boys got skills with the tools.
#6 User is offline   Nigel Icon
  • Platinum Member
  • PipPipPipPipPip
  • Gender:Male
Haha, thats 1 of my biggest frustrations. Thats why im now saving my ass of for a house so i can build a proper shed :) I tell you what theres not much you cant do with a good welder, grinder and a bit of imagination/ skill
#7 User is offline   Club Spec Icon
  • Platinum Member
  • PipPipPipPipPip
  • Gender:Male
  • Car Type:Subaru
  • Car Model:WRX CS6
Posted 11 March 2008 - 07:56 PM
awesome build up, well done
#8 User is offline   SLK-200 Icon
  • Standard Member
  • PipPip
  • Gender:Male
  • Car Model:s14 200sx
Posted 11 March 2008 - 08:32 PM
This car looks so good in the pics and looks even better in the flesh!!! :yes: keep up the good work dude catch up with ya soon...
#9 User is offline   Biggie Icon
  • Fast Fours and Rotaries
  • PipPipPipPipPip
  • Group: Events Coordinator
  • Gender:Male
  • Car Model:96' Type X
Posted 11 March 2008 - 08:40 PM
very very hot ride :D
#10 User is offline   one-eighty Icon
  • Backyardigan
  • PipPipPipPip
  • Group: Gold Member
  • Gender:Male
  • Car Type:Other
  • Car Model:s12 gazelle and rps13 180sx
Posted 11 March 2008 - 08:56 PM
dude! i dont even have a shed or garage, i have a loose stone driveway and my trusty ply board. and check out my build.
not tryin to hijack your thread dude u gat some awesome skills, i'me always a bit scared to whip out the welder and grider and take to my car with it.
car looks mickey mouse mate top job.
#11 User is offline   blingcommander Icon
  • 504 / hardtooned is awesome
  • Gender:Female
  • Car Model:S14a 1JZ powah
Posted 11 March 2008 - 09:25 PM
you know how much i love your car already, and that will show in my new build, it will look nearly the same, but reverse panda :wub: and also with the idea that you toyed with ;)
and don't forget the tune i'm paying for :lol:
#12 User is offline   mindcircus Icon
  • OKAYY!!
  • PipPipPipPip
Posted 11 March 2008 - 10:34 PM
we all know how sexy your car is =]
one question is this car still street legal?
#13 User is offline   Karbonyte Icon
  • Unresponsive member
  • Group: Euro Manager
  • Gender:Male
  • Car Type:Other
Posted 12 March 2008 - 01:35 AM
:yes:
Awesometown.
POPULATION: YOU!
#14 User is offline   turkishskyline Icon
  • Platinum Member
  • PipPipPipPipPip
  • Gender:Male
  • Car Model:s14a
Posted 13 March 2008 - 01:05 AM
this has got to be one of my faveourite cars atm your engine bay is sooooo clean how did you do it let me in on the secret
#15 User is offline   Danny_S15 Icon
  • 1 2 3 4 5
  • Icon
  • Group: Classifieds Moderator
  • Gender:Male
  • Car Model:nissan 200sx s15 spec s gt
Posted 13 March 2008 - 01:14 AM
absolutely awesome. nice to see a build from the ground up, would love to do one some day. well done
#16 User is offline   TURBOS Icon
  • TURBOS
  • PipPipPipPip
  • Gender:Male
  • Car Model:1993 180SX
Posted 13 March 2008 - 10:46 AM
absolutely awsome build, love the way u go about things, very clean neat and functional, mad ride
#17 User is offline   ant_s13sil Icon
  • Gold Member
  • PipPipPipPip
Posted 13 March 2008 - 11:51 AM
very nice car, very clean!
couple of questions :P i assume since you drift it you havent had any problems, but how does the 215/40 go on the 9.5? i am getting 18x9.5s for my s13 and had asked around and general concensus was to go 225 as 215 is too narrow. so i was thinking 225/35 so i can go nice and low. but if 215/40s can go on they may be better?
and where did you get/how much were those weather shields? assuming theyre carbon?
#18 User is offline   blingcommander Icon
  • Gender:Female
Posted 13 March 2008 - 07:52 PM
origin carbon, through streeter........
i think nigel has a stalker :ph34r:
#19 User is offline   Front Line Icon
  • Nissan Silvia's Rookie of the Year 08'
  • PipPipPipPip
  • Gender:Male
  • Car Model:Nissan Silvia S13 1992 Q-spec.
