Sign In Register Help
hardtuned network
   silvia | skyline | gt-r | 350z | toyota | subaru | evo | honda | mazda | euro | raceline | clubs
Skyline Hoodies
Featuring an R32, R33, R34 & THE NEW R35 GTR front and rear, they are one of our best selling items!
AU $69.00
Drift & Auto DVD's
Motive DVD, Drifters Unleashed, Outrun tour of Japan. More drift & motorsport action than you can imagine!
From AU $14.95
Silvia Hoodies
Our #1 Selling item, we only have limited stock of these hoodies, so get in ASAP!
AU $65.00
Lanyards
Do you ever lose your keys? Find them easy by grabbing a lanyard, available in red, blue and black.
AU $6.00
Skyline Hoodies
AU $69.00
Silvia Keys
Custom made keys to fit your sil! Available in multiple colors and styles!
AU $29.00
Hardtuned.net: S15 owners with splits - Hardtuned.net
Welcome to Hardtuned.net!
Are you new to the site?
why not sign up as a member?
It's free, and you get a tonne more features:
  • Removes this nag screen
  • Start new topics and reply to others
  • Subscribe to topics and forums to get automatic updates
  • Get your own PM box to message other members
  • Get your own profile and make new friends
  • Customize your experience !
Guest Message © 2010 DevFuse
Page 1 of 1
  • You cannot start a new topic
S15 owners with splits placement of crossovers and tweeter
#1 User is offline   SIL80 Icon
  • Platinum Member
  • PipPipPipPipPip
  • Group: Platinum Member
  • Car Type:Nissan Silvia
  • Car Model:S15
Posted 31 October 2005 - 09:59 PM
As per title, I am planning my install at present. Where are ppl mounting their tweeters and crossovers. ATM I am thinking of placing the crossovers under the door skins, just need to cut some foam out from the inside skin to make room (S13's have plenty of room) or I'll place them both in the glovebox.
Tweeters are either gonna be on the kick panels or flush mounted onto the door skin next to standard speaker hole. I really don't want to cut door trims or plastic panels but this appears to be only option at present.
So what have all you other S15 owners done with your set up.
#2 User is offline   _ck_ Icon
  • Standard Member
  • PipPip
  • Group: Standard Member
Posted 31 October 2005 - 10:09 PM
Crossover inside door trim.
Tweeter in the plastic bit surrounding door handle. You're going to have to cut a hole unfortunately but replacement plastic bit shouldn't cost that much.
Midrange in the same place as standard speaker. I'm running 6.5 inch splits.
ck
#3 User is offline   domino_m Icon
  • Standard Member
  • PipPip
Posted 31 October 2005 - 10:26 PM
Cross-over in the boot (i have really big crossover boxes) with the tweeter up high near the windows.
Bad idea to put your tweeters where i have... the treble is too 'bright' with my tweeter placement... try to put it low... as close to the woofer as possible.
#4 User is offline   Hail Icon
  • Platinum Member
  • Icon
  • Group: Retired Moderator
  • Gender:Male
  • Car Type:European Car
  • Car Model:MY10 Volkswagen Golf GTI
Posted 02 November 2005 - 07:33 AM
ck
My set up is very similar...
Sounds awesome!
#5 User is offline   agg25 Icon
  • Platinum Member
  • PipPipPipPipPip
Posted 02 November 2005 - 10:37 AM
I thought everyone put the tweeter up high like that? I've heard heaps say it sounds better up closer to your ear???
#6 User is offline   Axis Icon
  • Standard Member
  • PipPip
  • Gender:Male
Posted 02 November 2005 - 02:36 PM
That's not really the case, but its a matter of personal preference really.
Ultimately the tweeter and the mid-range are both the same distance away from your ear to ensure that the music from both hits your ears at the same time. The easiest way to achieve this is to put them next to eachother.
You can heighten your sound stage by placing them higher in your car but if you still achieve the same physical distance then you're probably doing even better :)
#7 User is offline   BrenV Icon
  • 258kw@17psi
  • PipPipPip
  • Group: Silver Member
  • Car Model:S15
Posted 06 November 2005 - 08:34 PM
Ive got Boston Pro 60s in mine and they do have quite large crossovers. When u take off ur door trim u will see two space fillers, take one of them out and mount the croosovers on that.
In the plastic door handle surround u will notice that there is a circle section visible on the inside of the surround. My tweeters fit perfect in there so i drilled that out and placed them there. I attentuated the tweeters down to -4dB.
I know that this isnt the best position of the tweeters for imaging and staging but I am really happy with the sound. I dont find much seperation plus I like a bit of treble so its perfect for what I want, listening to R&B.
Bren
#8 User is offline   PCOTY Icon
  • V35 350GT
  • PipPipPip
  • Gender:Male
  • Car Type:Nissan Skyline
  • Car Model:2003 V35 350GT Coupe
Posted 11 November 2005 - 12:03 AM
If anyone wants to swap their uncut standard S15 door handle surround for mine which is already cut for tweeters (I have taken the stereo out and want to return it to stock), then I'm keen to swap.
