Track tyres and the size game - Hardtuned.net
225 235/45 or 235/40 or 245/40
10 replies to this topic
#1 davidg2152
  • Car:S13 SR20DET
Posted 26 February 2017 - 02:36 PM
Well my 888R's are closing in on retirement and I want to try and neaten up the nugget for consistency.
I currently have 225/45/17 front and 235/45/17 rear Toyo 888R's.
I have been told Nitto NT01's are pretty similar (made by Toyo) and have a 100TW. I want to give em a go (unless something else pops up) but they come in either 225/45 (and I dont want to take tyre away) or 235/40 and 245/40 widths.
I run a 17x8 Lenso D1 rim.
From my calcs the 235/40 should be fine and the reduction (albeit sweet FA) in rolling diameter will only assist acceleration.
Has anyone played with this at all and any experiences I can learn from?
Car is 100% track only.
#2 boost-it
  • Car:180sx Type X
Posted 27 February 2017 - 10:25 AM
r888r is a faster compound than the nt01. i have run nt01 for a while now and they are a good entry level semi slick. they feel almost very much like a fast road tyre than a semi slick tbh.
when you step it up to the hankook z221 or the advan ao50 the grip level is on another level.
as for tyre sizing find a combination dont wont rub or limit your castor settings/alignment. 225 is a little on the skinny side and is an unpopular size for semis.
#3 davidg2152
  • Car:S13 SR20DET
Posted 27 February 2017 - 01:23 PM
Great advice mate. I was told the Nitto is actually a Toyo as from same factory but as you have used them I will run with it.
Would a 235/40/17 work on a 17*8 or even a 245/40?
I think the 235s should be able to somehow go on the front of it witjout too much drama?
#4 boost_bus180
Posted 27 February 2017 - 03:47 PM
I've had 235/40 and 255/40 NT01 tyres on 9" rims and to be honest there wasn't that much of a visible difference in the sidewall angle when fitted and on the car. not as much as I expected anyway. I think a 235/40 on a 8" rim would be ok, but it will be a bit sloppy compared to it on a 9" rim. that said, I remember one of the guys in QLD with the yellow silvia (SC_180 or something arather) had 255/40 all round on 9" rims with no issues, so going by that your 235 on a 8" rim will probably be fine
Edited by boost_bus180, 27 February 2017 - 03:54 PM.
#5 davidg2152
  • Car:S13 SR20DET
Posted 27 February 2017 - 10:36 PM
I currently have a 235/45 on the rear
thought a 235/40 on front woukd take away any scrub issues
#6 Varvs
  • Car:97 180sx Type X
Posted 28 February 2017 - 08:57 AM
I have 235/4517s on 8" and they rub a bit at full lock. thats RE003s though, not semis.
sidewalls are flush with the face of the wheel.
#7 davidg2152
  • Car:S13 SR20DET
Posted 28 February 2017 - 05:57 PM
Thanks mate do they scrub on inner or on the actually gourd lip?
#8 boost_bus180
Posted 01 March 2017 - 04:52 AM
Your wheel offset, and to a lesser extent your ride height, will be the determining factors of where and when your tyre scrubs. 235/40 is a very conservative size tyre to use on a silvia and can fit just fine. You're stressing over nothing here
#9 Varvs
Posted 01 March 2017 - 05:25 PM
scrubs on the inside and depending on incline, the outside catches in the tread grooves.
castor plays a big part too as it moves the wheel further forward, closer to the guards.
#10 Dose Pipe Sutututu
  • Car:Boat Sutututuutu
Posted 02 March 2017 - 06:43 AM
a 235 section semi and a 235 section non semi will be noticeably different in terms of overall tyre with.
If a 235 road tyre is scrubbing going to a 235 semi will scrub even more due to the thicker side walls.
#11 davidg2152
  • Car:S13 SR20DET
Posted 02 March 2017 - 07:46 AM
copy mate.
I guess is using a 235/40 over a 225/45 actually going to achieve anything really.