Posted 17 March 2008 - 07:15 PM
Chiefff!!! Nicceee!
I really love those white rims mate!
Do you recommend them!?
Can you give me the model of them, what inch, where you got them, and how much? (Either here or a pm please really interested!)
#20 User is offline   Xenosis Icon
  • Standard Member
  • PipPip
  • Gender:Male
  • Car Model:1993 Nissan Silvia
Posted 17 March 2008 - 09:03 PM
I came.
#21 User is offline   blingcommander Icon
  • Gender:Female
Posted 17 March 2008 - 09:09 PM
View PostFront Line, on Mar 17 2008, 07:15 PM, said:
Chiefff!!! Nicceee!
Footwork:
Spare 18x10.5+22 Rays Volk Racing TE37 in Bronze
Rays wheel nuts
all in the specs ;)
#22 User is offline   Front Line Icon
  • PipPipPipPip
  • Gender:Male
Posted 17 March 2008 - 09:36 PM
Chiefff!!! Nicceee!
Footwork:
Rays wheel nuts
all in the specs ;)
Ah sorry i got that mistaken with pedals =(
But thanks!!! Can you hit me up with pricing???
#23 User is offline   blingcommander Icon
  • Gender:Female
Posted 17 March 2008 - 11:46 PM
Chiefff!!! Nicceee!
Footwork:
Rays wheel nuts
all in the specs ;)
HEAPS :yes: i just bought the 2 18s off him for 1200 with shagged tyres, was quoted around 1700 delivered to my door with no tyres for a new PAIR. and they don't go much cheaper for 17s either
#24 User is offline   Spenda Icon
  • NeverSpool
  • PipPipPip
  • Group: Silver Member
  • Gender:Male
  • Car Model:S14 S2 - VET
Posted 18 March 2008 - 10:11 AM
I love everything about this car... nice work nigel...
#25 User is offline   Dragon180 Icon
  • Gettin' loooooose!
  • PipPipPip
  • Gender:Male
  • Car Type:Other
  • Car Model:'92 Nissan 180SX
Posted 21 March 2008 - 07:13 PM
F$cken hell Nig,
You've built another HORN AS car, unfortunately you won't get this one on the front of DB. It's a damn shame!
Must catch up sometime soon and share your secrets.
R.
Cooba
#26 User is offline   sneaky fujita Icon
  • Standard Member
  • PipPip
  • Gender:Male
  • Car Model:1997 Nissan 180sx TypeX
Posted 21 March 2008 - 08:04 PM
This car of yours is amazing. You've added so many handmade touches and all the work is so clean it looks like it could well be OEM. The details are simply stunning.
I can openly admit i have less than none of the 'mad build skills' that you have, i am left in utter awe. Don't stop modding and please don't stop taking pics to show all of us.
Keep it up.....
#27 User is offline   billyAHH Icon
  • VLNY
  • PipPipPipPipPip
  • Gender:Male
  • Car Type:Nissan Skyline
  • Car Model:Nissan Skyline R32 GTS4
Posted 22 March 2008 - 11:11 AM
i love the s13 silvias with stock body and wide ass rims... VERY SEXY CAR nigel well done man...
#28 User is offline   HarryHighpants Icon
  • Standard Member
  • PipPip
  • Gender:Male
Posted 22 March 2008 - 03:07 PM
I had a dream about this car last night...
I think im obsessed with it...
I cant stop thinking about it...
:hypo: :hypo:
#29 User is offline   pig513 Icon
  • Silver Member
  • PipPipPip
  • Car Model:1989 180sx, 1991 fc rx7, 1jz cressida
Posted 25 March 2008 - 12:55 PM
to me this car is perfect. every thing about it is right! i love it, verty good work with the build up. hanging out to see it done and back on the track
#30 User is offline   Phil.s15 Icon
  • Silver.s15
  • PipPipPip
  • Gender:Male
  • Car Model:Toyota Celica
Posted 25 March 2008 - 01:22 PM
thats a sick s13 u got urself their mate awsome wheels they sex
  • (44 Pages)
  • 1
  • 2
  • 3
  • Last »