#9 User is offline   BLU200 Icon
  • Standard Member
  • PipPip
  • Car Model:'01 S15
Posted 11 November 2005 - 11:00 AM
I have my old Kef KAR 160.2's in the car out of my old Pulsar. Had the tweeters mounted over the top of the woofer using a metal strap to create a bridge. They're mounted in the doors in the stock location with a woods surround.
The crossovers are mounted up in the dash. ie behind the steering cluster and centre cosole etc.
Stealth install.... (not that its a big system or anything)
#10 User is offline   Project_Noir Icon
  • Newbie
  • Pip
  • Group: Newbie
  • Car Model:Nissan 200SX Spec R GT
Posted 15 November 2005 - 10:50 PM
I've got the same setup as ck.
My mate has set his tweeters in the corners of the dash, they're sitting on little feet which are stuck on to the dash.
#11 User is offline   KSW Icon
  • Silver Member
  • PipPipPip
Posted 16 November 2005 - 03:12 PM
I put my tweeters in the little air conditioning grills in the top corners of the dash, sounds great and you cant even see them.
#12 User is offline   khoala Icon
  • O_o
  • PipPipPipPipPip
  • Car Model:S15 Silvia
Posted 21 November 2005 - 10:05 PM
tweeters in door trim
crosovers in boot
if you see my setup, you will know why
#13 User is offline   s15dude Icon
  • Newbie
  • Pip
  • Group: Newbie
  • Gender:Male
  • Car Model:2001 s15 spec r
Posted 05 November 2009 - 08:27 PM
ck
Sounds awesome!
i think i am going to have to do the same...where abouts inside the door trim did u put the crossover? i have found a point, wil have to make a bracket, but can mount it in between the metal rods that open and close door and the electric window tracks. fits there perfect just a c*** to secure it!!
#14 User is offline   Shiraz200SX Icon
  • Silver Member
  • PipPipPip
  • Gender:Male
  • Car Model:200SX S14A
Posted 06 November 2009 - 07:08 PM
crossover in door trim = FAIL!
worst place for them. water can get inside the trim, then bye bye crossover. kickpanels or boot.
#15 User is offline   OLiK Icon
  • Platinum Member
  • PipPipPipPipPip
  • Gender:Male
Posted 22 November 2009 - 10:47 AM
how big are the stock speakers in the doors of a s15?
#16 User is offline   Shiraz200SX Icon
  • Silver Member
  • PipPipPip
  • Gender:Male
Posted 22 November 2009 - 09:45 PM
16-17cm.
#17 User is offline   chris268 Icon
  • BYAAAH!
  • PipPipPipPip
  • Group: Gold Member
  • Gender:Male
  • Car Model:S15 200SX Spec R
Posted 24 November 2009 - 04:48 PM
I've got 6.5 inch splits with 3/4 inch tweeters.
crossovers in the door trim. Never had issues with them being water damaged.
#18 User is offline   SAM112 Icon
  • Sam!
  • PipPip
  • Gender:Female
  • Car Model:S15 200sx SpecR
Posted 02 December 2009 - 08:35 PM
Neither have I, but then one tweeter has just died for no apparent reason..
#19 User is offline   nutty Icon
  • I got cherry eyes
  • Icon
  • Group: Donating Member
  • Gender:Male
  • Car Model:S15
Posted 04 December 2009 - 09:31 PM
I got crossover in the trim tweeters here
#20 User is offline   -**wHiStLe**- Icon
  • *Jailbait Movement* !!! Bandwagon slaaart
  • PipPipPipPipPip
  • Gender:Male
  • Car Model:S15 on her wayyyy
Posted 04 March 2010 - 03:22 AM
Any instruction on the easiest way to get door trims off?
#21 User is offline   Sonz Icon
  • Standard Member
  • PipPip
Posted 15 March 2010 - 09:08 PM
+1. i couldnt get the passenger side off so i gave up after an hour. lol.
#22 User is offline   nutty Icon
  • I got cherry eyes
  • Icon
  • Gender:Male
  • Car Model:S15
Posted 15 March 2010 - 09:17 PM
Easy,
one screw in the phone/wallet holder thing just pop the cap in the bottom, then one behind door handle once again pop off the plastic cap thing.
then just pop all the plastic srews out from around the outside, then just lift the trim up
#23 User is offline   xgsir Icon
  • Standard Member
  • PipPip
  • Gender:Male
Posted 05 May 2010 - 03:51 AM
I placed my tweeter near the door handles as well.
As for preventing water damage to the cross over, just try to cover the unit to prevent moisture from getting into it.
#24 User is offline   IXnakedXI Icon
  • My S15 is auto LOL
  • PipPipPipPipPip
  • Gender:Male
Posted 10 May 2010 - 12:24 PM
my tweeters are on the plastic triangle opposite of the mirrors, speakers are in the standard spot, rear speakers are in the standard position, and rear tweeters are in a panel I made that separates the boot from the cabin (when the seat is folded down).
Page 1 of 1
